Jeep Cherokee and Jeep Grand Cherokee Lights
in Jeep
1997 Jeep GC i replaced the bulb bacause it melted to the hole where the bulb goes in. i need to take out the lens to get the melted bulb off. how do i get the lens off?
SUVs and Smart Shopper
has anyone replaced or cleaned the lens
Healing Hazy Headlamps
Has anyone experienced problems with this particular light and have any solutions on where to go to find the problem in the wiring?
-Marc
If you have fogging on the inside, I'd suspect moisture.
The dealer just changed the ignition switch to solve that, so far has been working.
Anyone had a similar experience?
Good luck,
Theo
planning on also getting smoked halo headlights and taillights if i find a smoked one i like....tips/ideas accepted
-Marc
Anyone else having these issues?
Thanks much for any help.
Luckee
Does anybody know what part needs to be replaced and location?
I appreciate your help.
Thank You
thank you
The tails and signal lights from the rear left side,don't work properly, if any body have the schematics of the circuit please send me. I try changing the light bulb but still doesn't work.
Want to keep it for a couple more years, since it's paid for and running great still, so have replaced a few things (rusted window trim, failed hood and trunk pistons, minor stuff to keep it in good shape).
Problems we can't find fixes for:
* memory settings (door button or remotes) don't hold the side mirror positions anymore and set both side mirrors to some apparently random setting
* automatic headlights come on by themselves in the middle of the night (full dark, engine off, no key in ignition). also hear relay clicking randomly when driving during the day in full sun
* brakes pulse badly, assuming warped rotors (again). after reading here, will try vented rotors and ceramic pads next. also read about torque settings on lug nuts, will keep in mind
Any help with these problems would be greatly appreciated. Always loved Jeeps, want to love this one again ;-)
Second, Look at the bottom, between the marker light and the front signal light. there should be another screw there. you have to un screw this one too. It's about 2 inches long. You can see that the side light start become loose. Don't pull it. You don't want to cut the wire. Just slow pull it to the side when the screw became loose.
Now, you can twist the light socket out, and change the bulb. Put everything back in the reverse order. Then you are all set.
Hope this help you in any way. It should take about 20 - 30 mins top. good luck !!!!
I am glad i was able to help you!!!
Meghan
Perhaps someone else has another thought. Anyone?
Try asking in Got a Quick, Technical Question? and in Edmunds Answers.
while driving on the road at night the headlights will just shut off. i pull on my high beams and those always work, and when i let go of the switch they shut off again. i timed it, and it takes at least 5 minutes of me pulling on the switch until the low beams decide to work again, and when they do, it last for about 3 min.
please i need some feedback. also, i like to do my own mechanic work, but before i do i always do my homework.
