Chevy Suburban Electrical Dies While Driving and Stalls
I have a 2003 Suburban LT and it has started to die while driving and the Air Conditioner stops blowing cold air and the air gets hot as if the A/C weren't on. I have replaced the battery and have had the alternator checked, it's not the battery or the alternator, does someone know what it might be? I have a teenage daughter that uses this car and I would hate for it to break down while she is driving. Please help me someone. Thanks so much
See Also
Diagnose Engine Stalls
See Also
Does the engine cut off abruptly? Do you hear any noise? Feel any vibrations, jerky motion? Do you see a change in the exhaust?
SUVs and Smart Shopper
This doesn't explain why the car won't start after sitting 10 hours with less than a half tank of fuel and will start if the tank is banged on the bottom. I've done this for at least a year and a half and it works every time if you have some fuel. Possibly related is a recall I received for an instrument panel voltage problem. It causes gauges to read inaccuratly. Our fuel gauge level jumps a quarter tank at times. I wonder if the pump could be programmed to shut off with no fuel indication either to prevent burnout or to keep air out of fuel lines.
Fuel filter replaced this weekend - drove fine - for awhile. I found much debris in old filter - could new filter already be plugged-up? Should fuel pump be checked/cleaned/replaced? Electical seems okay (wires, battery, etc.)
Please help with any advice you all might be able to offer. Thanks!
Then, it drove just fine with no problems day after day for a week or so. Then, out of nowhere again, the tac started going crazy and the think started bucking and lurching with my foot on the brake. This "behavior" has happened just after it is started, it happens after it's been running for 20 + minutes without any prior problem, there is no rhyme or reason to it. I can start it and it will run in the driveway for 30 minutes with no problems or I can start it on another day and it wont stay running!
It isn't the fuel pump, or the battery.
Also, every once in a while when it is having this problem when it shuts off and I go to restart it, it acts as if it isn't going to start. I will have to turn it over several times, and then it will just start.
Please, if anyone has ANY ideas I would be thankful. This is my main vehicle (the only one our entire family can fit in) and I have four children with me constantly.....it broke down on me on the INTERSTATE with them all in it. Obviously, I lose my power steering and my brakes don't work right when it happens.......it is EXTREMELY hard to control when it cuts off while I'm driving 65 mph! We've pretty much been house bound (no trips to the doctor because it's 30 minutes away) since this problem began.
My mechanic cannot seem to get a code on this problem. It has shut off before and I've just let it sit without attempting to restart it. He hooks up his scanner or computer (small handheld box) and it doesn't throw ANY code at all!
Thank you for taking the time to read through this.
Cindy :sick:
I'd check first to make sure the main power to the vehicle was perfect. Check the battery, corrosion on the terminals or up in the cables, loose connections, key switch, and any main power relays. Probably the easiest way to begin to analyze this, is to hang a (fused) digital voltmeter off a 'switched' power circuit (a circuit that gets turned on via the ignition switch). Watch what happens to that digital voltage (should be normally about 13.5 volts), when the vehicle has the problem which causes the engine to cut out.
If the voltage is perfect and steady, then move your diagnosis to the computer and engine control circuits.
If the voltage was jumping around, then you know you have a power problem, and begin to focus there. Move your voltmeter monitoring back to a circuit which is an 'unswitched' (hot all of the time) circuit. If the voltage is fine the next time this happens, then you suspect ignition switch or relay....part of the circuit which is downstream of where you are monitoring. If the voltage is less than perfect, then move your diagnosis upstream toward the battery.
Thanks for the suggestion, again. I will keep this thread posted. Any other suggestions are also welcomed.
When I would come to a stop at a red light the engine would die. I go to park it the
engine would die. And when I put my foot on the gas it would lurch forward. When
my engine would die I would lose power steering. I go to start it again it would crank forever and not start. And the whole time it did'nt throw a code at me. After drive it for months like this it finally gave me a code. It was the coolant senser went
bad. Check the voltage at the coolant sensor plug with a voltmeter with the key on engine off and it should be 5 volts. To check the coolant senser itself you have to
ohm it with an ohmeter. Ohm out the coolant sensor once when the engine is cold and once when the engine is at hot at normal operating temperature. Compare it to the ohm spec of the coolant sensor in a hanyes manuel that you can get at autozone. If the coolant sensor is out of the ohm spec replace it. Or you can have a mechanic check the coolant sensor. I replace the coolant sensor on my suburban and it fixed the problem. Hope this helps later
at the vehicle to diagnose a problem with only your interpretation of a symptom......but here goes......
You don't have any fuel, or bad fuel, or fuel pump is bad.
Or a bad sensor, which one of the 50, who knows.
Or...........
Tested this about 3x at about 35 mph, stalled everytime, but cranked right back up. The suv is equipped with a trailer brake controller. If you've experienced this or a similar issue your response is appreciated.
How do you troubleshoot something like this when its occurrences are unpredictable and without a code? Wow... makes us hesitant to take it on a trip for worry it will decide not to restart in the middle of nowhere. I have read all the blogs relating to suburbans stalling and have not found a solution. Ideas?
I had the same problem with my 05 Suburban 175000 miles. It first stalled pulling out into traffic a week ago, left turn, dead stall, no stearing, traffic coming - scary. I was able to get out of the way. It started right up. Ran fine for a day. Then did it again. A day later again. I learned to shift to neutral and crank it while rolling, so I could get out of the way. A couple days later I noticed it was only on left turns. I went to two dealers and two repair shops. No clue. "only on left turns?" no way. It would have to be a wire short. They didn't have time, I was traveling out of state. The car was still going "straight and right" just fine... so I drove on. then I hit a big bump in the road east of Tulsa, and it stalled, but didn't die. 10 miles later it did it again. I'm in the middle of Oklahoma, and it is getting worse. Finally, I'm in walled in construction zone, no shoulder, concrete sides, 10 miles of it, and it dies completely. I shift to nuetral and it won't start. It tries, but won't. Guages are dancing around like crazy. I'm coasting to a stop, 10mph, and there in front of me is a hole in the concrete barrier that I ease through out of traffic. I get towed to a shop and they start pulling on wires. By this time, the car has cooled and it is starting and running fine. For some reason it was worse hot. They notice on a bunch of wires that run down behind or beside the power steering pump and under the car, that the car will stall if they pull on those. So they slide under and take of the skid plate and disconnect all those wires and pull them up for examination. We cut all the tape off, and examine them. The two little wires going to the lower AC switch have a kink and a worn spot, one has the plastic off for an 1/8 inch and the wire is exposed. We taped them up... saw no other bad spots, shook our heads, shrugged and put it all back together. For some reason on the left turn and later when it worsened, on a bump, the rub got worse and worse and then shorted out completely (when it was hot) The AC was working fine, there had been no engine light codes, but this surge / short had caused the stall. It is working fine now... we just drove 200 miles with not one stall. It had gotten so bad that it was stalling every left turn and most bumps in the road. It took 1.5 hours to pull all the wires out, and put it all back. No parts necessary. Hope this helps. Western Auto in Atoka OK - Great guys! thanks!
The car re-started after 10 minutes and drove home, about 3 miles, without incident. We turned off the car in the driveway at the house and when we tried to re-start it, it re-started when the ignition key was turned to the first 'accessories' position. We turned it off, then we tried again and it again started at the 'accessories' position. We let it sit for an hour and it re-started and ran in the usual manner, full power, no problems. We have not driven it for a week, it has been sitting in the driveway. We went out and started it a few days ago, started and engine ran fine (depressing the accelerator, no hesitation, no read-outs, etc.). Then we tried again a day later, car started just fine, but yellow 'check engine' light was on, no other read-outs, no problems. This morning we started it to move it to another area of the driveway and it was completely fine, no 'check engine' light, no read-outs, car started and ran as usual..
This is an intermittent problem, and I am afraid to drive it, don't know when/where the engine will lose power. Can someone here please give me a few suggestions?
I thank you for your help, and I will let the mechanic know about possible corrosion on the connectors on the ECM (it is now in the shop). I hope your trip goes well, and I will look for your follow-up post next week.
