Chevy S10 - GMC S15 and Sonoma Vibrations
Wow. 03 4.3l v6, xcab sls.
I have had a vibration for the past year. Seems like the past few weeks it is getting worse. I took it today to get the wheels balanced, but nope, still there. Now it is accomponied by a rattling noise under the truck, which maybe totally coincidental.
Seems that the vibration really kicks in at 20-22 mph, then levels, and then again at around 40-42 mph.
When I purchased this vehicle used w/48,000 miles, it had been lowered a bit. I noticed this "vibration" and took it back to the dealership, which they replaced the driveshaft. But, it never really helped.
Has anyone else dealt with this issue?
1
My gf's stepfather looked at it today (he works in service at a GM dealership). When he drove it, he immediatly said CV Joint. The loud vibration, and I mean, loud as in, I have to turn up my stereo LOUDER to hear it, and my rear view mirror vibrates, is coming from under the seats/floorboard area. From what I can tell, there is a double u-joint in the middle. It has to be the CV/driveshaft. I do not know what else it could be! I know its not transmission or tires, so that leaves only this. Any thoughts? :sick:
What was found was a couple of items:
1. The center support bracket was not a match. It was put on "elsewhere", and much thinner than stock.
2. Slight bend in rear shaft.
(ujoints ok, nothing major)
3. Sorry if I do not know the name of this, but the part that comes out of the transfer case in the rear, that bolts up to the rear driveshaft, was stripped, and needs to be replaced.
4. also a seal where the front driveline meets up to the transmission is bad and needs replaced.
I get it back tommorow, hopefully this takes care of it.
Pre loosen all plug wires, start it up and lift off each wire from the plug to see if RPM drops.
If RPM does not drop, there is your dead plug, wire, or bad valve.
As the engine warms, the valve may make a better seal, as it does when revved up.
Swap out the wire to a different plug to see if condition follows it.
An OHM meter will verify the wire.
A compression test will verify valve, even better is a Leak Down Tester. This tool will show you where the air is leaking from when both valves are closed.
The air will escape out 3 possibilities, the oil fill - Bad Rings, the exhaust pipe - bad valve, or the intake at the throttle - Bad Valve.
This tool requires an air compressor and piston at top dead center on compression stroke.
You didn't mention how many miles.
Mine has 177,000 and does not burn any oil and runs perfect.
That's from being very fussy about it all like racing.
it has a bad vibration in all speeds
i checked the U joints and they seem tight to me
and it has a fresh tranny rebuild
i raised the rear of the truck to check the rear end
on the passenger side of the truck i can grab the tire and it moves in and out anywhere from an eighth to a quarter inch
the drivers side is tight
Does this mean the axle bearing on the inside needs replaced and could this be the cause of the vibration?
I would suspect where they connect, most logical is at the switch. If the pressure switch has one wire on one side and 2 wires on the other, the 2 is the connection. If not, good luck looking.
The pressure switch has nothing to do with your current problem except the 2 wire connection.
anyone else have a prob like this ??
anybody know the answers to the problems
anything helps....really annoying...fed up with it...suggestions please
its a 1993 sonoma with a 4.3L, automatic
Phil
Do you think that if I raised up the differential off the ground and ran the car at 70 MPH that I could possibly find the source of the problem?
Thanks for your helpful advice.
Phil
Those shafts are balanced as one. When I put the new one back in my truck I had to make sure I splined it up with the bench marks the shop put on it. Otherwise it would have thrown off the balance.
I have seen in some cases where the spot weld gave way and one of the weights came off.
So far you've indicated:
New drive shaft and balanced twice.
Pinion bearing in good shape.
Tires and wheels in good shape.
Could it have a broken leaf spring or spring mounts come loose some how?
Have you had your truck high centered on a tree stump or something?
If you're going to do the 70mph thing please be careful.
Let us know what you find out.
Phil
I just signed up only because of your post. I wager I know for certain what your problem is--and it is the same for problem all S-10/Sonoma extended cab pickup trucks: The drivetrain is mis-aligned. This is a factory/engineering defect, which GM has failed to rectify. This problem really manifests itself in the Extreme pickups.
I had the same $1000.00 + problem and, after finding on my own the GM Service Bulletin which instructs dealers to grease the centering ball in each of the two "Double Cardan" constant velocity joints on a regular basis (a bandaid fix is all this is), I stumbled on this site http://www.jagsthatrun.com/Pages/Parts_S10-Driveshaft-Align.html which shed all the light I needed to resolve the problem.
My truck is a 2000 S-10 Extreme, and installing just the transmission mount spacer and center bearing spacer, I solved all my problems. I have yet to install the shims between the axle and leaf springs; but I need only to grease the two centering balls in the joints every other oil/filter change, and I have had no noise, no breakaway (accelerating from a complete stop) shudder, and no vibration.
Now if only the dealer will accept responsibility for terminally damaging my perfectly good 4.3 with poor work practices, and replace same, I would not be in such a foul mood.
Sigh.
Meanwhile, go to that site, order that kit (or fabricate it yourself--your choice) and grab your tools, and you will no longer have these problems--especially the "howling"sounds that emanate when that centering ball dries up and gets stressed because of the misalignment.
Does the dealer recommend the spacer you installed?
Phil
Phil
i couldnt figure it out either basically no one could. it wasnt until the guy who worked on my truck spoke to the driveshaft place. the guy who worked on my truck couldnt. dont know it the problem will solve everybodys but i have the two piece driveshaft. the yolks were bad so t hey couldnt balance it. they suggested the one piece. i drove it down the interstate last night at 70 and had no noise or vibration. ive been putting up with it for about five months
dave
It appears that a previous owner had put a lift kit on the truck then took it back off before I got it some brackets had been welded onto the frame at the suspension mounting areas but have been removed. That is probably the reason for the extra long drive shaft originally in the truck when I got it. We dropped the rear leaf springs when we originally replaced the differential and didn't notice how tight the drive shaft was any ideas or help would be appreciated
Phil
