2008 Accord Noisy Tires
We're looking for a new car and test drove a 2008 Accord last weekend. We loved the "cockpit" dashboard and the nav system. But we thought that both the engine (a 4 cylinder) and the wind noise was very loud. Has anyone had a similar experience? We test drove a Camry and a Lexus ES350 on the same day - both V6, and neither seemed as loud. The engine nosie reminded us of our '97 accord with a manual transmission.
completely new to the car buying experience, so forgive any technical blunders here. We'd go for the Accord, but we were bothered by the noise and the increased length (we park on the street a lot).
Speaking of length, ES350 and Accord are about the same length, an inch or two is unlikely to make a difference. OTOH, the new Accord's turning diameter has reduced, so it should be as easy, it not easier, to park than the outgoing shorter version.
Agree that the car is noisy due to the michelin tires.
noticed it especially on rough concrete.Engine is as quiet as my 02
camry and no wind noise when sunroof is closed.
Maybe its the car & not the tires?
Tires can make a big difference. The stock Michelins are expensive, last for a long time but they hate certain road surfaces (usually old-ish concrete/tar). Every other tire I have had on my 98 Accord since the original has made the cabin quieter and comparable to the quietest cars in the class without giving up the Accord attributes. The car still tracks like I want, and handles well. Mileage has never been a disappointment.
The hate, especially, shiny/broken road surfaces. Don't offer good grip either. I have had other kind of disappointments with other brands though. Some were exceptionally quiet and drastically improved steering at the same time, but wore off too quickly (soft compound). It was one of the Yokohamas (forgot the model).
I didn’t see Michelins as being prone to road hazards in fact, quite the opposite. On the other hand, my move away from Yokohama was triggered by that fact (and lower life, given my driving style).
But I have never seen a worse tire than the set in a (rental) Sienna. I went over a pothole that I have several times in my cars, and heard the air being lost. The AAA guy the rental company sent told me that it was a common problem. Based on my experience, I’m assuming softer compound tires are quieter but more prone to road hazards.
WOW. This is definitely not a revolutionary improved full model change. I am wondering if it's even evolutionary. It just looks bigger with too many lines and weird body panels(ACE?).
I apologize 2008 owners as this is what was primarily supposed to be fixed per the marketing blitz "Beyond the Road" One thing I did to delete the tire problem in my 2006 is install some good Toyo Proxes 4 All Season tires. Real good match for this Accord as Toyo uses computers heavily to design the tires and use top notch design and materials! Tire is great in wet and dry and I've put on about 30k on them which is where they will max out. Definitely a recommended tire from me as I got 36k on my 2006.
I have about 36000 miles on my '04 Accord's Michelins, with no problems, and I find them to also be acceptable. I'll probably trade this one in for the '08.
My other car -- an '00 Accord coupe -- needed tires recently. I started to order Bridgestone Turanzas, which I've used before -- good tire -- but they seemed pricey this time, so they recommended Kumho Solus KH16. About $325 for Kumhos vs. $550 for Turanzas. They said the Kuhmos would be quiet and also wear well. So far, very quiet, smooth rolling, and I'm pleased. Don't know if this particular Kumho comes in the size that an '08 Accord would require, but so far it seems to be a good brand.
I am shopping for automatic EX. Please tell me how much you paid total delivery (or base plus taax) and from where.
Thanks so much,
Mandy
But if I had to guess, I would expect to pay about 7-8% off MSRP at the minimum (out the door, including TTL etc, for roughly about the same as MSRP).
This discussion is specifically about 08 Accord tires, so it's not where you're going to find a lot of folks who can help you.
Good luck!
You want bad tires, buy the Goodyear Integrity series.
Given their cost, when the time is here to replace, I doubt going with them.
Um, huh? What cheapness?
TheGrad
2006 Accord EX Sedan, 25,400 miles
Anyway, 2 days b-4 I bought the car, I went by Belle Tire( 75 store chain in my area) to ask if they would be willing to give me any credit for the OEM's. By the way he answered it sounds like they do it quite frequently. He called it a "new tire trade-in", which he defined as almost new tire(65 miles in this case)at a lower cost.
Long story, but he ended up offering to swap them straight up. No out of pocket $ for me. Plus, he threw in their road hazard warranty, which I did not have with the OEM Michelin's. It was neat how it worked out. I got the car yesterday and had them switched today.
I will definitely post updates as I get a few more miles on them. It may be tough for me to compare them to the Michelin's since I only drove those for a few miles.
On the V6 08 During steady cruising speeds , VCM shuts down one bank of cylinders. In this mode, the audio system’s Active Noise Cancellation (ANC) function generates out-of-phase sound waves to cancel out any undesirable noise that may be due to the harmonics of 3-cylinder operation.
Only issue is its not 100%t effective...
Honda's double wishbone suspensions (vs. less costly and less complicated MacPherson type struts) also appear to produce ride dynamics that may generate greater road noise or sensations. I like the way Hondas ride, and have always considered the greater road noise to be one collateral side effect.
Some also say that the current drivetrain (although it's a similar engine block and architecture, but greater displacement from 3.0 to 3.5 liters) is also more noisy compared to previous Accords. Subjectively, that may be the case.
We also own a 2005 Acura RL, which has a version of the 3.5 liter V6 (but no VCM). The RL is more quiet than the Accord, but luxury car owners seem to generally complain that the current RL has more road noise than other higher end cars. The RL has the same Michelin MXM tires, so I believe tire noise is definitely one of the causes. And possibly the all wheel drive. But it's a nice, sophisticated, and reliable car that has sold poorly.
Of course, the next RL will offer the next generation of VCM, but in a V8 as well as V6.
However, that said, again, if you research the tires, the OE Honda Michelins score very poorly for road noise versus other replacement tires of similar size and performance characteristics as all season tires. A lower rolling resistance can also increase gas mileage and there ARE differences from one manufacturer to another in that regard. Just wondered if anyone had had cause to change tires yet and what their experience have been.
I have a 2008 Accord 6spd coupe, and I currently have Kumho Ecsta SPT directional summer-only tires in place of the OEM Michelin MXMs, and I believe my coupe not only handles better, but it's also less noisy without the stock Michelins! Go figure.
The MXMs are not cheap when purchased after market, but Honda must get a great price on them since they put them on so many of their models. They are biased toward fuel economy, touring, and all season traction. But they're not particularly stellar at anything. And they're noisy. I love my coupe with the summer rubber and aftermarket rims!
And the fact that my coupe doesn't have VCM is a bonus, in my book.
they are telling me 24000 out the door price...i dont know if its good or not. please any suggestions thanks...
Click that link. That's where you want to post your question. This forum is for questions regarding tires in particular, so you might not find many responses here.
Good luck!
issue. I am about to venture down this road and wondered if anyone out
there has had any success in having the dealer replace the tires. This seems
to be a rather popular complaint among us Accord owners. I will let you
know how I make out.
