Lincoln LS Tires
I have a 2000 Lincoln LS with about 75,000 miles.
I am on my 4th set of tires. The first last about 35000, the second about 10000 Firehawks, the third about 14,000. I have a set of snow tires as well. I do mostly city driving and I am average driver (no speeding or fast starts. When I pull into my garage, I frequently smell rubber. Any ideas? I love the car but the tire wear is disturbing.
I've used up 3 sets of tires & the set I've got on now has lots of life left in it -- 122K miles.
I've got a '00 LS V8.. Never really found exactly what the PSI should be as I bought my baby used at 38K in '03. Now it's sitting at 85K.
Any insight much appreciated!
You are correct not to buy that comment. Have someone else check out the alignment/suspension. I have had excellent even tire wear with my LS and so have many others.
I just bought my 2005 Lincoln LS back in March. This past weekend I brought it to get the tires rotated since I had already put 9,000 miles on the car. The technician told me that all of the tires are dry rotting and the tread is gone and I should get them replaced before the winter comes (I live in Massachusetts)
I would like a good tire that is decent in the snow and wet grounds and can at least get some good milage out of them before being replaced. Any suggestions?
Also....should I contact the dealership who sold me the car? I bought the car with 21,700 miles on it. I believe the tires are the original tires on the car but the tech said the rot is so bad it doesn't happen like that overnight. I already had a problem with this dealership and had to bring back the car 5 times to be serviced because of bad brake pads and rotors (they gave me a car to drive away that needed all new pads and rotors, so much for inspecting the car before giving it to me!!)
Thank you in advance for your help!
Gina in Boston
I don't want to go back there anymore so I would rather just buy 4 brand new tires, especially with winter coming.
What kind of tires do you suggest?
Thank you,
Gina
Well I got my eyes opened, especially re the Ford/ Lincoln dealer. The diagnosis: needs new ball joints, both sides, and new tie rods. The dealer estimate, which I got in writing, was $519.side for the sealed (and therefore unmaintainable) ball joint, and $ 120 each side for the tie rods; plus total $500 for labor and a necessary front in alignment, another $75. I thought this insane and figured it was time for a new car,but first I Googled the issue and found many, many references to a much less (and better) fix using regular old fashioned ball joints; the parts at a tenth of the price of the OEM dealer parts. I did some calling around to friends and found one who had a friend who had could recommend an "exotic car" ( the frame and suspension are Jaguar)mechanic who looked at the car yesterday and will replace the ball joint assembley with the servicable (not sealed)ball joints with which Jaguar had replaced sealed ones years ago; he's done this in several LS's and Jaguars using not no name generic parts,,,,,,but Jaguar parts. He was also under the impression that Ford/Lincoln had been switching these ill conceived parts as they presented using the Jaguar parts.
A beyond aggravated me found out from the Ford/Lincoln service department and found that this was indeed the case BUT the customer had to suggest the use of aftermarket parts. So my car goes into the Jaguar mechanic Monday. I'll get my oil changed at Ford/Lincoln, it's actually less expensive than the quicky lube places and WM, and in my experience they have not tried to railroad me in to unnecessary stuff, which the quicky type lube places HAVE.
I have not had much beyond routine maintainance done on this care yet, but from now on I will absolutely ask questions first.
