Hyundai Veracruz Key Fob is a Nuisance
in Hyundai
I've only had my Limited a week but already I've had several instances of annoyances with my key fob.
Twice I have been carrying the fob in my pocket and later found the rear hatch open. Also, I have bent over with the fob in my pocket and turned on the alarm
These buttons need to be recessed or made less sensitive.
Has anyone else experience this type of event?
Maybe I carry more stuff in my pockets than some, which impact the fob.
Mike
And there may be some info you can scout out using one of the Honda links in the Online Repair Manuals guide.
Those of you that don't have it, believe me, you have to have it to understand the love affair.
One thing, when you open the door and want to say vacuum the car, you have constant beep, beep. Same beep as when you leave the key in the ignition with a "key vehicle." I queried the dealer several times and nobody could figure out how to silence the beep.
I finally figured it out - pull on the ignition switch one click toward you. You can still have the fob in your pocket, and the beep is silenced. Guess Hyundai had it figured out all the time to, but, forgot to document it.
You MUST remove ALL keys to outside the car before the door buttons will work...
I'm thinking of getting some kind of hard case to put my key in. Has anyone else found a solution?
Or do you have to insert it in the key hole to start the car?
And also does it have remote engine start? Like GM's?
I've had mine for 10 months and I couldn't tell you how many times that I have inadvertently opened the hatch, locked the doors or invoked the security alarm.
I hope Hyundai is working on a fix for this issue.
They may have fixe this key fob button problem on the latest models as my Veracruz has a May 08 manufacturing date (Hyundai is known for making slight improvements like this and not even mentioning them). My Veracruz also has the new "softer" leather seats with the intentional tucks in the leather to accomplish this effect. However, I hate the look and feel of this as the one I tried before getting this brand new one off the truck had the firm, nice looking leather seats with really tightly stretch leather. The dealer is going to change out the seats with one of their older vehicles today, though.
Larry
There was a post about someone else not having this happen to him. He said that his car build date was very recent, June 08 as a matter of fact. Mine is on April 08. He also said Hyundai could have fixed the problem.
When is the build date of your VC?
Does anyone have any cheaper alternatives to get a replacement? Is that $100 reprogramming fee negotiable? I assume that's the labor cost.
Thanks in advance for your suggestions.
For the previous poster, regarding pressing the button while in the car, if the ignition is on, it locks out the remote, including the door locks, just about every car that uses a remote does this. You will also not be able to open the hatch if the car is in gear. The button by the glove box disables the handle in the door, but the remote and dash button still work.
One of the nice features of this fob over the Toyota, or Mazda keys, if the battery in the fob dies, you can stick it in the ignition slot for it to work. I don't know how the Mazda one works, but the Toyota key you need to touch the Toyota emblem to the start button ring and press the start button, and it usually takes two hands to do so, I tried, isn't as easy as it looks.
I have had the doors lock on their own while in the garage though, still unknown how that happens, did it at least twice for me.
John
Chumo
It has happened numerous times since. We've talked to our Hyundai dealer and he says there is no fix or any official from Hyundai. I'm thinking of grinding the button off.
I have a 2009 Veracruz and my fob has just stopped working. No buttons work. Just replaced the battery, but no luck. My second key fob works normally. The second key fob just sits in the draw so it is like new. Now the obvious solution is to simply start using the second (like new) key fob. But that wouldn't be any fun! Has any one experienced a key fob that stopped working? Is there possibly a reset button? Any help appreciated. Thanks.
