Thanks for your help!
Have you considered taking it to the dealer to ask them what it is?
I would hate to see someone cut off a part that might be integral in keeping water out of some area of the car.
I have had plenty of poor seals over the years and it SUCKS.
Please!
http://www.ajusa.com/cgi-bin/category?cat=CAT_SEAT&session_id=f486cff43cb2f8b18f- f2e5119ba42c88
I am very happy with them, I bought the leatherette. They were easy to install.
If you have had any issues like mine, even if not as severe, please call and register and official complaint.
Call: Honda Motor Company at 1-800-1009, press option 5 to report a problem with your vehicle or dealership and have your VIN ready. It only takes a few minutes to call.
I kinda doubt that Honda will do much if anything about it. Every car is not going to be comfortable for every person; it's just not possible. Just my 2¢ worth.
About 2 weeks later, I did get a reply. It was a letter thanking me because "it is not often that people take the time to bring their concerns to our attention as you have done". I "provided valuable feedback to assist" their engineers for "future guidelines".
They then said that "no car can be designed to fit all people" and that they "do recommend that all prospective owners test drive the vehicle they are interested in extensively to determine the vehicle's comfort and proper fit."
I 'appreciate' their "appreciation", but that does not make my Fit any more comfortable to drive, does it?
What has helped some is the padded seat cushion that I bought in the auto dept. at wal-mart; And, I placed 4 foam pads-the kind that you use for upholstery-in pillow cases and duct-taped them together to place beneath that wal-mart seat cushion. Elegant, huh!! But, it does change the angle that I sit at enough that I don't ache in the hip,leg, and back as much as I used to.
I'm still not happy with the "fit" of the car. But, I think that I can live with it; I certainly can't afford to sell it and buy something else right now. A new car was a hard enough accomplishment for me anyway.
If anyone is interested, the address for American Honda Motor Co. is:
1919 Torrance Blvd
Torrance, Ca 90501-2746
A lawsuit over uncomfortable seats? Puhleeze....
This is why we pay so much for health insurance!
Can you please explain how you popped it out? (Anyone?)
I would like to turn it off for a period of time.
How difficult is it to do?
We are going to the drive in movies tonite with the kids and I plan to park backwards and let the kids sit in the hatch to watch but I cannot turn the light out and I hate to start taping stuff over the light.
Help! Anyone?
I think to take the light out you'd have to remove the whole side panel, right?
I believe the light assembly just pulls out of the side panel. The 2 wires are then exposed and you could splice a switch into the circuit. A hole could be cut out of the side panel next to the light and the switch ( rocker ) could be mounted or in this case inserted.
FYI I tried to switch the back-up and turn signal light locations, but the bulb holder socket and harness wouldn't reach.
Bubba
Wonder if I can modify the pedal to a. reach the floor pan OR b. attach the pedal via a swivel so the bottom end is closer to the floor pan.
Perry
http://motors.search.ebay.com/foot-pedals_Parts-Accessories_W0QQ_trksidZm37QQcatrefZC12QQfromZR40QQsacatZ6028
I can't seem to get my refresh mode right: my front seat back won't lay all the way down level with the back seat. I've rammed the front seat as far forward as it will go, but still no luck. This happens with both the driver's and passenger sides. Help!!
I'll try it, and hope it works!
I'll try this to see if it does the trick. I do hope so!
You're joking right? I think you are...
I find the seats to be VERY comfortable!!!! The only complaint I have is no arm rest, that is really taking me a while to get used to. I drove with my elbow on the arm rest for the last 19 years so its really throwing me off!
Think they would? :confuse:
I can't get a body shop to move the seat because of the airbags.
You can easily buy a replacement seat for any car like a Recaro seat. I have complaints about the Fit drivers seat and it might keep me from buying one. The airbag is not affected unless you are considerably higher or lower than before or things like that. A more comfy seat which is a replacement seat should be just fine. Do a google search and You'll see quite a few of them available for the Fit. There are tuner Forums that also discuss things like this on a regular basis.
sorry for my poor inglish, i'm better in french. :shades:
The dealer says that all Fits are like this and that nothing can be done. Has anyone else noticed this?
I recently had our Toyota Sienna in for service and they checked the A/C by putting a thermometer probe in the vent. Our van only cools to about 60, and they recommended recharging the system because they expect something in the mid 40s.
Today I put my Fit on recirculate, max cold, and put my kitchen thermometer in. It only gets down to 52 degrees. I will be calling the dealer.
Go on the dealer's lot and try one.
MY old vw rabbit wouldn't even go down past 50. How cold do we really need to be?
Just took delivery of fit on 8/30, the a/c output is much weaker compared to my 2000 accord. But since all my cars are parked outside, on a hot day I have to rolldown the windows with a/c on max/recir and after driving a few minutes rollup the windows and I tend to leave it on recir and in the FIT you will get cooled down if you do this.
The Tall and Short of It
I think I threw away the directions, only because they were so simple. Basically it comes in 1 piece with 2 screws. The base mounts directly inside the existing cup holder that's in the rear between the front seats, behind the parking brake. The 2 screws (maybe 1.5" in length) fasten it down pretty securely. And they give you a round felt cover to go on top of the new cup holder (to cover the screw heads). Its extremely simple.
