Mitsubishi Outlander Steering Stability and Suspension
I've got an LS with the 16" tires and I like them because it gives a bit more sidewall
when falling into a pothole. Living in NY, the narrower, taller tires are also a more practical choice for a CUV and a little bit better for winter traction (not as much as a better tread though). I'm really amazed how the trend has gone towards 20" and beyond over the past few years. (Fine for a show car, but toss those rims in the trash at the first pothole)
This plus sizing gains sharper tire turning response at the expense of ride comfort (suspension should take into effect less sidewall cushioning so going to large rims tires may feel harsh over bumps if the car wasn't already designed for that) In a CUV I'd prefer the ability to take bumps over sharper steering response. (sports car is another animal all together)
http://www.discounttire.com/images/plusSizingGraphic.gif
Tell me how this SUV fairs after the first large pothole!!! ;-)
http://image.sporttruck.com/f/14376998/0511st_04_z+truck_wheels_and_tires_plus_s- izing+cadillac_escalade_26s.jpg
I didn't check my Outlanders tire pressure until it was about 6 months old, it was about 45 psi then. I didn't lower the pressure because it was riding fine. Now I have pretty good wear on the center of the tire with about 23K on the car.
A cargo load of about the weight of 3 adult passengers usually drops the rear suspension of my XLS AWD for about 2-3 inches. The self levelled xenon light didn’t react to this weight accordingly (as the brochure says).
I adventured with this car to Alaska (Dead Horse) and indeed I kept an average speed in not paved road of about 50 miles per hour. The XLS was very good, socked the bumps, mud, and stones pretty well.
How do you know that? You mean to say the auto-levelling in the Outlander does not work as described?
My headlamps was pointing to the trees or above the traffic signal on the road. This only happen when the car was loaded.
