Saab 9-5 Maintenance and Repair
I have a 1999 Saab 95, auto, 4 cylinder. I believe the fuel pump is going out. The car will sometimes stall at a stop light and when I stepped on the gas hard it sound/feels like it's stalling but gets going again!! I already checked the fuse, what else can it be? The car has of 100k on it and it's the original fuel pump.
--Jim
Thx
Also the speedometer is not working, is this related to the brake light issue?
My 95 SE wagon sat for a year, outside, in the northeast.
Started fine with a brief jump, but the left rear wheel is siezed. Tried flat-towing it a few feet in neutral to break it loose. Ploughed a furrow in my gravel driveway.
EBrake handle is in disengaged position.
Car goes in and out of first and reverse (auto) just fine. But in first it goes nowhere much. In reverse it just sort of climbs up on the rear wheel.
Pulled the wheel off. used chemical rust remover, then cleaned and lubed liberally. poked, prodded and pounded on sturdy parts of caliper assembly. Outboard pad is not siezed to rotor as I can easily wiggle it with a big screwdriver. Inboard harder to futz with without disassembly.
I'm about to head out and pull the caliper on that corner, or try anyway.
Meanwhile I'm wondering if the trouble might be eBrake rather than brake? And if so what to look for, do? Or something else altogether?
Thanks so much.
