Isuzu Rodeo Speedometer Problem
I have a 93 Rodeo and the speedometer/odometer does not work. I suspect the AT Speed Sensor but don't know where it is located.
Thanks a million for this post. I've been looking at this ABS issue on my 1999 Rodeo 4x4 for a while, and have been waiting to find a post that enabled me to fix it myself. Sure enough, I went about the rear differential, found the ABS sensor, cleared the contact points.........wasn't getting a good charge. Per your post, I followed the electric up to a junction point just in front of the rear driver side tire...I looked close...and there it was...a 3-wire set...(orange, brown, and white)...and the white cable was broken off. Did a similar pig-tail splicing game....and sure enough...ABS light turned off after 100 ft of sub 10 mph driving...
Anyways, wanted to explicitly say thank you for sharing your knowledge. This has helped me fix one of my more major annoyances with my Rodeo with only 92k miles on it...now if I could only fix the damn gas gauge!!
I am not sure what to do next or how to troubleshoot from here. Since the speedometer quit working, the vehicle stalls when you come to a stop.
Any ideas?
The three wire set, does it matter if you have a 2wd or 4wd vehicle?
I want to get this fixed, its annoying.
My speedometer went haywire and now stopped or intermittently works, cruise switch does not work and check engine light came on. Been searching net for places to purchase the transmission mounted Vehicle Speed Sensor (VSS); however, I can find no where to purchase, either new or used. My vehicle is 2004 Isuzu Rodeo, 3.5 liter V6, Automatic, 2 wheel drive. Any help on how to repair or where to purchase would be greatly appreciated.
John
I was told it might be the speed sensor, but I'm skeptical on this. Here's more info on the car.
The ABS is always on, and the Check Engine light comes on and off at times. Back a year ago, pieces of metal came off near the break-disk. I'm assuming it was the ABS. They were grooved pieces.
It appears the shocks and axles need replaced (unrelated issue). The car also bounces at 70mph, I'm assuming this is because of the worn shocks.
Let me know! Thanks.
- just be sure to use up as much gas as you can so the gas tank isn't so heavy when you ease it off, you can siphon the rest out yourself before putting it back on and fill-er-up when your done.
-tank is only held by 4 bolts, easily accessable with a raised vehicle from the rear(take off spare tire if its mounted under the vehicle), hardest part i found was initially wiggling the hoses off the tank. other then that just put a jack w/some plywood(or something to brace it) under the tank when taking off the 4 bolts, ease it down, unplug fuel pump(and hoses going to fuel pump), replace unit and put it back on, reconnect hoses(only 3 of them if i remember correctly, refer to the link above).
annoying gas gauge fixed (totally worth 20bucks and some spare time).
Daryl
