I've had friends with Mitsubishi products. Their mechanics are very happy guys.
The two JD Power studies I mentioned are based on numbers of reported problems.
Also, I too am comparing this SUV to the Outlander. But, as some have stated, I do believe, the Santa Fe and the Mitsubishi Endeavor are the same class of vehicle. The Outlander and the Tucson are in the same class. So, when we all make the comparisons, me included, we sometimes are not comparing class to class.
If you price compare between classes, the Hyundai products win in both cases. Just my 2 cents worth.
The Murano's CVT issues get me nervous. I really like the Santa Fe, and I like spending $7000.00 less!
One question I have not seen addressed or answered anywhere, including the brochure: Do the head curtain airbags have a roll-over sensor, or are they only activated in a side crash?
I think I'm back to buying a Santa Fe!
I wonder where in the dash the navigation system will be in the spring? Might be worth the wait....
Thanks in advance.
Mark
Was your sound coming from the area of those bolts? Mine is definitely coming from the seat back. (See my post immediately above.)
Nissan's CVT only scare me because it is belt driven rather than using a chain with a master link like Ford's CVT. I don't think alot of places know how to work on them so you might have to shell out a fortune if you are out of warranty.
Have they come up with a TSB on the outside temp. gauge problem? I read somewhere that the temp gauge is not accurate, and it has to be re-wired at the fuse box.
How about the lack of front interior dome lights when the doors are opened? The map lights should turn on with the rear dome. You would think that fix would be an easy one, even if the truck was not designed that way.
I did notice a slight alternator type whine through the radio. When the radio was turned off or down, the whine was absent.
It did ride nice and was comfortable up front. I love the interior touches and blue back lighting. Being a car nut, I am very impressed with the truck. Who would ever have thought that a Hyundai product would be impressive???!!!
Competition is a wonderful thing! And speaking of competition, I checked out an Outlander yesterday. Nice job, but I didn't like the front or rear styling. The front seats did not have as much leg room as the Santa Fe, but the rear leg room seems to be more. But that might be because the front seats don't go back as much as they do in the Santa Fe. But since styling is subjective, some might like it. But the Santa Fe seems to have a much more upscale feel and look to it. My 2 cents.
Mark
No interior dome lights which I thought was weird but I have a sunroof so I thought that was why.
No problems at all with the radio. I do not detect any kind of whine and I am very sensitive to sound. If you buy a Santa Fe make sure the service dept. engages the auto locks--I have to go have mine done.
I have to say that so far I love love love this car and we test drove everything! My husband is a BMW nut so he was trying to talk me into the X3 (which doesn't even have a 3nd row option--I got the 3nd row) but with everything that the Santa Fe has that car is $20,000 more!!!! My husband now loves the Sante Fe as much as I do!
-AWD Outlander will tow 3500lbs, Santa Fe - according to Hyundai brochure - 2000 lbs(with trailer brakes, 1650 lbs without.
-Keyless system FAST-Key in Mitsubishi allows you to unlock all doors and start the car with key in your pocket or purse, think when you cary your baby or bags.
-Leave under the floor and glovebox compartments alone. Cargo volume is 39 cu ft in Mitsubishi and 34.2 cu ft in Hyundai behind second row(*again Santa Fe brochure), but total cargo (with second row down) in Hyundai is 78.2 cu ft
and 72.6 in Outlander.
And don't start with I' have friends with Mitsubishi products. My wife owned 97 Mirage for seven years, no single problem (it was made in Japan like the Outlander is)
JD Powers again is based on reported problems people have, not always mechanical. One more example - I can't figure out how to operate I-DRIVE in BMW, so it is a bad car.
Sory for the long post.
I don't see why the front map lights need to come on when I open the door. The rear dome light provides more than enough light when entering the vehicle. If I ever have a reason, I can easily reach up and press the map light on (so far I've never felt the need). Incidentally, the Lexus RX350 lighting is set up identically to the Santa Fe (rear dome light only).
I have absolutely no static or whine in my radio. In fact I love the quality of the standard Santa Fe radio. Great sound quality both with FM and with CDs. I can't really tell any difference from our RX350.
It is hard to be a small player in this world. When Chrysler needed their engines and small cars, back in 90', everyone was happy. Now they hang out with Mercedes. Guess Mazda has more luck. 3rd row seat in Outlander is a joke, but I don't need one anyway. Decisions, decisions...
When the engine's cold, the mileage is much worse, usually in the 15 to 16 mpg range for city stop and go driving. It takes at least 10 to 15 minutes of driving to thoroughly warm the engine and exhaust system. The mileage then gradually creeps up to 18 to 19 mpg in city driving. So if you only do short trips in your Santa Fe, expect worse gas mileage.
Similarly, if I go onto the expressway, with the engine warm, my mileage will increase to 24 to 27 depending on speed and which way the wind's blowing. So how much stop and go you do vs. non-stop cruising will radically alter the gas mileage. 4000 pounds takes a lot of energy to get moving.
Finally, I find I can squeeze an extra mpg out of my Santa Fe just by driving with a light touch on the pedal. Accelerating slowly and coasting up to the red lights. I'm sure I could easily drop the mileage 1 or 2 mpg by driving with a lead foot. I have never driven that way so am not about to test it out.
I'm happy with my mileage, which has gotten a little better than when I first purchased the vehicle. I'll see if it keeps getting better as I put more miles on it.
2007 Santa Fe AWD Limited with touring and premium packages
Dark Cherry Red with beige leather interior :shades:
Mark
Reading some thread about rust proof, and I am more confused with the following points of view.
- Today's car is well made. There is no need for rust proof. All you need is to wax the car and wash the car regularly in winter.
- Drilling hole on car for rust proof will cause more rust eventually.
- If you want to keep your car for 10 yrs +, take the car for rust proof.
Also, when I was signing the paper at my dealer, the dealer was pushing me hard to install a device that would stop car from rusting for $900 CAD. A similar device in Canadian Tire cost $350. Not sure about its effectiveness.
Any suggestions?
Mark
I find slight hesitation upon moderate acceleration frm stop. Similar to "turbo lag", anyone else?
Also, headlight don't seem to "go" far enought donw the road, go to high beams alot.
Lastly, is the oil capacity correct in manual? Have a 02 Elantra that manual read 4.5 qts., actually takes 3.5 qts.
Thanks for your time.
As for the headlights I had the same issue. Dealer adjusted them. Much better now...Good luck.
I just got 2007, the drain is easy but I assume that the "sheild" must be removed to get to filter. Has anyone changed O & F? Also, is manual correct on amt of oil needed?
Thanks again.
The other thing I noticed in the test drive is that I kept the driver side temp at 72 dgrees but it was still blowing cold air even though the outside temp was 53 degrees. I asked the salesman about it and he was also not sure why it was doing that. But after setting the temp at 74 degrees it started blowing warm air. Anyone noticed this ?
I also find the blower fan to be extremely quiet. Overall, I'm very pleased with the system (as well as the rest of the vehicle)
I would recommend the new Santa Fe. As a matter of fact, I would want one myself
Dude, what are you waiting for, Go get one....
Best of Luck tooya.
