2004 Town and Country - Turn Signals that activate the wrong side
I have a Chrysler Town and Country Van 2004, Most of the time when I use the RIGHT turn signal, the LEFT indicator light on the dashboard activates. Also, the turn signals sometimes turn off after about 5 seconds of functioning.
Steve
Don
thanks, before I got your reply, I stopped by Autozone and they could order the multi function switch for $50. It be here till tomorrow. They way you make it sound is that I should let a pro install it. I am pretty mechanical but not a pro. Whats your take?
Steve
Good luck with it,
Don
I have the same issue with the left turn signal not working. Now, i work on cars, but right now my brain is frozen on what a BCM is.
Also, I have already replaced my turn signal switch and when I took the cover off i found a plug that was not plugged in to the socket on the steering wheel. AS I have no idea what it goes to, I have not plugged it in. Any ideas?
But good news! These switches apparently fail because they have excessive lube inside that interferes with the contacts. Not to hard to fix yourself. Five screws. First remove switch per this video:
Oh, PS, somebody said you should disconnect the battery first ... Prob'ly to make sure you don't set off the air bag by accident.
