- For the earlier post about 5 speed gearing: Raise the 5th gear if you like, but leave that 1st gear nice and low. It's great for getting out of tough spots and makes for good acceleration when you really need it.
Juice - Thanks for the info on the Goodyears. I hadn't read that. I've been to tirerack.com (which is where I read about the Aquatreds), but I'll also check that other site. I'll also gotten decent reponses about Mich X1's. I'm a bit concerned about snow performance with those.
Plus one on the rim would be nice, but, if I were going to spend that kind of money, I would get a set of steelies and mount snow tires on them. Then I can get the GTs for Spring/Summer/Fall and put the Winter treads on for snowy months and off-road trips.
> exactly do you roll over a sedan that was rated
> the least likely to roll over?
least likely to roll over doesn't mean impossible to roll over.
Consider what might have happened had you been in a Suzuki Samurai...can you say "cartwheel"?
My Forester came with the same Desert Duelers offered on the CR-V, same size even, and they were a relatively loud tire. After my tire swap road noise diminished.
I recall C&D tested a CR-V when it got the power boost in '99, and the tires were BF Goodrich. The thing was a full 3 dB quieter at highway speeds. What a difference tires can make.
varmit: my buddy Hutch also checked the Tire Rack surveys, but I guess the tires had not been out long enough for those problems to creep up.
-juice
I'll check around about the Aquatreds. In the meantime, I'll start looking at the alternatives.
varmit: My set of Bridgestone Dueler H/Ls from The Tire Rack should be installed by the end of the week. I'll be sure to let you know how I like 'em. So far, this is looking like a great deal. Even after paying for local mounting/balance, getting this new rubber through Tire Rack will save me more than $100 versus the local tire stores.
It's very interesting to consider Honda's factory tires for the CR-V. The Tire Rack classifies the Bridgestone Dueler H/T as a "Highway All-Season" tire for trucks, while the BF Goodrich Touring T/A falls under the "Standard Touring" category for passenger cars -- truly a reflection of the truck/car line straddled by vehicles in this class.
My choice of the H/Ls was based mostly on positive commentary from The Tire Rack and Consumer Reports. Plus, CRVIX founder Bing runs with these tires, satisfied with their performance and treadwear even after 45,000 miles. However, if I was never planning on leaving the pavement again, a passenger-car tire like Michelin X-Ones would have probably topped my list.
Oh, and in case anyone is wondering when they should start looking for new tires, let me illustrate:
i know, drive slower :P
maybe time for stabilizer bars or something?
Steve
Anyway, if the UTQG ratings are accurate, the Dueler H/Ls should have roughly 2.5x the treadwear of these ratty ol' H/Ts, which means I should be able to look forward to 75,000 miles on the new tires.
GatorGreg recommended the Michelin X-Ones and I've seen positive reviews, but, like yourself, I do head off-road from time to time and (unlike you) I need good snow traction. In order, my priorities are traction, noise, and then tread wear as the least important. The trouble is, good all-weather traction and less noise seem to exclude one another.
Like yourself, I was only doing a four tire rotation. I let the dealer do it the first few times and that's the pattern they started. Now I have a brand new tire on one rear corner, while the rest have 53K on them. If it were possible to repair the punctured one, I'd consider that. The boyz at the dealer said they still have another 10K left in them. Since the snow is starting to fall, it's probably best to replace them now.
Those tires look mighty familiar! Mine lasted 28k miles, also with very spirited driving. Wear was nice and even, so your alignment is good.
They are rated 180BB, which means not very long lasting tread, B for heat resistance, B for wet braking. Overall, not so good, but it's a truck tire and that's the compromises it comes with.
I did a plus one, but my new tires are 460AA. Substantially longer tread life, A for heat and A for wet braking. Sure enough, 15k miles and they still look brand new, and they handle nicely. They are not a good tire for snowy climates though (Nitto NT460).
varmit: you sure it's OK for the RT4WD to drive with tires that have a different diamter? I'd get 4 new ones ASAP, or try to find one used tire that matches the other 3 more closely.
-juice
-juice
If true, then they are aggresssively pricing them and liitle room to negotiate in my opinion.
-juice
1400 or 1500 over cost. Not bad for car in limited supply with ggod demand.
-juice
remote entry, aluminum wheels was about 28K.
A big difference (23%) over 22.7K.
The highlander is defintaley bigger looking from the outside and a little more plush in my opinion, but interior volume is very comparable, especially the back seat where the CRV has much more leg room.
Head room about the same and hip room better in Highlander.
Cargo in Highalnder a little bigger.
Overall I found it hard to justify the +5K price difference so I bought the CRV.
I've seen photos of both side-to-side vs. stock, and even used the Hellas for a year. They are slightly brighter. The catch is both lasted less than a year, compared to 5 years or longer for a stock halogen bulb. To me it wasn't worth it to keep replacing them.
You can go to a higher wattage bulb (80-100 watts), but then it's no longer street legal. I've heard they also do not last as long, because they run hotter.
-juice
But purely in terms of passenger space the CR-V can hold its own.
-juice
That's why the highlander seems more plush than the CR-V. On and off the road the Highlander is smoother, more powerful, and more refined than the CR-V, but you pay for those attributes with your checkbook.
It's all up to you. The CR-V meets the same basic needs/wants as the Highlander, but the Highlander will be more sophisticated. It depends on what you want and how much you're willing to pay for it.
Ty
It is Camry based, and fairly wide for 3-across seating. The platform was used for the RX300, so it is refined, but the pricing is definitely on the high end. Toyota just moved up to a 5/60 powertrain warranty last year, too. I hope Honda matches it.
AN had a little snippet on the Pilot, and said price would be in the $25k-30k range. I hope that's true, and we don't see a $29,999 base price on a 2WD stripped model. It's a bit boxy but seems like it'll be extremely practical.
Honda sent Toyota back to the drawing board for the Sienna after Odyssey demand was so much higher, so Pilot may do the same for Highlander.
But in terms of size it does seem like the CR-V is half way between the RAV4 and Highlander, maybe even closer to the latter.
-juice
Hey by the way, I was wondering what the point of the CRV is anyway? Is like the apple jacks don't taste like apples? I mean the CRV can't tow anything, has limited cargo space, only comes with a 4 cyllinder, can't really off road (they even say it in their commercials), and really there are so many better choices out there why would you ever get anything like the CRV?
The Aztek... LOL
I actually read a review of the RAV4 and it was not very complimentary at all. RAV isn't anywhere near as good as even the old CR-V.
Steve
What class does the Aztek fall under? It's too big to be a small (formerly known as "mini") SUV. It's certainly heavy enough to compete with the Pilot, Highlander and JGC. It slurps fuel well enough to compete with most mid-sized utes. But I do agree that they are cheap.
Which brings us to the fact that they are "cheap" in more than one sense of the word. The fact that Aztek owners have built a fanatical defense around their odd-ball choice is really no surprize. And I don't blame them. It is a very functional vehicle. But that has nothing to do with mechanical quality or reliability. A "most appealing" survey tells us about the owners, not the vehicles.
As for safety, penetration of the safety cage is a bad thing and the lack of it is an important safety feature. But it doesn't do a lot of good if the person goes splat on the inside of that cage.
I test drove a Rendezvous and the engine is coarse and unrefined. I've also rented a Montana and was not impressed at all. Top that off with poor reliability, awful resale, and bad crash test results. Usually, if she's ugly at least she has a personality...
llofgren is spot-on about reliability, but I would add Nissan to his list. The top 7 nameplates, per CR, are Toyota, Honda, Nissan, and Subaru. Plus Lexus/Infiniti/Acura, but IMO those are redundant.
JD Power APEAL study does not say anything about quality. In fact, that's why they created it.
-juice
Darn it! You guys are right! GM is behind Honda!
Oh ya but they are ahead of everbody else! Honda is 2nd and GM is 3rd. Look out Honda!!
Steve
http://www.jdpa.com/studies/pressrelease.asp?StudyID=585&CatID=1
Only Jaguar and Lincoln placed ahead of Honda/Acura...and they belong to Ford, not GM.
"Infiniti ranks second with 219 PP100, followed by Jaguar (250 PP100), Lincoln (253 PP100) and Acura (255 PP100). Honda and Toyota tie at 278 PP100 to rank highest among non-luxury nameplates."
rofl!
Tom
