Mitsubishi Outlander Steering Stability and Suspension
I hope this helps.
http://www.mitsubishiforum.com/m_114144/tm.htm
You, Your Vehicle and the Technical Service Bulletin (TSB)
Please let us know how you make out Thursday with your dealer.
I really, really like this car despite this annoyance. I haven't seen any others on the road yet and it's been weeks. I hope that's not a bad sign. BTW, at the dealer tonight they had a bright cherry red (non-metallic) Outlander which I hadn't seen before.
I only hope that this is the ABS popping noise as it happens only when I start the car and drive off. But I dont understand why ABS will make that clunk and it just does not give me enough confidence in this vehicle.. a mitsubishi nonetheless.
First the door mirror rattle and second this popping/clunking noise. Two strikes in my mind. Especially considering that this is made in japan etc.. You'd figure that since it has been out for long in japan (granted its 4 cyl cvt), they'd figure this out.
Its not the seriousness of these I am concerned about. Sure rattle was fixed and popping noise could be harmless though jury is still out on that. Its just that right out of the gate, I didnt expect to take a brand new vehicle into a dealership service dept which is not a very friendly one to begin with. Its a hassle and doesnt bode well for the future. Perhaps Toyota and Honda owners may have gone thru this type of stuff before but mitsu lost a good chance of making a strong first impression.
But on the way home from the dealer, when driving over some back roads with some imperfections, I drove over some repaired concrete road areas and when driving over the raised areas of repair, there seemed to be almost no shock absorption at all! It was very, VERY jarring, and very unexpected. Somehow, my 15 mile test drive early just didn't go over any imperfections of this type, and I never noticed an issue in the LS model I test drove the previous week.
I have recently owned a Toyota Highlander and Toyota Matrix and have test driven a Lexus RX350. I know those are "cushy feel" suspensions. But I also have test driven the Acura RDX, Maxda CX-7, and the Outlander and know those have a "sport suspension", are "more taut" and "more firm", and therefore going over imperfections will be clearly more noticed and more jarring.
But this was just TOO severe -- it was clearly far beyond anything I experienced in the Acura RDX test drive and Mazda CX-7 test drive which went over some imperfect roads.
And yes -- the tire pressure was checked and is 30 psi for all four tires.
Has anyone found the new Outlander to have a bit too harsh of a suspension? Is there anything that can be done to soften it slightly?
Bud H
Suspension
* Independent MacPherson Strut Front Suspension With Coil Springs, Shock Absorbers and Sport Ride Type
* Independent Multi-Link Rear Suspension With Coil Springs, Shock Absorbers and Sport Ride Type
* 20-mm Rear Stabilizer Bar
You can blame these "taut" suspensions on autorags and sites such as edmunds themselves. They keep harping on makers to make these crazy tuner suspensions. Toyota is by far the only maker who seemed to resist. Well even Buick succumbed a little.
My only regret in my XLS is that I didnt do enough homework. Sometimes, the suspension gives me "Should've bought that camry" :sick: feeling
Which dealership did you go to? There is a US TSB available and they should have a Canadian one as well by now. I did not have the front clunk in my Outlander as mine was a later build (mid-January). I had the mirror wind rattle, but I fixed that myself and now I enjoy a quiet ride.
I didn't notice the ABS popping sound in mine, nor any other weird noise. I drove many times with the radio off and my ears wide open just listening for unusual sounds, but I could not hear anything so far. I will try again.
It did it again while backing into my garage. I can't believe that MMNA cannot properly fix this stupid thing. Looks like another day wasted at the dealer.
Be warned!
Thanks for the help. This is a great forum!!
http://outieclub.com/viewtopic.php?p=194#p194
It is so good to be able to go into a dealership and have this kind of information. I have a month or two before I am ready to start negotiating so I hope to be well informed by then.
Thanks again.
I will keep monitoring it but as for now I never hear it anymore in normal driving...I have 5000 City miles on it.
I figure if there is a problem in the future, it will be covered by the great warranty.. I don't want my front end taken apart for a minor noise unless it is a safety item, which this bearing deal is not..
Other than that, the SUV is quite an amazing performer for the price..!
good luck!
SUVs and Smart Shopper
Does anyone else have any similar experiences? The dealer said they can't find a problem - they call it torque steer. It seems more dangerous than that. Never had this much "torque steer" on any other car.
Thought this forum would be a good way to inquire if an intermittent "issue" I am getting is shared with any of my fellow Outie owners.
I have an '08 XLS (CDN model) and when engaging from the park to drive, or from drive to park we had on several occassions experience a clucking noise + a sudden surge (forward or backward). Good thing I normally cover my brakes in any event. Has anyone experience this?
I took it to my dealer and they we really good about it and even search for any info / TSB's and found none.
Not 100% sure if this inquiry is related to the previous "clunking" posts that I see in '07 but thought to inquire here for owners with the 2008 version.
So far I'm lovin' my Outtie especially with the 650 thumping beat of power
I have been told that I may buy some damper called “progressive dampers” that become stronger when the car’s load increases. If this is true what brand of suspension/damper are on the market? Is there a Mitsubishi suspension/damper (progressive) that can be ordered from my dealership?
I'm hoping that someone will post a fix that is how can the suspension be eased off. This is not a lancer or a LeMans racing vehicle but that's exactly what it feels like and with the high center of gravity it sometimes bounces around.
The other thing that really makes it a difficult vehicle is the cross-wind effects. With the high profile it really kicks around a lot.
Someone mentioned lowering the tire pressure which helped a little but not totally.
There should be a way to soften the ride.
firmer dampers would help, but i've yet to find one.
While inspecting the Outlander for the occasional damages to the underneath I found out that the rear suspension design is that the shock absorber is outside the coil spring and both rest in independent bases. I suspect that this is an old rear suspension design.
Going to Japanese Outlander (year 2008) information sold in Japan the rear suspension assemblage seems to be more modern technology, I think, because the shock absorber is inside the coil spring and both rest in only one base. This layout is very similar to what is called Macpherson suspension usually located in the front of the car (see attached).
Could someone elaborate on this finding or are we being sold substandard suspension outlanders in the USA?
http://www.carspace.com/batman47/Albums/batman47%27s%20Album/outlander08-suspens- ion.jpg/page/photo.html#pic
I too have noticed the discrepancy in the Outlander’s rear suspension from what you see in the brochures, and what you get in the actual vehicles. After a recent test drive, I saw a bit of the spare tire below the rear bumper, and I wanted to verify if it was a full size spare or the thinner space saver type. As I was down there I noticed that on this 2009 V6 XLS the shock absorber was beside the spring just like yours. I asked the sales manager if this is the suspension type in the fully loaded Outlanders., and if they’ve been that way since 2008. His answer was yes to both, but had no answer to why it does not look like the one in the brochures for both 2008,and 2009.
I then went to another dealer on my way to work, and spoke with the service department staff, and they said that the Outlander is a “WORLD” car. That the models we receive here in N.A are the same as what they get in Japan, and the rest of the world. So I asked why again does the suspension in the actual V6 equipped model not match the brochure, and their best answer was that “different models have different suspensions”. This dealer had a much larger inventory of Outlanders, so I took a quick peak at a few models and voila I saw the different types.
It seems that the 4 cylinder AWD model has the rear suspension that is displayed in the brochures, with the spring/shock being one unit. Once you go to the V6 AWD model you get the other type. Now I must admit that I did this quickly as I was doing this on my way to work.
I couldn’t verify 100% that the suspension that we see in the brochures is the one that I saw under a few 4 cylinder AWD models, but I can confirm that it has the spring/shock as one unit. I pointed out my findings to the service staff, and they seemed to act like they knew that all along, and confirmed that the rear suspension in the V6 AWD is “Sport Tuned” and is going to give a stiffer/rougher ride then the 4 cylinder AWD rear suspension.
The same diagram we are referring to is much larger in the 2008 brochure than in the 2009, and if you look at it closely you can tell that the V6 engine is actually a drawing superimposed onto a real picture of a suspension. What that suspension was from is still a question to me. It looks more sophisticated like it has a wishbone type rear suspension. A suspension I still have to verify exists in any Outlander model.
