I have a 4WD 5sp 02 CRV. The shift feels wonderful. It is precise, smooth and effortless. The only problem is that a sixth gear is needed to reduce the rpm at high speeds. Currently at 5th gear, CRV revs at 3000 rpm at 60 mph, 3600 rpm at 75 mph. Unfortunately my CRV operates mostly at 75 mph which is one of the reasons I can only get 24-25 mpg.
I would only consider the VW TDI as a second vehicle to the CRV.
I've got as high as about 32 mpg with my 99 EX auto. Have also pulled a large 17 foot boat with 90 hp motor with it, but was against a stiff breeze of about 30mph and had to stay in 3rd, so it was a little touchy.
Currently in Canada diesel is about 50 cents a gallon cheaper than gas ( gas is heavily taxed here
The picture above shows the rear view aid. Looking at it:
-On the bottom left, you can make out part of the spare tire.
-On the left edge you can make out the pole and its base that's located 4 ft behind the spare tire.(see below)
-On the bottom edge you can make out the snow about 4 ft behind the vehicle on the ground.
-Typically, backing into a spot with a car behind me. I find that I can get to within 2 feet before the leading edge of it's hood dissappears. The taller the hood, the closer I can get before it becomes a blind spot.
Here are a few pics looking back through the inside of our CRV. I drove to my wife's work location, only 3 miles from our house. (They're both on base) The inside pic makes the view a little more distorted than it actually is. I tried using the flash, but that pic was worse than this one without the flash.
The aid itself is only 6x8" and doesn't block much of the rear window. I placed it offset to the driver's side, so that I could still see it through the back. Moving it too close to center brings the spare tire in too much. My wife is only 5' 2", so putting it down and to the right into the recessed portion of the rear window made it hard to see through the rear view mirror. Otherwise that would be a good place for it, and the spare tire would entirely dissappear.
Hope this helps a few of you out there.
The body styling of the Sorento
The use of interior space of a CRV
The reliability of the CRV
The Accord's V6
The fold down front passenger seat of the Vue
The gas tank of the Suburban
The side head bags of the Vue
The third seat configuration of a Tarsus station wagon
I have a question about tire rotation on my 2002 CRV. I want to rotate and include the spare haven't had any spares but donut tires for many years from what I remember when I rotated with a spare tire you took the front left off and used that as the spare and put the present spare on the right rear. Is that correct or does Honda have another recommendation? Nothing in the owners manual on this but from what I read in your posts you have a pretty good knowledge on these vehicles.Thanks.
GGy - What I like about my 02 5-spd LX: short throw, generally smooth action (except when engine is cold, plus some recurrent clunkiness going into 3d, at least on mine). What I don't like: not as easy (yet) to achieve very fast, seamless shifts for lane acceleration, and no "6th" gear for higher rpms.
Some of what I'm experiencing with shifts is probably that I'm still adjusting to the CR-V feel -- my Suzuki is an entirely different rhythm and feel manual (Suzuki). Still, after 3 months, I'm beginning to wonder about why I'm having trouble gauging quickly where the "sweet spot" is for each gear, esp. 3d.
I agree with someone else who posted gas mileage: My 02 5-spd probably does get better than 25 mpg at 60 - 65 mph, but since my car normally travels at 70+ on highway, the best I can get is 25 - 26 highway, 23 - 24 town. Mountain driving gets me 26 - 28 mpg even at high speeds (pressure difference). I keep my tires at 32 - 35 psi, so I can't blame low tire pressure for the differences.
My impression is that the current and near future passenger diesel engines are as clean if not cleaner than the gasoline engines. Yes the EPA recently released a "report" stating that they SUSPECT diesel exhaust to be carcinogenic. I would expect all petroleum products to be harmful. I would like to see more scientific studies done of the complete cycle emissions of gasoline, petro-diesel, and B100 usage. Some studies suggest that the tailpipe emissions of newer gasoline powered cars are cleaner than recent diesel engined vehicles. A snapshot does not tell the whole story. Gas exhaust purportedly has smaller particulate matter that can penetrate deeper into the lungs and can float for several hundred miles where as diesel particulate is larger and usually falls to the ground within a few hundred feet. Particulate traps are being added to diesel engined cars. NOX is also being addressed. B100 eliminates something like 90% of the carcinogenic aspect of petro-diesel. "noisy, extremely dirty, smelly diesel engines" is an image of the past and of older technolgy on trucks and buses. New regs. passed 01OCT02 for diesel engines and low sulfur regs. in 2006 will both go a long ways to improving petro-diesel emissions. 30% or so of new cars sold in Europe are diesels. Higher gasoline prices and concern for greenhouse emissions are the driving factors. Batteries are not environmentally benign. I expect near term future diesel engines will be cleaner than gasoline engines at the tailpipe and over the complete cycle from fuel manufacture, fueling, and usage. What is doing more harm to me and the environment? I invite comment. I'm trying to determine which power plant I'd like in my next car/SUV/wagon.
I was watching TLC (or was it Discovery?) where they basically said that we're like the inhabitants of Easter Island, but on a much larger scale. By the time the Europeans discovered them, they had used up all of the resources on the island and resorted to cannibalism. We're doing the same thing and the "end" is nearer than what most people suspect and hope. The piece was a bit too pessimistic, but nonetheless true.
The gearing is low, which is great for around town driving. I do find myself searching for a 6th gear when speeds hit 70+ mph. I've been happy with it over the last 60K miles and think it's contributed to a higher average gas mileage. I tend to get 28mpg around town and as high as 30mpg on the highway. Though, expect less if you typically drive 75+ mph.
The only time I wished I had an automatic was off-road, trying to climb a steep dirt trail. The CR-V had all the traction I needed, but first gear wasn't low enough and I kept stalling. The auto tranny would have given some slippage and I would have got up the hill. But that's only happened once in 60K miles.
Recently there's been increased concern that geologists have erred in "peak" of oil; that is time when we reach the midpoint of our oil supplies. New estimates place peak at end of this decade instead of 40 years down the road. After peak, oil prices will only go up. Now that's scary.
Fuel cell vehicles will be mass produced in the next 1 to 2 years. Honda has a FC ?? in test markets already, and has announced production plans for 04 as I recall. Promise of fuel cell technology was to be able to provide home energy generation plants at reasonable cost.
No, but I stayed at a Best Western.....
Inkie - Off the top of my head, I do not recall the exact pattern for a five tire rotation. You might try tirerack.com or another retailer. They often have consumer information like that.
01r1 - I think what you needed was a low gear transfer case. The manual CR-V's first gear is the lowest I've ever seen. Although the automatic may give smoother power delivery, it is geared much higher.
The warranty of a Hyundai
The side curtain air bags from a Passat
The AWD of a Subaru
The VSC of a Toyota
The price of a Kia
And I'd replace the 3rd seat from the Expedition for that Taurus - it has twice the space.
-juice
Yes, I agree, if you do much of that, you'll need something with a low range.
Actually, petroleum is from plants. Sinclair oil created the myth with their dinosaur commercials (which I read about in ANCIENT texts! ;-) Moonkat will verify this as he is known to stay at Best Westerns! :-)
* Retractable 3rd seat from Pilot or MDX
* One piece lift gate (minivan type) with power rear window from 4Runner (Don't like those two-pieces type from Land Cruiser/LX470, BMW X5 and others side-swing type from CR-V, RAV4 when it's different to load stuffs from one side.)
* Integrated tow hitch from Grand Cherokee
I already installed a backup-aid that displays the distance from the closes obstacle- but a visual confirmation would be safer.
I wonder if you can take it off or move it at will or is it permanemt- also -can it be affected by the rear defroster i.e. melt?
How much? any web store?
The newer, cleaner, quieter(?) diesel engines for passenger-type vehicles sound interesting. I just haven't read anything that convinces me that they run cleaner or more efficiently than hydrogen or electric hybrid, so diesel just means another version of "petro-" to me.
I would love to find a well-equipped, efficient, powerful small SUV that uses a clean, recyclable power source, so I can say "Shove It" to Big Oil. That would be my dream carriage. Maybe in my lifetime?
I think Honda did a good job with the '02 CRV. The "Ideal SUV", I like Juice's (Post 9320) side curtain air bag of the Passat, Varmit's (Post 9319) Accord driver's seat, and for fun (Post 9323) Lok888's power rear window from 4Runner. On a realist note (rare for me) I know a man who has a 4x4 Suburban. He believes that the bigger vehicle is safer than a CRV. I would like Honda to know that I would be willing to pay for the side curtain air bag to help protect my passengers and me from these larger vehicles.
One of the things I like most about the CRV is the amount of backseat passenger legroom. I am 6'2'' and in many vehicles when someone is behind me I have to slide my seat up for them to have room for their legs. The CRV has the backseat legroom of a ML320 (I like this vehicle but I really cannot afford it). The legroom issure is very important to me. I want my passengers to be comfortable.
On fuel, only when the price of oil goes up will alternative fuels be an option. I am surprise that England has not done more with alternative forms of energy with gas costing so much there. I realize thier gas price is mostly tax. IMO in the US gas is cheap. That is why we have the Suburban and Expeditions. Please, Suburban and Expeditions people don't flame me. I have a friend with a big family and a camper trailer, this vehicle is perfect for his family. Again IMO, when the cost for a fill-up is $200-250 vs. $60-80 buying patterns will change.
Honda has a 5-dr Civic with a CTDi in Europe. The European Accord is also getting a diesel engine. Any word on when the States will see a gas/electric hybrid CR-V or any diesel engine choices? Juice, Tidester, Varmit, Bueler, anyone?
'02 CR-V EX first two tanks 23 and 21 MPG.
I wonder if the new 4Runner still has that power window. I agree it's a nifty feature. I like lift gates because they give you shelter in the rain.
And it is neat that Jeep found a way to integrate a tow hitch with a unibody frame.
At least the big SUVs are now getting bumpers compatible with cars. That should be a requirement, though.
How about adding "Insight EPA mileage figures" to our wish list? :-)
-juice
Here in NA, they figure cars will go from ICE, to hybrid, to fuel cells.
BTW, I have read of no real plans to make a hybrid CR-V. The only thing I've seen from Honda has released was over a year ago and stated that they would build a hybrid version of the Pilot, CR-V, or Accord depending on how well the hybrid Civic sells.
Think about it carefully - you would probably never recover your investment, since fuel costs aren't that high to begin with. You might be stuck with a huge battery swap bill in 3-5 years, who knows, that could kill whatever fuel savings you had. Would you really risk it?
Let's do a survey, would you pay roughly $26 grand for a hybrid CR-V EX 5 speed? How much would you really be willing to pay?
I say if the feds had a $3000 tax refund instead of a tax deduction, it would totally be worth it for the extra range you'd get.
Would you just get a Pilot instead for that price? I imagine Civic hybrid buyers are in a similar situation if they look at Accords.
-juice
If I had to replace the '92 Civic VX (37+ MPG) next year I'd be torn between getting another CR-V, Subaru Legacy wagon, Outback wagon, Forester, and the VW Jetta wagon TDI. Good to have choices. If only we had more engine choices. 2006?
The TDI is about $1300 than the gas 2.0l. To me that seems like a reasonable amount of money to double your range. Even then the 2.0 probably outsells it 10 to 1 (just my guess).
So would a $4000 premium on a CR-V would be a mighty tough sell. Depending on your tax bracket, the most you could get from a $3000 deduction, in a 40% tax bracket, is $1200, so it would still cost you $2800 out of pocket.
The lean burn VX didn't sell that well, did it? Remember the CRX HF? No? I bet you remember the Si. :-)
Besides lean burn, there is direct injection. I'd like to see that become widespread.
-juice
I don't know about Harmonys, but Yoko Avid Tourings are noisy on anything but smooth pavement. A better choice for CRV would be Yoko Aegis LS4s. Aggressive tread pattern, though surprisingly quiet and comfortable tire at Avid Touring prices. Also very good in snow and wet; more of an off-road tire. I found the Tourings to be excellent handling - sharper turn-in than Energy MXV4 but thin tread left me feeling they are not good for heavier vehicle. And don't think of going off-road.
Honda sold 3788 Insights in 2000, 4726 in 2001. That's not even a dent.
Civic hybrid should sell far more, but still, they sold 331,780 non-hybrid Civics in 2001.
-juice
The tires look much beefier, and performance has not been sacrificed.
What brand, model?
I put a set of Michelin Arctic Alpines on my 02. They actually handle better then the OEM tires, and they are quiet. I would have expected the opposite for these tires because they are made for winter conditions. I should take a picture of my CRV next to another one with the stock size tires on...
Here is the rumored list of upcomming hybrid SUV's....
Ford Escape
Honda CRV
Honda Pilot
Lexus RX300
Personally, I don't forsee the federal government pushing for greater fuel economy requirements. IIRC an article recently noted that average fuel economy in the US has gone down in the past few years. But our little world of cheap fuel may not always be that way.
link
Now imagine 25-30% mpg gains from the use of hybrid powerplants. It would take years to fully deploy, but we are looking a scenario of a similar reduction in oil use within a few years. The downside includes the initial cost requirements and long term damage to the North American oil industry (and sub-industries) as well as certain changes in the geo-political landscape.
Whoa - this is getting way too deep!!
When we replace the regime we will surely get more oil from Iraq and some say the price of oil per barrel could drop from $30+ to $10-13.
I met Scott Ritter (former head UN inspector, and American Republican) the Monday before the Senate and House voted on the Iraq resolution and since then I have become more skeptical of why Bush wants to remove Saddam.
