Kia Sorento Lights and Bulbs
in Kia
The right main beam of my 06 sorento blew at 30K miles ... I run them all the time, so this is not bad. I bought a replacement bulb ... how do I install? thanks. Ken
1.Remove one bolt from top and two bolts from front of headlight housing.
2.Pull housing forward ... you have to push from behind with moderate pressure and some wiggling is required. It will only come out 6/8 inches or so with the wires attached, so you have to hold it and work at the same time. Have someone help to make it easy.
3. Unscrew the cap directly behing bulb. 1/4 turn counter clockwise.
4. Pull off the electrical connector ... straight back. Look the back of the bulb and the metal bulb base ... and remember how it is aligned ... this will make reinstaling easy.
5. A metal 'V' shaped wire spring holds the bulb in place. The wide end is a pivot, do not unscrew. Loosen the screw on the other side so you can slide the spring wire out from under the metal tab. Pivot the spring up and remove the bulb ... the bulb has a very loose fit when the spring tension is off.
6. Install the new bulb ... do not touch the glass ... tabs on the bulb metal base stick out and will make sure it is flush and in the right position. It only fits flush in one position. The fit is very loose, so you have to make sure the bulb does not fall out.
7. With the bulb in position, rotate the metal spring so it holds the bulb and slide the end of the spring wire under the metal clip. This is the hard part. You may have to loosen the clip hold-down screw a little more (don't remove completely) ... and/or use a small screwdriver to hold the clip up. Tighten the clip screw.
8. Reinstall the cap on the housing behind the bulb.
9. Slide the headlight housing back in with a little pressure and wiggling ... it should go fairly easily.
10. Reinstall the three bolts.
You should be good to go !!! The dealer will charge $40 for this!
Smitdog
I have a Kia Sorento EX 2005 and I am experiencing problems with the light system. A few weeks ago; I changed both headlights as a precautionary step after noticing one died. The other day I noticed the same light failed. Usually I would not think too much of it but the vehicle stoplights do not work, and the overhead light assembly in the interior of the vehicle only works in "on" and not in "door" position. I decided to take the vehicle to the dealer and they first claimed that bulbs are not part of the warranty. I explained the service rep that I have a hunch that the electrical system and not the lights are the cause of the problem. Her response was that the vehicle has 43K miles and the warranty on covers for this type of problems up to 36K. I read the manual and it seems the warranty should cover up to 60K. Please advice.
Here's a website that will take you to some links to find that mirror - http://sorentosite.com/links.htm. Sorry, you'll have to look through them till you find what you like.
To install the mirrors you purchased, go to http://sorentosite.com/diy.htm for do-it-yourself instructions if you're handy,
Vic
My problem is how to fix the lights. They will turn on if I hit the top of the shifter cover 5 or 6 times, but they do not stay on when I shut the car off and back on again. The back of the shifter dust cover is broken off and I can feel down inside with 2 fingers the light wire under the light assembly, but it feels tight. I cannot figure out how to get the shifter cover off to see if the connector I cannot reach is tight or not.
Dave
We unhooked the trailer hitch (wiring part) and a few minutes later all the lights came on, even my fog lights worked up front.
Is the hitch wiring causing this?? If so, what can I do?? I did have it installed professionally.
GCANNING
I got Kia Corporate involved awhile back. They supposedly was going to have a gentleman from corporate fly in from Chicago that was bringing a wiring harness with him to see if that was the problem. Well, when it came time for me to take my car to the dealer, the man from Chicago wasn't there and the dealer told me they sent it FedEx. Two weeks later...another headlight and fog light went out! I took it back again and believe it or not..the dealership tried to tell me that this is typical of headlights to do this! Not once did they come up with a remedy for what was blowing these lights. I went round and round with them. I actually was told by an insider of the dealership that when they put my name in the computer, it flashes accross the screen"DO NOT SERVICE THIS VEHICHLE". Keep in mind, I purchased this vehichle New from them, with a 10yr., 100,000 mile warranty plus a bumper to bumper warranty for the same! When I finally got a chance to talk to the owner of the dealership, He told me and I quote" When JD Powers called you, you did not give my men in service all 10's and when they do not get 10's, they do not get their bonuses and that tends to make them mad!" I say that if they don't do their job...they don't deserve the bonuses just like everyone else! Needless to say, Kia Corporate acted like they were going to help me with the problem but they did nothing but side for the dealer as to there being no problem with my vehicle...I got no where with Kia Corporate! I am at 108,000 miles on my Kia and this all started at approx. 20,000 miles. I just replaced another headlight and brake light this week. I also had and still have a problem with the lights coming on by themself and the doors locking by themself.....something else they never fixed! I probably can't do anything more about it now but if anyboby has had this problem I wish you would let me know! And by the way....Kia told me that they never had this problem with any other Sorento! I see the Sorento's passing me all the time with the headlight out!!!!!!!
There is a diode located in the dome light circuit (door only positio). It is not in there factory wiring diagram and is just as hard to find in the parts catolog.kia part number 9138a-3e000 should take care of that issue. It is taped into the wire harness under the lower left kick panel (by the fuse box).
56000 Miles, bought new in October '05. I just installed my third battery. When they die, they just die, no warning whatsoever. Turn the key, snapping/cracking sound, dead battery. Yesterday I noticed the battery was still very warm even after 3 or 4 hours out of the vehicle, this was a Bosch that I purchased in November '08. I am pretty sure the batteries are shorting out internally.
Also, my headlights and tailights have been popping since about 6 months after buying it. I gave up on the dealer a long time ago. I love the vehicle so I just deal with it.
Also, a third issue. My brake rotors have now been turned on the lathe 3 times in 56k miles. They keep warping. I have never had to have this done this many times on ANY other vehicle I have owned in 25 years.
So, lets see...
Replaced more batteries
Replaced more bulbs
and turned more rotors... than on any vehicle I have EVER owned.. but I still LOVE this SUV.. What is wrong with me???
Rotors....yes the OEM ones are lousy....replace with aftermarket ones when you can...and dont overtighten the lugs....they should be hand tighten to the proper specs
Sorie finally gave out after 5 years and 115k when the front differential let go and eveloped a coolant leak at a y joint that required the motor to be lifted in order to access the part for replacement ($30 for the part and 5 hours labor alone)....approx $4500 to replace the differential .....car wasnt worth that much so donated it........I enjoyed it while it lasted...but not convinced the drivetrains are built to sustain long term wear and tear.......
I lost mine while changing the lightbulb. Kia does not sell this part on its own, but only by buying the entire headlight assembly (~$150-200). Has anyone had to replace the spring only and found a place to buy them?
This problem should be taken up by the NTSB because what happens when one brake light fails, then before you get it replaced...the other fails??? Yes, somebody slams into you from behind under many circumstances. Kia has blood on their hands somewhere; I can't imagine that it has not happened yet.
Has anyone had a dealer repair the problem yet? :mad:
Its a Kia campaign. Possibly you should check with your dealer before getting theatrical?
--Frank
as far as the headlamps being faded, depends on where you are...and if the vehicle is parked outside all the time....the lamps can be buffed out...with products at most auto parts stores
The odd thing about all this is that there is a Sorento model in the US but not in Canada which has both sensors and backup mirror.
I would be most grateful if anyone can supply me with any details about how to install the sensors which only need linking to a wire leading to the tail lamps. Additional information about how I can lead the wires from thee sensors to the tail lamp would be most useful.
TIA.
so what reason did they give for not honoring warranty if you provide oil change receipts and hard it serviced at the appropriate intervals for those items effecting the drive train.....almost 150K on my Sorie...and have been taking it to a independent mechanic for many years now....
:mad:
Headlights and brake lights that continually need to be replaced is certainly a safety issue as well as interior lights that won't go out when using your headlights.
make the complaints and make kia give back to us liitle people that they clearly do not care about and make our vehicles safe to drive.
The NTHSA needs to know, but I recall no finding a method to report it on their web site. It is a safety item.
mike.spangler@sbcglobal.net
Report Your Safety Complaint
Thank you, Brian
