If you're not a do-it-yourselfer as I was tending to hope, I'd buy the new one from GM partsdirect or rockauto.com for $560 and pay them to put it in. Hope that the new engineering has resistors and solder joints improved. The worry I have is that the older Regals had trouble and your car is still having trouble.
Putting in a used one is probably going to go dim or already be dim.
Take the old unit you pull out and send it off to be repaired on Ebay if you aren't into soldering yourself. Put it back for a spare if you plan to keep the car.
I still think your cheapest would be to take the unit out (or pay a garage to do so) and send it off for repair, and then pay the garage to reinstall. I understand you can drive the car without the control unit. Are you in a moderate climate?
If I'm understanding your post correctly, you are stating that one option is for you to purchase a unit from gmpartsdirect and take it to the dealer to install.
Heck if they are willing to install a part you bring to them, I'd pick up one from eBay such as this one: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270389813817
which probably has been rebuilt better than factory, and have them install it. The 1 hour labor sounds like like it's unavoidable, no matter where you have it done - at a dealer or locally owned garage. You do have to ship your old unit to the seller with this method, but there is no down-time - just a quick swap. I suspect cold weather will be setting in soon in your neck of the woods.
I personally would feel this unit would work as well as any unit that your dealer is offering, yet at a reduced cost.
I can't tell from your posts much about you, young, old, male, female. I think I read somewhere that you live in Maine. I don't know if you feel comfortable enough to buy something from an eBay seller, and if that is an option you would consider. I buy on eBay all the time and would do it in a heartbeat. Just to make it clear, I am not that eBay seller, not related to him or her, do not know him or her
But if I have to stick to your original question: Which of the two options in your post, I'd probably try to see if that new unit has an improved design and if yes, go that route.
Otherwise, as Imidazol97 said, you may just be paying to swap a bad used part for a bad used part.
Hope you find the right solution!
That means only one visit to the shop.
It'd be worth paying the dealer extra to install a known good one to compensate for the lost profit he would have made on the new part at 800 or whatever it was.
Last I had known, a dealer wouldn't put in anything other than a new GM part of rebuilt or remanufactured by GM. Things may have changed as the profits went away.
Dash control unit, park avenue, main control
97-04 MSRP $1,077.32 Your Price $646.39
Any ideas?
I have seen this question posted a number of times in the BPA Maint. and Repair forum, but no one seemed to have the answer. I hope you can help.
As you will see, my previous post described the exact same problem you are having. The hot on one side and cold on the other doesn't seem to have any explanation related to the controls settings. My guess is that there is some flap that is not working properly, however it seems a number of people have the same issue. I saw this same question posted a number of times on the repair and maintenance forum (with no answers posted), and the eBay link to the place that rebuilds climate controls stated on his eBay listing that he was aware of the same problem (hot on one side/cold on other) and that replacing the climate controls would not fix it. Apparently, lots of us have the trouble and I have yet to find the answer. I think I will rip into the dash myself the first long weekend I have and see if I can find something.
If you were not having this problem before the CC unit was replaced, I would promptly return to the dealer and explain that they need to fix it. Maybe it is a weak part that gets easily broken or misplaced from removing the entire dash?? I would make it their problem if it is a new problem to your car.
I hope someone has our answer. I will post again if I find something. Good luck!
My best guess on the bouncing fuel gauge needle is the sender unit is going bad. There were a few years that the senders seem to have been built to insufficent standards. But the problem is not limited to PAs. Our '98 Jeep fuel sender was built substandard too and would make you think you had 1/4 tank when it was bone dry. ( Surprise! :lemon: ) Other models too, not limited to our models. Some vehicles model years have a safety recall on these items. You shouldn't run out of gas in traffic when the gauge says you've got plenty of gas, hence safety recall...
First, I'd recommend you contact your dealer and ask if there are any recalls that need action on your car. And ask if any have already been performed. I'd guess they should have told you of any needs while you were in the shop, but just to make sure I'd ask.
If you were a DIY'r, I tell you how you could fix the bad sender for about $30, but its a more difficult repair than the climate control. I'd guess a dealer repair will probably set you back another $500-700. That's just a guess. gmpartsdirect says it's a $225/$117 part, but that's just for the sender (and doesn't include any crazy shipping costs). Sometimes the dealer will want to replace the entire pump & sender assembly as a whole. At MSRP, that would be almost $600 - $800 for parts alone!
About your passenger side temp control slide: Did you use it before replacing your climate control, and was it working then? Please do check your owner's manual on the use of it
If you don't see any temp difference when you use it, it is possible the dealer didn't reconnect if properly, or a wire broke or came loose. Like Ramzoni said, if it was working before and not working after, I'd say the dealer needs to repair it at no cost.
Sometimes the mechanics at a dealership are experienced, sometimes they are working as part a school program.
Let us know what you decide and how it goes!
Repair fuel gauge senderon how to repair the sliders by replacing only the contacts using Aurora parts which were available separately.
Also in watching the video you see how easy it is to do some repairs--if your PA has the trunk access hole rather than needing to drop the tank to access the fuel gauge sender.
Some gauge have had a corrosion problem due to sulfur in fuels. A few additives claim to help that problem; Techron by Chevron is one. It's on the shelf at Meijers, Advance Auto, Pepboys, different prices and two different sizes, 12 oz for 12 gallons and 20 ox for 20 gallons. You want the fuel system cleaner rather than the injector cleaner. I would try that.
Essentially the contacts slide and change the resistance. That resistance is read by the gauge. If there's corrosion on the slide (or wear so contact isn't made) the resistance changes drastically. In your case I would guess that high resistance is read at high float and therefore with poor contact your gauge is getting a reading for full tank. Then when contact is made again, the gauge slowly goes back to the correct reading.
Having someone else do the repair is probably expensive. I myself would put up with a lot silly gauge reading movement as long as it was reading at times so I was sure I had a certain level of fuel.
On newer ones the actuators are easily accessed (relatively) and replaced. So take off the cover panel, and spend some time upside down moving controls with the key ON and seeing which control moves which actuator. On older ones the links may have come unsnapped or the actuator gears may be broken inside or slipping.
Yesterday, I pulled the battery to use in testing another vehicle. I then reinstalled it back in the 94 Park Avenue. The battery cables are clean and are attached to the battery on the correct terminals. But, ever since that battery reinstallation, for some reason my gauges and the security system seem to be behaving like they are being "fed" reversed-polarity juice. Here's what's happening:
I can only start the car now by (1) opening the driver's side door (2) using the power lock switch to lock all doors (3) get in the car and close the door (4) wait for the security system to set (5) turn the key. Works every time, but also sets the alarm system off. I then use my door key to turn off the security system off, while the car is running. If I try to start the car in the normal way, the security system is keeping the starter and fuel pump disengaged.
Also, when I start the car and then shut it off, my temp and oil gauges swing to the right i.e. clockwise and to the high-reading side. And when the car is running, my voltage gauge reads only about 11 volts continuously. It never shows any signs of reacting to the gas pedal or alternator's charging.
This all seems to point to a simple polarity problem, but I can't figure out what is causing that or how things got this way, since all I did was remove and reinstall the battery correctly. ??? I know this is probably something bone-headedly simple, but any help anyone would be willing to offer would be greatly appreciated. Thanks.
Like I said tho, I'm not very experienced at soldering. I'll be honest, that I haven't focused a lot on cleaning out the old solder as there wasn't a lot in place. I mainly just heated it well, and added new solder.
If you do a search for soldering techniques, there are lots of howtos and videos that can teach way better than I could.
Sorry, I couldn't respond before now - it was an on-call weekend. You probably got it working by now, eh?
Is there any chance the battery has switched which terminal is positive and negative from its treatment in the other car environment?
What was done with it at the other vehicle?
But it's my thinking that a reversed connection on the battery destoys the fusible links to protect the electrical system...
I suspect you might have removed it with the key ON or reinstalled and reconnected with the ignition key ON? That's the best I can do.
The steering wheel buttons require pulling the buttons out with paperclips prying on both sides to wiggle them up. The leads are short and the bulbs can be unsoldered and replaced. They probably have a blue filter over the bulb that you can recycle to the new bulb.
Radio Shack will have bulbs for both applications. You may not find an exact match but they will be serviceable.
3) Would GM carry the bulbs?
Yes, but not the way we want. They'll sell the bulbs in a new heater control unit!!!
>how removed...
Remove the whole control box then, carefully, disassemble to determine what bulbs are where. Those bulbs, in my guess, are behind the switches; the switches probably don't come out by prying on the front like the steering wheel switches.
Give me some time and I'll see if I have a guide for the HVAC repair...
I'm sure there are places on the net, and EBAY if you can stand it, that repair yours on quick turn around or send a rebuilt unit for a price. Depends on how much you like fine, detail work inside stuff.
question for you, when you say it won't start, do you mean the key is turned, but the engine won't spin or turn over at all? or do you mean the engine is turning over but won't run? Does it ever quit running while driving?
If it is turning over but not firing, I'd say there is a 99% chance that you've got a failing crankshaft position sensor (abbreviated CKP). Unfortunately as your mom and mechanic have seen, when it (the CKP) fails, it fails in an intermittent fashion. There was apparently a bad batch of these around the year 2000 models.
Part costs about $26 at Autozone, lots more at the dealer.
I'd recommend she have the mechanic replace that part and she'll probably be set, if that is the symptom you are describing.
regarding posting a message in this forum, you would probably be better off selecting the 'start a new thread' link or the 'Post New Message' link and put a brief title that describes your problem or question, with the detail in the "Message:" box.
I don't think the other poster's condition about the Regal, is like yours as it would not restart at all at that time.
After each sensor replacement no problem for 10 to 15 days, then back again. The occurences are random, but now showup when starting a cold engine. also occur either driving straight or when making a turn in either direction. Goes away immediately upon hitting "Reset" button or turning engine off. There is no known affect on operating the vehicle when this occurs. Definitely a nuisance.
Would appreciate hearing about a definte "FIX" have read alot so far about similar problem symptons.
Thanking you in advance
MacMan2009
I have a 99 Park it had a 11 year birthday today. Two issues the back up lights
are not working I have checked the fuse box under the glove compartment the fuse
looks good replaced the back up light switch a the transmission wit a new one and
replaced the bulbs still no good any ideas? 2 nd issue is the oil pressure read out
I replaced the switch above the oil filter checked the connection but the read out
is wacky rise and falls and rings the alarm. Any ideas?
Art Levine
as the PA ultra? I mention to a Buick GM that bench seats in the front are great
for big guys. He said the bench seat went out with the 8 track. If they do not build
a model like my 99 park I will drive it forever until the wheels fall off. I bought mine
new 40 K pearl diamond white it still runs great with some minor electrical issues.
I just press that window with my thumb when it goes dim with the temp.
1999 Buick Park Ultra Back up lights failed both of them. Check the fuse replaced it even though it looked ok. Replaced the bulbs even though they looked ok. Noticed
a broken Green Wire in the bundle that goes up the trunk C HINGE . sPLICED AND REPAIRED still no lights I will report after inspect the entire harness to the lights.
Any ideas?
Tap splicer so that it will not come apart again so easily. I replaced the fuse,backup
switch and bulbs good that they are new but that was all unnecessary. So word to
the wise find the fat green wire in the bundle that is the ground make sure yours is
not cut or broke!
In sharmon708's case the car is NOT turning the motor over due to the security system protecting from nonauthorized keys.
One question, was more than one key in the car near the steering column at the time it wouldn't start? I.E., one key in pocket or hand and the other in the ignition? I've experienced this with our Cobalt. Two key transponders reacting when the key is inserted confuses the computer.
The key does not have the transponder in the head of the key. You're telling me then it has the black chip in the neck of the key that gets touched by two contacts at the entrance to the lock cylinder when the key is put in all the way. I was wrong in thinking it had the transponders...
If it had the black chip with metal contacts on both sides that's the VATS system. The tiny wires in the steering column connect to the connector at the base of the steering column. Tilting the wheel breaks the tiny threads of wires in the wires and changes their resistance as more of the threads in each wire break. Also the contacts in the lock cylinder may be dirty or worn back and making bad or poor contact.
When you turn the key ON the security light should come on for about 5 seconds as the theft deterrent module reads the resistance in the circuit to the key. If that resistance is right, the security light goes off. If not, it should start flashing and flash for three minutes as the injectors and starter are locked out.
Then after 3 minutes the module is ready to read another key chip.
There are other problems some people have had with various parts of the car security such as trunk lock sensors on H-bodies.
If your problem is VATS, the easiest fix is to find the two tiny wires at the bottom of the steering column (they're usually inside a larger plastic housing that looks like a single wire itself) and jump them with a resistor pack the same resistance as the key chip (within 10%). Theft alarm installers have resistors that they get already made to the 15 resistances used by GM. They might be an easy way to have the resistor jumper installed for a moderate price even ifyou don't buy an alarm system from them!!!
Clean the key contacts with a pencil eraser. Use another key if it works better. Dip the key into alcohol and insert quickly into the lock cylinder to try to clean the contacts that rub the black chip.
If it is the VATS system like on the leSabre and Bonnevilles, the module can fail in 4 ways. One is if it decides it's getting wrong readings for some reason and it goes into bypass mode where it just lets the car start every time. Mine on my 98 leSabre did that. Occasionally the security light would come on while driving and then go off. Occasionally the key chips didn't read right on the first turn of the key. But instead of locking out 3 minutes every time, it would read the key again on removal and reinsertion and usually start. Eventually the system quit turning on the security light or the bulb burned out. I don't know which. That's 2 years ago.
Good luck. http://vats.likeabigdog.com/
Search for VATS on google. (vehicle anti theft system)
Sharmon708, the key transponder is not the same as the keyless remote.
Unfortunately I can't offer any real help to you. I had one car a long time ago, that if you drove it for a long drive would not turn the engine over until it had cooled down a while. I always guessed that the starter was getting too hot as I thought it was by the exhaust pipe, but I can't say with authority.
I've not heard of a NSS failure on these cars, although I've seen it on Jeep Cherokees.
*** If you suspect this is your problem, one way you could isolate it would be to wait until it fails again and then put the transmission in neutral and try to turn it over. They will start in either neutral or park, by design. On the Cherokee NSSwitches that I've seen, the copper contacts in the area of the 'park' selection would get dirty or gummed up while the neutral was usually still in good shape. You could test them by one of two methods, either attempting to start in neutral, or pulling the relay for the starter and jumper'ing it to bypass the NSS. I'd recommend a try in neutral to keep it simple.
If your mechanic has looked at it, I would guess he has eliminated the simple stuff like loose battery cables.
Hope you find it soon, and please write back if you do, so that others may benefit from your experience.
When the problem occurs, the security light is not flashing. Messing with the shifter sometimes seems to reset the problem but it is inconsistant. Removing the key and re-inserting has sometimes corrected it also. The car has 84,000 miles on it and this is the most significant problem that I have had in the 60,000 plus miles that I have owned it. So far, the car has not had the problem in a week an a half.
Here is what happened i was sitting at a stop light and it just died.. So I put it in park and tried to start it but it won't even turn over. So i thought i lost battery connection but the head lights, horn, wipers, radio, and the power seats were still working . So I checked every fuse in the fuse box under the hood. All were ok. So i checked the one located under the back seat and checked most of them and they were good. I bought a used ECM but have not got it programmed yet. I talked to a guy at my work and he said to check to see if i even have power going to the fuse box that is under the hood. My car has a lot of miles which i put a bunch on it my self and have changed a lot of things but its a solid car so it worth it. motor,trany so far . the car its self has 270,000 miles. but i want to get to 300,000
Thanks for your time!!
At that mileage I would guess crankshaft position sensor when it died, but when it wouldn't turn over, that indicates more. Because of the double positives, power may still go to part of the car and not others.
However, because it died and then wouldn't even crank, that might point to the cables.
You can test with a meter at the small terminal on the solenoid, while someone turns the key ON and CRANK to see if power is getting to the solenoid to active it and the starter.
Be careful with live positive wires. But The real test would be to get under the car and use a jumper to see if the thing cranks when you apply power directly to the solenoid small terminal that the key actually applies power to if all the parts are working in between. Then if that doesn't work, apply power to the positive terminal on the solenoid, the big one, and expect a spark. If it cranks then, you know it's a connection or the solenoid.
You could have all your accessories work, in spite of the starter not turning the motor over as it (starter) uses a much larger draw of amps. So if you have a loose connection at the battery, that could happen, or if the battery itself has gotten weak it could cause the stall and failure to restart. Alternator working properly?
Did you try to test the battery strength or jump start? Wiggle the battery cables and make sure they were tight?
Next would be testing the starter.
If both battery and starter pass tests and cables were tight, maybe a fusible link, but I'd look at a failure of the intake plenum with subsequent dump of coolant into the engine which can cause it to not turn over. That has happened to my '98.
But I'd check the simple things first.
Hope you set a record for high miles! I'm around 280k now, mostly original and shooting for 300k as my next goal too..
Please let us know how it goes.
What have you had to do to your car for those miles?
2 intake plenums (also known as UIM / upper intake manifold , the 2nd was a redesigned unit with a metal ring around the EGR pipe water passages, and replaced the original EGR stovepipe with the included reduced diameter pipe)
1 starter
1 radiator
1 oil pressure sensor ( +1 under warranty)
1' length of plastic hard pipe which connects fuel pipe to fuel rail
2 sets of Michelin X or X-Plus radials avg 100k miles each.
the usual maint stuff:
brake pads & rotors, rear bearings - hubs, valve cover gaskets, air & fuel filters, battery, shocks
I say 'mostly orig' as A/C, engine, trans, are original (except the UIM). Keyfob & it's battery orig too.
I try to swap oil & filter at 3 - 4000 miles
flushed the trans fluid (but only twice... probably not as often as I should)
I bought it in 2001 with 99988 miles. High mileage for a 3 year old car, but it had regular maint and a glove box full of receipts to prove it.
misc repairs:
resoldered resistors in climate control
installed pin to stop fuel gauge from flipping needle over
repaired connector to rear defroster
removed stuck cassette tape from stereo causing it to display error
took apart dash (huge job!) to replace turn-signal flasher, only to find it wasn't bad
replaced 1 driver's window motor
replaced 1 wiper motor
Looks like a lot, but I don't think so for the age. IMO.
Sorry for the novel
:sick:
