Chevrolet Malibu Fuel System/Fuel Pump
Hello friends, I am new to this area, I ask for your understanding, as I dont know the " ropes " yet. my question is,,, what is the average life of the electric fuel pump, on a 00 malibu? I had one replaced at around 60,000 mi, a real spendy job at that,,, Thanks
Also was told that the intake manifold gasket was leaking coolant on the front and back (external leak). After searching this forum, it looks like this might be a common problem. Is there more to come on the top & bottom?
Any thoughts?
Not sure your gasket question, but get them replaced.
I once had a sender replaced under warranty on a Chevy Cavalier, the wait was less than 1 hour.
Look up Gibbs LLP in San Francisco.
Malibus are junk. GM does not stand behind their product and that is a shame. I have always bought GM and this was my last one.
http://cf.us.biz.yahoo.com/bw/080326/20080326005392.html?.v=1
You'll have to read the details. It only applies to certain vehicles and not all leaks.
Help!!!
gulick21@comcast.net
have a 2005 malibu that has just started a rough idle or missing in the engine. more noticable while in gear.will do it sometimes and then it won't.it will start and go away within the cycle of a stoplight.any suggestions would be helpful.i think it is water in gas tank.please tell me if i'm wrong.
Replying to: ahinson (Sep 29, 2008 1:34 am)
my malibu has just started running rough or missing.most noticable when in gear.RPM'S go up and down when stopped in gear.it will do it one day and not the next.it will also go away and come back within the cycle of a stoplight.i think it might be water in the gas tank.i cannot feel it above 1500 rpm's.
Has anyone experienced this yet?
I am going to the dealer later to get a wiring diagram for the relay source ... there has to be a problem in the power source of some kind.
did fuel pressure test with adequate results, repalced EGR valve, no effect. replaced MAF sensor which just recently caused check engine light, (check engine light never comes on), no effect. did cause check engine light again after resetting ECM. i did have bad alternator, repalcement of it, no effect. i did get it to stay running for about 5 mins on its own, after starting kept at 2000 rpm for 5-7 mins but ended with same results,
Now i do have the famous manifold gasket leak. just cant afford $700-$1000 repair right now. also have done recent tune-up, new spark plugs/wires, repalced TPS sensor and IAC valve within last 12-15 months ago. im out of money and paitence, any help will be appreciated
Helping my dad and mom fix their 03 Malibu today. 2 months ago they broke down on the side of the road. Some garage towed it and said the battery needed to be replaced for some reason and now also the fuel pump. 700 parts and labor for fuel pump job!! All three of us were concerned, the fuel pump thing seemed coincidental and strange, we gave them paid the bill and let it go. So now, the car broke down in the driveway. Decided the plugs and wires were way overdue, might as well change them finally, we thought it was the problem for sure. No start. After much stress on the heels of the last bill, my Dad looked in the manual in hope of finding something to try. Alas, turn the key to on but not start postion. Wait ten mins. Turn it back off and then start the car. Car started! Now I'm really curious about the last fuel pump job. I made the guy give me the old pump and maybe I'm just an overly suspicious A hole but i'm gonna take that old pump to one or two friends and see if I can get it tested. Let me know if this works for you and how it goes. I'll help more if I can.
:surprise:
your quote: "I have a 05 Malibu LS 3.5L V6. I have been having a issue with my fuel guage. If i fill up my car the gauge will drop to empty. Once i drive and burn some of the gas out it will read full until i get below half a tank. If i sit idle more than a few seconds it will drop to empty. i have only noticed it sputtering one time while idle. any suggestions other than a new fuel pump?"
Hadn't had this problem again until now. Now, it is doing it after the car warms up, and when I pull up to a stop light, or even while I am driving down the road around 35 mph. It sputters, power drops, and then dies. I can get it started after a few sputters, and then drive it short distance, and then it does it again.
Anyone experience similar problems? My mechanic checked the engine but it hadn't thrown any codes and the engine light hadn't come on when it was doing this!
The fuel pressure regulator is contained in the fuel pump module near the fuel pump outlet. The fuel pressure regulator is a diaphragm relief valve. The diaphragm has fuel pressure on one side and regulator spring pressure on the other side. The fuel pressure regulator is not vacuum biased. Fuel pressure is controlled by a pressure balance across the regulator. The fuel system pressure is constant.
