Subaru Legacy/Outback "Check Engine" Light Problems
If you are reading this message, you probably know what this is all about. You have gone through multiple 'check engine' light episodes, have replaced multiple oxygen sensors, and are on your third or fourth catalytic converter. I had a 2004 Legacy wagon with 80,000 mi, and my friend (still) has a 2004 Outback. We both have had the same experiences, so these problems are certainly not isolated incidences. In fact, my mechanic told me that has seen all kinds of creative means to disable the 'check engine' light. However, if you live in New York State and need to pass the annual emission test, you will have no choice but to fix the problem. In my case, I also had a transmission replaced, and had a cruise control problem that was unfixable (Subaru started an investigation, but were unable to find the causes of the problem). To retain my sanity, I finally traded the car in on a BMW and took a financial hit.
O2 sensors won't fix it. Spark plugs, spark plug wires, and maybe an ignition coil might. The coil is only $80 and there's only one for all 4 cylinders.
Tell your friend to try that. It's worked for other Edmunds.com members.
Honestly, you just need to find a better mechanic.
I'm working on an '01 Legacy (140K miles) for a friend. The check engine light is lit, but the code reads "N/A?" I can clear the code, but it comes back after a few minutes. The car runs fine cold, but is a little sluggish just off-idle when warm...once you get it rolling at speed, it feels fine. I've checked the plugs, air cleaner, cleaned the throttle body, battery connects and given it a general look over...I see nothing obvious. With this kind of mileage, he doesn't want to invest a ton in it. Anyone ever run into this error? Thanks in advance for your help...MT :sick:
I wonder if paisan has seen it before, paging paisan...
-mike
The knock sensor is mounted on top of the engine, just slightly on the right side (looking at the car from the front), and near the back of the block. It is somewhat underneath the intake manifold. It is not overly difficult to access, but it is a tight space - especially plugging it in!
Keep us posted with what you discover, please!
After driving from MD to NC and back this past weekend (with no problems) ... today I was driving around and, mid-way thru errands, the yellow "Check Engine" light turned on, and the green "Cruise Control" light started to blink on and off. I tried to "turn off" the CC using the handle by the steering wheel (even tho' I wasn't using it), but no luck. And stopping and restarting the car still gives me the error.
Any ideas on diagnosis and fix, or should I just take it into my local mechanic? (I'm not super car-fix handy myself.)
sapphireblue
-mike
And if it is an engine problem (e.g., cylinder issue), is that covered under the 3Y/36000 mile warranties (which I am still under)?
sb
-mike
-mike
They cleared the code a few weeks ago & since I've tightened the gas cap it hasn't come back.
I need help, I recently purchased a 97 Legacy GT with the 2.5l eng with 195k miles. shortly after I got it the CEL came on. I had the dealership check it out for me and the tech told me it was calling out a #1 cylinder misfire. since then I've changed the spark plugs, wires, and the coil, and the still came back after they reset it the third time. the eng runs great, except for every once in a while when I stop at a light it idles a little rough. I dont know what else to change out. does anyone have any suggestions?
-mike
one subaru owner I knew who had this was told the gas cap, hosing and emission cannisters connected to the fuel filler, were defective. Once those items were serviced, his check engine light problems went away.
-mike
Advice to anyone with a similar problem....swap the fuel injectors with each other and see if the codes change before replacing all that electrical stuff (unless, of course, it's tune-up time anyway).
BTW I own Toyotas and Hondas with similar/more mileage, and none have ever turned on the CEL. My POS Subaru does it routinely.
At this point, it is too early to tell if you should look to dump the car. Super low miles for the year, so it could potentially be a good buy for you. Give it some time, and proceed with repairs cautiously. Throwing sensors at the car to solve a tripped code is not a good course of action.
However since your car is a 2002 w/21k miles if it is in fact an emissions problem, it will be covered under the 8/80k emissions warranty.
My guess is that it may be the gas cap tightening thing, so give it a few days before panicing.
-mike
good luck.
I got an Actron model for $99. I've used it a couple of times, plus a couple of times for friends.
At $130 per use, it's paid for itself more than 5 times already.
This Code reader works well, cost <$40 USD and helps you figure out right away what the problem is. It also prevents having to stop at autozone to have them read/reset codes.
Thanks, for all the help on ideas. I am buying a scanner deal. There's a Harbor Freight tools here. Going to go check it out.
http://www.obd-codes.com/reviews/showproduct.php/product/25
It is an OBDII reader. There was OBD version I.
Does anyone know when Subaru switched, and if an OBDII scanner will read codes from earlier models?
I know that my Miata, for instance, is OBD v1, but it's a 1993.
Maybe check to see if the port is the same on your 95 Legacy? Let me know. It's under the dash board near the driver's left knee.
Edit: this is what the plug looks like:
'95 Imprezas were OBDII, and '96 Legacies are OBDII IIRC.
-mike
Motorsports and Modifications Host
I bought this car based on what I'd thought was a stellar reputation for the company. Am I confused on that point (I've been reading a lot of folks saying Subaru is famous for 'issues' such as this - I'm not looking for another 'dependent', if ya know what I mean).
I've checked my gas cap; I haven't checked my fuses. I expect I'm wasting my time until I get an OBD II readout - correct?
BTW, I've been reading a lot about different OBD II scanners; most that I've checked on claim that the Subaru needs one that also has VAG (don't know what that stands for, but apparently reads more codes). I have the 2.5 normally aspirated engine; any suggestions on which I should purchase? (It'd be nice to be able to at least get an idea, for future reference, what's wrong before hauling into the dealership.) Thanks.
Let me give a little history of these problems so that I can get your collective thoughts on whether they are all related and symptomatic of a larger or missed problem or simply unfortunate isolated incidents.
My 2002 Outback Wagon is the base model with a standard 4 cyl. engine, automatic transmission. It currently has approx. 93k miles on it.
Back in late 2005, when I had approx. 51k miles on the vehicle, I started getting constant Check Engine lights. The dealer pulled a Code P0420 and started off by replacing a Fuel (or Oxygen) Sensor. (The dealer indicated that these were the same things.) When the CELs persisted approx. 2500 miles later, and the same code reappeared, the dealer replaced the catalytic converter. I went 15k more miles and the problem resurfaced - same code. The dealer cleared the computer and told me to drive on it some more. At 73787 miles, when the CEL and same P0420 code came back, the dealer replaced the same fuel/Oxygen sensor. Then, at 76874 (now February 2007) -- same code came back and the dealer put in a new catalytic converter.
Up to this point, I simply got constant CELs and it did not really affect driving performance in any perceptible way. That changed this past fall, when I noticed that the vehicle would sputter and I would get intermittent engine vibrations, usually at idle or low RPM. Occasionally, the vibrations and sputtering would get more intense and sometimes at higher RPM (e.g. 2k). I also noticed that I would typically see the problems when the weather turned colder and in stop-and-go traffic or at higher altitudes (in the mountains at 9000 feet and above). The CEL would blink for 20-30 seconds and then turn constant.
When I brought the car to the dealer in November with approx. 89k miles, at first they could not pull a code, and simply cleared the computer. The problem reappeared and technicians were able to pull a code: P0302 (cyl. 2 misfire). I was up for my 90K service, so that was done, replacing the spark plugs, and I also had them do a fuel injector flush at their recommendation.
My problems came back in about 2 weeks and less than 2000 miles. This time the technicians pulled a P0420 code. They cleared the computer, told me to drive it some more, but warned that if the code came back I would be due for my fourth catalytic converter.
The same symptoms persisted but when I brought the vehicle back to the dealer in late January, with approx. 93k, the techs pulled a P0302 code (the cyl 2 misfire) again. At their recommendation, I had the ignition coil assembly and ignition wires replaced. Although it was not documented, the technician also told me he did a comprehension test, which came back with normal results. They told me to use better gasoline and drive on it.
The same problems -- engine sputtering/engine vibs, blinking CELs, etc. - came back within a week and less than 200 miles (using the better grade gasoline). The tech who worked on my car confessed that he was not sure whether the new coils and wires would solve the problem but all that the dealer can offer at this point is the recommendation that I continue to drive on it and keep putting in better grades of gasoline. Otherwise, they are out of ideas. (The service manager confessed that he did not think gasoline quality was really the issue.)
So the short questions I have following this long post are these: Are the problems interrelated? Has something been overlooked? (A friend mentioned that loose connections with the air filter may be a culprit.) Any thoughts on what steps to take next?
I would be grateful for any suggestions or advice.
I would have tried that sooner. The cat was probably a symptom of unburned fuel making its way past the cylinders that were misfiring.
This case is far beyond my knowledge, but they have to try to find the cause rather than continue treating the symptoms.
-mike
