Infiniti QX56 Problems and Solutions
                    I have a 2008 QX56 with intelligent key.  This morning I can not start the vehicle.  Has anybody had this problem?  The remote will lock and unlock the doors, but the ignition switch will not rotate from the "lock" position and the dash light flashes the car and key symbol.  It is Sunday and Infiniti roadside assistance says they will tow it tomorrow to my dealership because they need a dealership signature to drop off the car and nobody is there on Sunday.
For what it's worth, I don't see why it wouldn't be covered by warranty.
SUVs and Smart Shopper
Yes, I just had the same problem with my brand new 2007 G35X. I too was driving on the highway traveling about 65mph when my sunroof exploded. Glass shattered and sunroof exploded up and out - very scary!! My car is currently at the dealership pending an explanation. This is ridiculous me and my passenger could have been killed had I not took control of the car. Infiniti is still trying to figure out what the problem was. Clearly a manufacturing defect. Has anyone else out there experienced this problem - please post.
Angel 10 in NY.
I just turned 1200 miles and I really enjoy the car when my wife lets me get behind the wheel. Both my F-150 and Q56 are black which sort of led me to order the Zaino Kit, for $86.00 , to see if I get the POP! that readers speak of. I must now build up my courage, stamina, and what else I need muster up to attack a 6 hour task.
6 hours to Zaino? I did the dawn, clay, to z-5 on a Yukon Denali in little over an hour. Course if you're doing a 6 pack an hour I can understand why it would take you 6 hours.
To further the discussion, I asked them why the HID. They explained to me that the QX in US does not come with the harness that allows DRL by simply switching a fuse (like my brothers BMW X3). They did that to the fog light in the past; but had a lot of complains about frequent replacement. HID on the other hand is more long lasting. Of course, I won't be able to tell until maybe 100,000 miles later. Theoretically, it should be the case.
It costed me about $400 to do it. Hope this helps!
Seems like a fuel level sender problem. Anyone else had this problem or clues on this and how hard it is to replace the unit ? Do you have to drop the fuel tank ?
I'd like any input.
thanks Bill
Has anyone gotten the dealer to warranty any of these issues? I would love to hear about it.
This is a warranty item...dealer replaced mine. you will need the Front Drive Shaft Assembly and a Propellar Shaft. This repair and parts were covered under warranty
What I wrote was only a suggestion. The proof is in the comfort of the passengers and you're saying that the overall cooling is inadequate. I've never driven a QX56 so I will certainly defer to your hands on experience.
I would say buy a $5 A/C thermometer at Autozone and take it on all of your test drives. Drive a QX56 on a day above 90 and see if it cools the cabin air, but more importantly see how you feel inside. To me, it felt hot even after 20 minutes, and the thermometer (60) backed me up. The rear air (after traveling about 4 feet through the roof of the vehicle) actually came out hot - 71 degrees.
FYI - I drove a Sequoia as well and it didn't cool below 55, which was OK but not ideal. I don't know what kind of A/C equipment GMC uses, but as I've said again and again, my new Yukon will get down to about 42 after 5 minutes on the hottest Texas days. I will never overlook the A/C again when buying a new vehicle. Luckily I bought the QX56 in June when I could catch the flaw quickly. Had I bought last winter or spring, I would be sweating like a pig while cruising in syle.
1. Brakes Fail with no explanation
2. Brake Rotors warp at 5,000 mile intervals
3. Automatic skid control actuates unexpectedly.
4. Transmission noise and shifting is irregular
5. Gas Mileage is horrible compared to its competitors
6. Dashboard button for rear hatch release repeatedly breaks.
7. Very harsh ride for a vehicle this price.
8. Dealership is clueless as to many of these problems.
Probably THE worst vehicle that I have ever owned.
