Oldsmobile Aurora Transmission
holly2883
Member Posts: 2
in Oldsmobile
I have a 1997 Oldsmobile aurora...The transmission acts like it has no power at all it wont go into any gears at all even reverse or drive unless you get the rpms up to like 5000 then it will go into gear but to get it to drive you have to stay at the high rpms....just wondering if it is the tranny or something else causing it...and also the car has always started then one day someone left a light on in it and the battery went dead so we jumped it and it started right up....then like 2 weeks later went to start it and it started right up i turned it off then went to start it again and no noice at all only a clicking sound in the fuse box in the back seat....tried to jump it and still same thing...and also my turning signals come on but dont flash just stay on solid just wondering if anyone else has had these problems.
Can anyone point me in the right direction? Past inquiries at the garage came up empty, says the prior owner.
I have a 1998 Aurora with 175000kms on it. My tranny went at 75,000. I started it on the garage pad, heard a large noise and stopped the car. I started it later and everything seemed fine, One week later, the gears all went. Maybe there was a weakness in the tranny--I do not know.
I checked with various tranny rebuilders and they told me that since it is a cadillac tranny, the costs of rebuilding could cost more that getting one from GM. I got a new tranny with 80,000 Kms warranty. The new tranny still runs as smoothly and perfectly as a tranny can ---as does my entire 1998 Aurora, which I intend to keep for many years. I just bought myself a 2008 Solstice GXP as a fun roadster car since e I could not find an adequate replacement for the Aurora---so now I have 2, which is silly, but fun!!!.
I really like the car, and am glad that I purchased it. If this can be resolved without too much pain it will really be a joy.
The shop I use now was recommended by a friend who drives high end cars and puts a ton of miles on them. When he developed a serious tranny problem, he took his Acura back to his regular local dealer of many years/cars, got quoted $5,400, flipped out, went transmission shop shopping, and wound up at one that did the same job for over 35% less. No follow up issues, and that same car soldiers on five years later.
When I pulled up to the same transmission shop (located in a lower rent industrialized area of town), I saw Acuras parked there. When I asked the owner what all the Acuras were doing there, he said he does that same dealer's overflow.
I like the idea of getting the same level of quality without getting ripped off. Ask your more knowledgeable friends and acquaintances, and shop around.
http://aurorah.proboards.com/index.cgi?board=1stgen&action=display&thread=2376
Had input output sensor replaced under warranty with no success. However mechanic at private service station I deal with advised that there is a technical service bulletin out on this problem. Apparantly it is caused by a faulty electrical connector going into transmission that creates a false signal and causes problem. This is a large, gray connector is located on the right side of the transmission (as you are looking at it from front of car). To alleviate the problem I simply wiggle the connector. Typically check engine light goes out immediately or maybe after several start-stop cycles and transmission works just fine. When in for service have mechanic check codes and inevitably come back as transmission codes, though I cannot tell you which ones.
Problem is getting worse as time goes on. Now have 123K on car. Big problem I face is getting through emissions testing. Have to have check engine light off and car go through several start-stop cycles after resetting light. Was able to get through in August and have almost two years before need retesting. However thought of having to spend $700 on a non-repair to pass emissions (and stay registered) is not comforting one.
Have you had any success with resolving problem?
I only took it for a short drive to test it and no codes reoccurred. I have to check the data to see if it shows any kind of signal relating to that P0716 code. Could that be my only problem or does anyone knowledgable of these transmissions think there are more issues based on the info I have provided. I suppose even anyone's previous experience with perhaps the same issue would be appreciated.
My loss of third gear was in the 3rd gear clutch pack where I found the clutched to be completely burnt out. Replacement of the above items and I now have all four gears back.
