Visitor Agreement.
Has anyone else found an aftermarket keyless that works well?
Thanks for any info. (by the way, the car is great: quite, smooth, good economy)
Pictures of my aftetmarket unit at:
http://autos.ph.groups.yahoo.com/group/YarisintheUSA/photos/view/1c2d?b=1&m=s&o=- 0
Only one day left: leather covered armrest
What is correct?
Has anyone gotten 2 keys with their remote entry Yaris (Sedan or LB)?
The salesman is contacting the district rep, but I would like to know what your experience has been.
Ravelco
I paid a total of $240 (installed) for darker window tinting :shades:
($100)
and a Prestige Model APS-25CH alarm. :mad: ($140)
Now admittedly, I probably got a little better pricing than the average joe (kinda a-friend-of-a-friend thang) but still I got a very good alarm installed at a fairly reasonable price.
Are there more expensive alarms out there on the market: you betcha. But this model has many advanced features: code hoping RF, Starter disable, Intrusion alert, Code learning, Protected valet, Remote panic, User selectable chirp delete, Shock sensor, Loud six multi-tone siren, and on and on...
I have a Clifford alarm on my wife's vehicle but those have gotten just too high dollar for me (especially with the price I paid for a Yaris - I don't need an alarm that costs half the car's value!!!). The Prestige alarm is a good balance between features/capability and price.
________________
Drew
Toyota 07 Yaris - Get the Toyota 07 Yaris Catalog by Toyota Motors
I need the driver's side, front to back..front and rear quarter panels and the front and rear door.
Mine is the charcoal grey color.
What cruise control kit is Toyota of Canada installing? Is it a factory parts thing or the Brandon Distribing (BD) after market kit that was developed for Gulf Toyota.
I contacted BD and they said their kit uses the embedded programming already in the ECM computer but requires a seperate (not Toyota's) control head (buttons for Set, Resume, etc.) and "splicing" into the existing harness. I intend to contact them again and get more information before I risk my warrantee.
I'll try to investigate Toyota of Canada's cruise control option, too.
LDBennett
1). Toyota for the California area has no option for cruise control for the Yaris Hatchback, either originally or dealer installed.
2). Toyota for the California area threatened possible revocation of a warrantee repair if sedan parts or after market parts where installed to obtain cruise control, if either caused damage to the car's systems requiring repair. This was to be judged on a case by case basis (its the law, I believe, that they have to prove your modification created the warrantee problem before they can refuse to pay).
3). All the parts and the programming are already in the car for cruise control except the control head (Set, On/Off, Resume switches mounted on a stalk under the steering column in the sedan). What may also be missing is the cable that weaves through the steering column for the stalk (??).
4). Brandon Distributing (BD) makes an after market crusie control for either the Manual or A/T model Yaris. It is a control head (same functionality as the sedan cruise control stalk). The A/T model requires splicing into one wire that goes into the ECM computer at the point where the cruise control signal from the control head normally would enter the ECM. The control head would also be required to be grounded. The unit uses the Toyota embedded programming for the cruise control function. So you get install instructions, and the control head with attendant wiring with the BD kit. There is no vacuum motor for throttle control since the throttle of a Yaris is controlled via an electric motor run by the ECM computer.
5). The BD unit is the dealer installed option developed for the Gulf States Toyota distributor, or so BD claims, but is available to the general public via the internet at their site. Some dealers in the USA may be installing it too (???).
6). I was not able to accurately define what Toyota of Canada is installing but they list a dealer installed optional cruise control, as they would not comment on their units maker.
I have decided that the risk is minimal in installing the BD unit as it is a passive device and cannot hurt the ECM computer even if continuously grounded which would only occur with a wiring error on my part. I might add BD was very helpful in my pursuit of information on which to make this decision. The huge Yaris Shop Manual I found on the internet also helped immensely.
LDBennett
My Toyota mechanic friend says the California Yaris Hatchback's have a different computer than cars from different parts of the USA and Canada. They tried to add the cruise control to four different Hatchbacks and none had the progaramming in the ECM computer for that feature and would not work. They even tried the sedan ECM computer in the Hatchback with no luck.
Before doing anything for a crusie control I think it very wise to find a dealer who has successfully installed one! Californians are screwed, again!
LDBennett
This is not about Rostra but about Toyota. Toyota failed to include the software in the California version of the Hatchback Yaris, which the Rostra unit relies on for operation.
The Yaris is a fly-by-wire throttle. That is, you press on a foot control that feeds an electric signal to the computer. The computer then positions the throttle plate at the engine using an electric motor.
The upscale Yaris Sedan has a cruise control and the ECM computer has the programming in it to make the cruise control function work. For the Hatchback in California apparently Toyota chose to exclude the embedded cruise control software precluding any electric cruise control being added (at least in a conventional sense). There is no throttle system at the engine, only the elctric motor, so I don't believe a vacuum motor cruise control can be adapted (??).
While your sister may indeed have a successful Rostra cruise control on her four year old car, the Yaris is only in its second model year and in California, apprently, the yaris Hatchback does not have the ability to have any cruise control, by Rostra or by anyone else that I have found. If the Yaris Hatchback was delevered in the Gulf States of the USA or in Canada then that is not the case as Toyota left the software in those cars.
So you see this is a California Toyota Yaris Hatchback problem , not a Rostra problem.
LDBennett
Rostra responded that they DO NOT use the ECM programming and it is inconsequential that the ECM programming is there or not. The Toyota mechanic friend was using just the Toyota factory cruise control stalk and relying on the ECM cruise control programming to be there and that apparently is why his approach didn't work.
The Rostra unit, according to their latest direct communication (not through BD), taps into the electric foot throttle wiring and has its own computer. The car's ECM does not even know the cruise control is controling the throttle electrically and not the driver's foot. This iscompletely different than what BD told me!
I think it is time to commit! I'll buy the Rostra unit (not through BD if I can help it). At least I got the name and email address of the Rostra Engineering Manager. If I have any problems I'll contact him directly.
LDBennett
http://flyingdragon.4t.com/shiftball.jpg
It actually looks better than I thought it would.
Anyway, you are required to tap into about four wires under the dash: two for brakes, one for the Vehicle Speed Sensor, and one for power. In addition you must route a wire through the firewall to the transmission connector to tap into the Neutral Safety Switch wire. The harness supplied also has a ground lug that has to be run to the body. The power lead includes a fuse for the Cruise Control Unit.
There are two modules, the Cruise Control Module and the Interface Module, with all the required harnessing. The Accelerator Pedal Assembly normally tells the ECM electrically what speed you want. For this system you disconnect the exiting connectors to the pedal assembly and insert the cabling provided. It interrupts the normal pedal signals and inserts the Cruise Control signals when the Cruise Control is on and reverts back to your input when the Cruise Control is off. There is a stalk with the control switches (on/off, set, etc.) that you must mount near the steering wheel (??).
The kit seems very complete and the instructions adequate but the quality of the picture figures leaves a little to be desired. I suppose once you get into it the lost picture detail will be deemed unnecessary (??). My son, a former mechanic, will install it with my help when he gets time. I could do it myself but under the dash work is tough on me at my arthritic age.
I m so sorry about all the confusion. The kit is much as I initially expected (I installed a digital Cruise Control more than 20 years ago on a Nissan) until BD lead me totally astray creating all the confusing about whether the Rostra used the Yaris's ECM Cruise Control programming (which it most definitely does not). I also learned, in a phone conversation with a Rostra sales rep that they have sold about 3500 units for Yaris's with only one known failure (bad switch in stalk). I'll let everyone know when I get it in and working.
LDBennett
My former mechanic son installed the Rostra Cruise Control per the excellent instruction (The instructions need better pictures!) in two hours last evening. No problems.
I took the Yaris out on the freeway today for a little trip for about 1 1/2 hours driving time, on level ground, up one of the steeper grades on the local freeway (Cajon Pass for those of you that know the greater Los Angeles area), and it worked just fine. No complaints.
So even with all the "problems" initially in understanding the unit, caused by Brandon Distributing, I am very satisfied now that it is in and working. Again I bought it through M&R Electronics on the Internet. I recommend them.
This happily ends the pursuit of a cruise control installation in a 2007 Toyota Yaris Hatchback with auto. Bye!
LDBennett
My friend drove my car to my wedding ceremony from the photo shoot and lost my smart key...says she can't find it and won't pay to replace it...I definitely can't afford $250 + for a new one!
Also, on the sedan, if you lock the doors with the key fob and then open the trunk with the key, does the alarm go off?
If you are inside the sedan and lock the doors with the key fob, can you pop the trunk from the release button?
Any help you can give would be appreciated.
I have a toyota yaris Sedan with the spoiler, but i wanna the 4PC KIT (FRONT, SIDES, REAR) i saw that NARISTO have it, bu tis Really EXPENSIVE, so i want to now if someone can send me the specification with dimension and picture of this kit, because i now people in my country that will make it for me for less money and good quality.
Or you can tell me where i can buy it less expensive or maybe who sell me from a used car.
My Yaris is red.
Regards!
