Mazda3 Dashboard and Instrumentation Questions
                    I just bought an 07' 3 "S touring"  and noticed that the digital clock jumped ahead 30 minutes. I didn't touch anything.
Has anyone had this problem and what did you have to do to fix it?
1. Press and hold down CD and AM/FM buttons
2. Start your car while still pressing down on those buttons
3. The display will read, "DIS ON" which means Driver Information System On.
4. Release the CD and AM/FM buttons
5. Turn off and restart the car
6. Now press the Set button and cycle through your avg. mpg, miles until empty, current mpg, and avg mph!
Now you can truly know your Real MPG numbers! Which is a mixed blessing!
Please pass this info to others!
JC
0. Make sure your radio is on and then turn-off the car (Thanks godaddy1)
3. The LCD display will read, "DIS ON" which means Driver Information System On.
JC
cheers
Blake
A few months after I noticed the problem, Mazda issued a service bulletin and provided a revised part to correct the problem. My dealer fixed it within 15 minutes. That particular issue only affected 2006 models built prior to November 2005. It sounds as though your '07 has a similar bug.
It was a little frustrating to me at the time, especially since this was my first non-Honda purchase. After 35k miles and almost two years, there have only been two warranty issues. One was the clock issue and the other was a problem with the adhesive used to secure shift knob on manual tranmsission cars. In hot weather, the knob would twist around and they gladly fixed that in no time as well. The service manager didn't even check the car in to speed me through the process.
Give your dealer a call and let them know what's happening. You may not be the first one to have this issue and they may know exactly how to fix it.
I'll see if it happens again. If it does I'll the dealer a call and have them fix it.
Thanks for replying. Glad to know I'm not aging before my time!....lol
Forgive my ignorance here but I can't seem to locate the "set" button. I just bought an 08 Mazda3 S Touring with the optional 6 CD stereo system. The only "set" button I can see in the whole car is the set button for the cruise control. Am I missing something or did they get smart and delete the set button on the stereo.
Jack
psy
psy
From everything I have read on other Mazda forum sites, the unlock does not work for 2008 models.
~ JC
I have attempted to follow the following instructions and not getting the DIS ON.
1. Turn on radio, then turn off car
2. Press and hold CD and AM/FM buttons (also have tried holding down the “:00” button)
3. Start car while holding down buttons (have used car “on” and also started ignition)
4. Have not received the "DIS ON" prompt, after holding for up to 30 sec
5. Release CD and AM/FM button
6. Press “:00” for 5 sec and cycle thru computer (have not gotten here yet)
7. Turn off and restart car
8. Press and hold for 5 sec “:00” to cycle thru computer
Suggestions/comments?
Tried to hold down the :00 button but nothing happens.
My Mazda 3 07 has no stereo weel control. am i able to unlock my trip computer? i tried the famous steps of holding the cd & AM/FM buttons. but didn't work. No DIS shown.
i would like to confirm something, is AM/FM is 1 or 2 diffrent buttons. in my case they are 2 seperate buttons so in my case i hold the 3 Keys CD, AM, & FM buttons.
waiting for your suggestions.
Many thanx
(Is it related way that the car sense the declined roads)
And I find I'm messing with the contrast, even without sunglasses. At dusk when I turn my lights on, it's still too light out to see the dash, so I turn up the brightness. Then I turn it down again when it's completely dark outside.
One last thing, and I'm done complaining (I really do like my car) - sure wish I could turn the fog lights on without the headlights. I'd like to use them as daytime running lights.
Can someone answer my concerns and explain to me about how the airbag system works in a Mazda3 sedan?
:confuse:
A gallon of milk placed on the seat will also trigger the light, since I assume the seats thinks there's a very light person there and so it turns off the airbag.
Even my wife has made the airbag off light come on by shifting in the seat on a long trip or reclining the seat fully to take a rest while I drive. The sensor in the seat seems fairly sensitive to changes in weight.
Keep an eye on it and I bet you'll find that you're seeing something similar.
I purchased a 2008 MS3 Sport with a single CD player. I was unable to do the 2 button trick to get DIS ON as others have reported. I got on eBay and purchased what was advertised as a '04-'06 single CD Mazda 3 radio from Discount OEM Radios. I knew from the forums that '04-'05 was not going to work. The picture looked like my radio except black faced instead of the metallic color. I risked the purchase because it was only $19.99 plus $16.00 shipping. I received the radio and noted it had a December '05 build date, making it from an '06 model. It was also a 6 CD changer instead of a single CD as advertised and marked on the paperwork. The faceplate was badly scratched as was the display. I removed the damaged faceplate and display, literally a 4 minute job. I removed the original radio from my 2008 MS3 and swapped in the eBay 2006 radio, re-using the 2008 display and faceplate. I powered it up, did the 2 button trick, DIS ON, power down, power up, push :00 (no "SET" button) and now I have a 6 CD changer with the trip computer in my 2008 non-GT MS3 for a $36 investment. This radio seems to have more power than the single CD and the changer works well. So, from this comes another datapoint, the computer that provides the trip computer function resides in the radio and 2006-2008 faceplates and displays are interchangeable. I hope this helps someone else.
-enganear
I just unlocked my 2008 Mazda 3 s Sport Model Trip Computer. It displays in place of the clock.
Follow the directions for the 2007.
When you get Dis On displayed, hold the :00 for 2-5 seconds and check to see if the display changes. If not (mine didn't) Follow the next directions.
Disconnect the negative to the battery.
Wait a minute or 2.
Reconnect the battery.
Turn the car to acc and turn on the radio.
You should have lost your presets and your clock is now wrong.
You will need to do 2 things here.
First of all, so you don't forget, roll your driver side window down all the way and then roll it back up and hold the switch in the up position for at least 2 seconds after. (This turns on the one touch all the way down feature)
Second, hold your :00 button for 2-5seconds and release. When you release, your trip computer should display. To toggle through each option just hit the :00 button. This should stay on for good.
Good Luck, I have been working on getting this working for weeks and only just got it figured out while I was installing my iPod Integration Kit. Enjoy!
I am debating hard whether to get the S Touring with leather/moon or the Grand Touring w/ bose/moon (it's a $1,300 difference and I want to save every penny I can).
Any ideas?
Please drop me a line if you get the chance and let me know how you go this to work.
J
Do you have a 6 cd in-dash? Im starting to think the hack only works for 6 cd in dash units, I have a single.
Let me know if you figured something out,
J
It didnt work the first time, because I didn't leave the negative disconnected long enough. I gave it a minute instead of a few seconds on the 2nd try and it worked.
ACD
