Chrysler Pacifica Brake Issues
luscombe1310
Member Posts: 1
in Chrysler
Hi Everyone:
This is my first post.
I purchased my 2005 AWD Pacifica on Dec 28 04.
My odometer reads 11,000 miles as today.
My rotor is bad I called local dealer they said Chrysler only cover this part in the first year regardless the mileages I have.
I had the front repaired last Fri. and mechanic said my rear was even worst than the front one.
Now I am waiting the rear rotor and brake to be arrived tomorrow.
The local dealership told me I can make a complaint to head quarter's customer service.
I called them this morning and they said I should go to dealership to have my car diagnosis and they will tell me will they knowledge the cost of repair or not and no guaranteed they would. This option is too late for me because I had friend fixing the problem for me.
I called my salesperson this morning (I had purchased and lease 6 different Chrysler cars from him since 92).
He gave me a hint that it seems around 04-05 Pacifica have brake issue.
I would like to know does anyone have the same experience like my 05 AWD Pacifica?
Any input will help. Thanks in advance!
I have a 2006 Pacifica it has about 38000 miles on. my husband uses it to commute. About 2 weeks ago we noticed the brakes were grinding a little when we first started braking but only while going slow. Then the brake light on the dash started to go off about the same time grinding noise started. So my husband decided to do the brakes. Well when the pads were pulled off I still have about 50% of the pad left. So I;m trying to see of anyone has had this same problem and if so what was the out come. Considering the warranty is now out I'm not sure what to do.
Also the on some occasions the ABS will start working when I am braking at slow speed for no
apparent reason (with the ABS light Off) then a few seconds later the ABS light comes on. Has anyone had this problem or know what might be causing this problem?
Thanks for any info.
