Nissan Pathfinder Tires and Wheels
SAeveral other makes use the 6 stud, 5.5 inch space wheels. Chev Silverado and Toyota 4x4, for example.
I have a 1993 Pathfinder and would like to use some 16" Toyota or Chev wheels. Will they fit?
Will a 255 75 (or 70) 16 tire fit ok?
Anyone else having this problem? Had the tires rotated and balanced but that won't fix this problem. What would be the next step -- alignment? check the suspension?
Bridgestone Alenza's are available in your OEM size. Cheaper than Michelin C/T's (which I just bought) and they have a very favorable Tire Rack rating. Whether they're right for you depends upon how you will use them.
I had the same issue with the stock Radial long Trails, but they needed replacement anyway after 35k. Tires are rotated and balanced every 5k.
i've recently purchased my 07 PF, SE and am not satisfied with the small 16" wheel/tires. I'd like to go up to 18" but wasnt sure how well the vehicle would handle this size. I know the LE's come with 17" and TireRack.com offers up to a 20" for this model. I'd also be curious to know if there is a certain brand of tire that would improve the ride. I figured I'd use my 16" in the winter since they appear to have a pretty good tread so these would be more for clear weather road conditions.
john
I commute on two-lane paved roads that have many turns, average speed 45mph. Because of the turns, I have never achieved more than 45K for each set of tires, 200K miles total for the vehicle, I travel via freeway to mountain spots during the summer & get into some bumpy, light rock terrain but no serious 4-wheelin'.
After researching Tire Rack, I have narowed the choices down to these:
- Avon Ranger TSE
- Bridgestone Dueler H/L Alenza
- Continental Cross-Contact LX
- Michelin LTX-MS
- Yokohama Geolander HT-S G051
I had the Michelins once before and got only 45K out of them. I'm a bit reluctant on the Bridgestones because another Bridgestone model came with the vehicle & weren't very good.
Opinions. anyone?
Brought the tire to COSTCO where I purchased the set of 4 tires. The service manager replaced the tire without question - it had to be ordered. But the damages to the vehicle had to be handled directly with Michelin. They required me to ship the damaged tire to them since their conversation with the Costco service techician initially indicated that it was "driver error" . I sent the damaged tire to Michelin. After their technicians inspected it, they contacted me and said the tire was a Run-Flat problem, not tread separation. Incredibly, they offered to pay a prorata share for a new replacement. I called them and told them how stupid they were, since Costco - backing the products they carry - replaced the tire for free immediately. I wanted to recover the costs to the dmaged tailpipe and rear mudflap from Michelin. Supervisors were contacted, but no chnage in their position. They sent brochures on Run-Flat tire damage. I don't have any expertise in tire failures, but I have been driving cars for over 35 years, and never experienced anything close this. Any intelligent person examining the tire (which I still have for I forced michelin to ship it back to me for further investigation), could see how the entire tread just ripped from the sidewall. This occured around the time that some of the Tire manufactures who produce the tire in China were experiencing major flaws. I'm not certain, but one of those Chinese tires was the Michelin LTX.
Does anybody know where I might be pursue this investigation - objectively?
First, check your maintenance records and see when the last time the tire pressure was checked and what the values were... Also it would be good to know what the tire pressure in the other three tires were immediately after the accident (but not essential). Be sure they were checked with a good tire pressure gage. I took mine to work to make sure it was calibrated, but some of the newer digital ones shouldn't need this (supposedly).
Second, check and see how often the tires were rotated and balanced, and what records you have of each event.
Third, compare the data you have collected against Nissan and Michelin recommendations. This is the first thing the manufacturers will do, if they start an investigation.
Take as many detailed pictures of the damaged tire and vehicle as possible, before anything is repaired. These will be essential for recovering costs later.
You may be able to take the tire carcass to an independent tire dealer for evaluation, but I would approach this diplomatically so the dealer doesn't think he will end up in court.
Hope this helps.
First, thanks for your response to my tire post. My tire guy suggested that I go with the Toyos again & I decided to follow his advice. Next time I'll switch if I get lousy mileage with these.
Re your Michelin problem: My initial act would be to send them a demand letter with copies of all the documentation you have. Make sure you sign & date the letter and give them 30 days to respond. If they fail to respond or do so in the negative, find out if they are members of the Better Business Bureau. If so, file a complaint with the BBB and see if they respond favorably; if not, file a complaint with your local district attorney's office & wait for Michelin's response.
Should you fail to receive any satisfaction from initiating these steps, then you may want to consider litigation. You can check out your state's dollar limitation amount for filing a claim in small claims court. No attorneys are allowed there and it's just you against Michelin. From the facts you have mentioned in your post, it appears that you have a good case and I wish you the best of luck.
By the way, I have a new inquiry for any reader who cares to respond. I recently discovered that the sway bar on my '01 PF LE has broken in half - that's right, clean in half within the curved section & not near the bushings where greater stress occurs. I talked to my factory-trained mechanic about this as well as a friend who is a former Nissan service manager, and both have never heard of this happening. I'm thinking this is a design or manufacturing defect rather than a mere worn-part repair situation. Granted, the vehicle has 200K miles on it now, but I hardly ever take it off road and have never hit anything that would initiate this breakage.
Has anyone ever heard of this happening?
I guess I will rethink a Michelin purchase in the future. I just Thank God that my son didn't "flip over" in the Pathy with a blow-out like that at 65MPH!!!. says something significant about the Pathy too!! There is no traction control or ESC system on the 2001.
THANK YOU.
ROWELL
In addition to the more or less stock tires he also has 4 studded snow tires (in my garage) which he has no need for.
He want's to trade/sell the regular tires and the snow tires (rims and all) for oversized rims and tires.
I won't go into the merits of what he wants to do, that's his thing. I am interested in getting the snow tires out of my garage as quickly as possible. He has agreed to let me post them on Craigs list.
The tires are radial WINTER KING P235/75R15 108Q M+S. The rims are (factory) painted white enamel with a red and blue pen stripe around the circumference. I don't think either the rims or the tires have been used much. The rims are in very good to excellent condition and the tires have excellent tread and, as far as I can tell, no missing studs.
Is $350 a fair asking price?
SUVs and Smart Shopper
Latest, I just took truck to dealer "Coral Springs Nissan" from hell, 30,000 mile service, and actual miles 29,500 mile. I ask them to rotate the tires, they say really not enough tread, three tires have at least 4mm, 1 has 3mm. I know why odd, when I constantly had tires rotated. This truck had the classic problem of, every time he hit a twig or bump, the front wheels shook, I told them several times. Eventually @ 22,500 miles they found tracking had a problem & needed an extended bolt. They now tell me need new set of tires. 29,500 "Need new tires", outrageous. Should get 50k on tires. Anyway, I pay & insist on rotate tires, they sell me another balance deal. Oil & Rotate $95.
Surely tires should do better then 29,500 miles.
I also tell them rear trunk lid, needs new struts, does not fully open, so constantly hit head. Service writer from hell says "no it’s fine". I refuse to deal with this writer, they get me another one. End of day, they oil struts, "See if that works, if not we will see about replacing”
Is Coral Springs Nissan a bad dealer or is it an institution Nissan thing. Try to never fix the problems.
Of course I still have the Tranny problem, rattles in doors, front windows that don't open properly, noisy wipers, tinny woofer.
Reg. Frank R.
Reg.
i will suggest... setting your PSI doing the white chalk line test... go to smooth paved parking lot..... take a piece of chalk and draw a line across the tire from the inside to the outside... you can do 3 to 8 lines.. then drive a little bit forward and watch to see if line is getting worn even....... if too much psi.. or too little will show ..... edges wear out faster or edges stay even and center of tire is worn ..or lighter .
sounds dumb but .... each truck weighs different... each tire needs to be set according to how much weight is on the tire.... the chalk line test will tell you the exact PSI the tire is asking for..
good luck
