Land Rover Disovery Electrical Problems
in Land Rover
where does the ground wire from under passenger side foot well attach to ground stater on 1995 discovery one???? thanks Patrick
thx in advance
Jumping it off starts it.
My solution, I had the dealer DEprogram the rear air suspension programing, END OF PROBLEM.
I would seem the computer kept trying to pump air in the nonexistent system. May this will help.
Ken
not to mention the alaways on check the engine......any ideas
any help
i own a 2000 landrover discovery was driving to work one morning and truck began to loose power then backed fire finally came to a stop and never started again. would turn over but not start. i changed to crank sensor, spark plugs wires and plugs, mass air flow sensor, still no start just turn over. so i just let it sit in the garage for a year cranking it now and then. with in 2 in a half years of sitting i finally put in a ingition coil still no start up also replaced the starter and bought new battery. now it turns only a quarter turn on attempting to start it. it has been sitting in garage since winter of 2010. what could be the issue. the local machnic tells me to bring it in he will have no problem getting it going but im afraid of his price.
