Chrysler Sebring Fuel and Oil Problems
                    I AM THE OWNER OF STARLITE MOTEL ASSINIBOIA WE HAVE 2005 CHRYSLER SEBRING AS A RENTAL CAR .THE CAR NEED FUEL PUMP  PART # 5093455AD NO DEALER IN CANADA HAVE IT  I CALL THE DEALER HE SAID BACK ORDER WAIT AT LEAST 2 WEEKS NOW I CANT RENT THE CAR I AM LOSING MY MONEY WHAT I  SHOULD DO PLEASE HELP .
If you think you have water in the tank or lines you can get a can of gas additive at most auto parts stores which should remove it. Read the directions and don't be tempted to pour in more than what it says for the amount of gas in the tank. More isn't necessarily better.
Also, if you think the computer might be out of whack by putting in higher octane gas, you can reset it and let it relearn. Disconnect the negative battery cable for at least an hour or more (overnight is okay). After you hook it back up, start the car and let it idle for several minutes until the idle rpm settles down. Then try to drive at moderate, varying speeds for a while to complete the relearning.
The Change Oil indicator just came on and I'm wondering if when they allegedly changed the oil, that they followed the reset procedure. Is this indicator based on time and mileage?
To be 100% safe, I may just change the oil & filter myself as well as reset the indicator.
It is located little to the left above the oil filter.
I repaired mine yesterday.. The sensor is $10.99 at autozone.. You have to raise the car, remove the heat shield that covers the oil sensor (3 Bolts 15mm) remove the plate. Disconnect the plug and unscrew the sensor from the block. The leak is on the plastic part of the sensor that goes into the threaded part of the sensor. Mine would drip onto the exhaust pipe and smoke. Mine was so bad that I would loose 1/2 qt oil in about 50 miles.
Also if is nicer to goto autozone and get the OIL SENSOR SOCKET 9.99 cause it makes it easier to remove and replace the new sensor.
Hope this help, and be careful while working under your vehcile.
I saw on the gas tank cap that if it's not tight it could cause the yellow engine light to come on. I can hear gas sloshing around in my tank when I'm turning corners. Could there be a gas tank pressure problem?
I have a pretty bad oil leak that runs down onto my oil filter. You can see where it's coming out but the problem is figuring out what the part is called. I "think" it's something like the oil sending unit? It looks like a little valve.
Upon reading other posts I think it may be the oil pressure sensor. Can someone confirm if the oil pressure sensor is visible from under the car and just above the oil filter?
Thank you in advance.
