Chevy S10 - GMC S15 and Sonoma Fuel Pump and Fuel System
in Chevrolet
I have a 02 Sonoma crew cab. I am wondering what signs I should be on the watch for if my fuel pump is going? would not start for a whole day, next day started fine.
Sometimes when I turn the key on and start driving,although my tank has gas--either a small amount or full tank--the Fuel guage goes to empty and the fuel gauge light comes on. Then, quickly the light will go off again and on again as long as I am driving. This is happening over a month ago. Now, it is getting a little weird. the guage goes to zero, then climbs back up slowly and then to zero again and so on...
Problem#2
My ABS brake light and Seat belt light comes on while driving and goes off again off and on but nothing appears to be wrong mechanically.
ANY one had this problem who could direct me how to fix this myself or whatever?
Thanks for your help!
ken 38
Turn signals lights work most of the time and sometimes do not. I understand it is a manufacturer problem. Does nayone had this problem and know how to fix this?
Problem # 2
"Trac On" light and several other instrument panel lights come on and stay on for a while and then goes off. All mechanical systems seem to be working fine otherwise.
Anyone knows how to fix this problem?
I bought my 2001 S-10 , 4.3 liters on October 2001.
Over the years I found that I had to accelerate for a long time before the transmission shifted the gears.
Quite recently, August 5, 2007 I found that the gear shifting is smoother after I changed the oil.
Boy, it is more fun to drive my s-10 now. It was a nuisance drivinig before when it was taking a longer time to shift, which i though was normal for the S10 since i bought it.
What might have caused this shifting problem?
Thanks fo yor help!
Ken 38
kcram - Pickups Host
I had problems with the original pump about 3 months ago so i bought a new assembly unit on ebay (i know bad mistake but I'm broke) and replaced it with the new one. Well i seem to have another problem. When i get on the gas and punch it to the floor, The truck will just either bog down and backfire or just stay at the speed i gas heavy at. But when i slowly get on the accelerator it will get up to speed fine. I've changed the fuel filter to see if it could have been the problem but it still happens. Could i be looking at another bad fuel pump or is it something else?
Can someone help?
Brian
My S10 is a 2000 v6 2wd vin# "W" for what its worth.
I hooked 12 volts directly to it, and it pumped fuel but still wouldn't crank.The relay has 12 volts, I switched the relay with another one and still have 5.1 volts. I read that they have a oil pressure fuel cutoff switch. my oil pressure is good but it could be malfunctioning. My Haynes manual doesnt show the location of the oil pressure fuel cutoff switch. so I have no idea where to look. any help would be great thanks, Curt
Thanks, Dan
