1. OFF
2. SPEED-LINKED - 20, 25, 30, 35, 40 Km/H
It states there is no auto unlock feature for the SF.
I do not see a TSB for the door locks for the 2008 model.
Chris
Do you have a shop/installer that you can recommend in the Denver area? That's where I live ... and I am planning to upgrade the speakers on my 2007 Santa Fe.
Cheers!
-Bokonon
The speakers and install ran me about $450 - which is not cheap, but I liked the store and the install people, and decided to give them my business. Their product recommendations were dead on, and they did an excellent job with the installation (which involved removing the door panels, as well as drilling new mounting holes and replacing the crossovers for the tweeters in the front doors - all of which was more involved than I wanted to get in my drafty, grimy garage during winter).
The stock speakers were made out of cardboard. Not impressive at all.
I didn't get an amp installed. I am running the new speakers off the stock head unit. For my purposes, I don't think the amp was necessary. The improvement in sound quality simply from replacing the speakers was very impressive, and is immediately noticeable.
Cheers!
Worst comes to worst, you could always opt for the speakers now, and add an amp later if you were dissatisfied.
BTW - check out the product ratings and speakers that are available on Crutchfield's website. They also have technical support staff that can provide recommendations. If you purchase equipment through them, they can also refer you to an installer in your area. They might also have views on amplifiers. Just an idea.
Sounds like you are getting a good deal on that package. Keep us posted on how you like the results when you get it installed.
Cheers!
Ryan
2024 Ram 1500 Longhorn, 2019 Jeep Wrangler Rubicon, 2019 Ford Mustang GT Premium, 2016 Kia Optima SX, 2000 Pontiac Trans Am WS6
The installers that I used seemed to think that the Santa Fe's audio head end was fairly good quality, and had adequate power if you connected it to some efficient speakers. And I am pleased with the results on my car too. This is a relatively cheap fix, but it makes a big difference.
I just wish that Hyundai (like virtually all car manufacturers) would use better speakers to start - it would only cost them a small amount, and would make a big difference in the car's appeal ... at least to people like me. But I suppose that as a marketing tool this would make upgrading to the premium sound systems less appealing.
As it turned out, we moved to southwest Washington state (just north of Vancouver) in May of this year. Only after actually moving did we learn that measurable snow is very rare here. It sounded like unless we were to venture quite a ways from home the Santa Fe would never come out of FWD mode.
Fast forward to 12 days ago. It began snowing and hasn't stopped much since. As I type this we have a foot or so on the ground in our yard. Since I'm originally from Wisconsin, my first thought was, "No big deal." WRONG! Unlike Wisonsin, Washington isn't equipped to deal with snow. As a result, most streets don't get plowed. The results are a lot of people who simply can't get around. My wife even got stranded in her Mazda 3 - we ended up having to buy chains and install them just to get her car home.
The Santa Fe, however, has been a completely different story. The thing has been completely unstoppable (WITHOUT chains). Uphill, downhill, snow, slush, you name it, the Santa Fe has handled it completely without effort. When on city streets I engage the AWD lock; otherwise I just let the automatic system work its magic.
Bottom line: If you're contemplating getting one of these things and need it to be great in snow, look no further. It's absolutely fantastic. Not only that, after owning it for 19 months and putting 19,000 miles on it, it's been nearly 100% flawless and has stayed tight as new. The only non-scheduled service has been adjusting the parking brake cable and replacing a squeaking rear wiper motor, both covered under warranty. The dealer up here (in Vancouver, WA) has been first-rate in every way, too.
You've come a long way, Hyundai. Nice job.
I had a Mazda 3 before I switched to the Santa Fe. The 3 got stuck pretty easily due to the low ground clearance. I would get hung up after parallel parking on some frozen snow in NYC.
You could go the FM transmitter route, but I've used them as well and the sound quality varies from passable to unlistenable, plus you have more stuff festooning your console.
I would go with something integrated. I thought the look/feel of my dash would change significantly but it really didn't.
The front bumper is made of a flimsy material to break away in case of an accident, which I would imagine makes it easier for the brushes on a car wash to lift the plate upwards, especially if they used small mounting screws.
We got 39,000 out of the OEM Duellers but want to something better for less.
What have you put on yours?
Suggestions? Any to avoid?
John
http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Eagle+Respon- sEdge&partnum=36VR8RE&vehicleSearch=true&fromCompare1=yes&place=1&speed_rating=S- &speed_rating=T&speed_rating=U&speed_rating=H&speed_rating=V&speed_rating=Z&spee- d_rating=W&speed_rating=Y&speed_rating=(Y)&minSpeedRating=S
Goodyear cannot touch this tire in the price/comfort/performance categories. The treadware is 420 and I picked them up at a local tire place for $105 a peice. I know Pepboys carries this brand too.
Thank you for the replies. Much appreciated.
Have a great day.
John
FWIW, 39,000 out of an OEM tire ain't that bad....
IT IS GR8 CAR............
