Toyota Sienna Noises, Rattles, and Squeaks
I have a 2007 Sienna LE with 10,000 miles on it.
I have this hum noise (no clicking or rattling) just constant pretty loud noise when accelerating.
It only happens when I am going at lets say 40 mph (about 65 km/hr) and engine is at 2000 rpm and then I accelerate so that the rpm goes to about 2500.
The noise gets lauder as it goes to higher RPM.
But note that when I am at 10 mph and engine at 2500 rpm, noice is not there. Similarly when I am driving at 70 mph and just cruising (rpm at about 2500), noise is not there.
It really only happens when accellerating at 3rd and 4th gear. Radio or any music that can interfere is off and I think the noise is lauder on the passenger side.
I went to the dealer and he told me that every sienna has this and the noise is coming from air intake (engine needs much more air when accelerating and that's the noise). I understand that more air is needed when accelerating but how come it doesn't do that when i am accelerating at 10 mph? and it's pretty laud, to the point where it makes me crazy.
What are your thoughts? Do other 2006/2007 siennas have this?
I will take it to the dealer again but I have a feeling they will say the same thing and I would like to go in with some ideas, more educated
Thanks in advance.
Hubert
Thanks in advance.
Hubert
Toyota did add some insulation to the firewall and to the door sills to compensate.
Just a thought.
Sorry, not me. Plan to keep my car a long time . . .
but on a serious note I am going to test drive new siennas to see if they have it too.
If there is anyone else that knows more info about this noise, please share
I have taken it back to the dealer a number of times. The technicians have all confirmed the noise is excessive and have tried the following:
Tightened air intake assy
Changed the Exhaust system
Replaced the Air intake assy
Loosened all engine mounts and tried to adjust engine in cradle
All the above DID NOT resolves the problem, so they reported to SE Toyota for their technical specialist to investigate.
He arrived and confirmed noise was EXESIVE and I was informed that he was going to file with TOYOTA ENGINEERING and that there is NO fix currently available. He would NOT give me the reported reference number to Toyota Engineering.
Since then I have spoken to Toyota and raised a Case number so I can update on the problem. But after few days they have contacted me and said there is NOTHING WRONG WITH SIENNA and that the noise inherent. I was NOT happy with the feedback and they have asked me to take up the dispute settlement program
I am disgusted with the feedback as four Toyota technicians have all confirmed the noise is excessive (They would not be happy with this excessive noise in their car)
I am not sure where to go from here!!!!! I wanted to work with them but they have washed their hands
Thanks for your message. Since my original post I took it to the dealer and they said nothing is wrong with that noise, they said all of them do that.
I didn't have time to go for a test drive, but few days later I did take one of their new cars and noise was not there.
So you are right, they are trying to cover things up here but I am surprised more people don't have this problem. It is really bad noise, and clearly something is wrong with it - i have a feeling that by the time it gets to 60,000 miles, the van will be a junk.
I will now take this officially to the dealer and will try to update you - if you hear anything from them as well, please let me know.
By the way, I am in Toronto, Ontario. What about you?
Take care,
Thanks very much for your message. I guess we will have to get used to it as well, but what bothers me is that this noise is only happening at certain speed and certain rpm - it's just not right.
However, in Car & Driver tests, Sienna was still the 2nd most quiet van at cruising speeds.
Toyota added sound insulation to the firewall and under the doors to compensate somewhat for the timing chains.
Timing belts have a change interval, chains don't, so the 2GR is also lower maintenance.
Here's a pic of the extra insulation from Toyota.
in my mind these changes would have nothing to do with why there is _NO_ noise when driving 40 km with 2200 rpm vs driving 80 km with 2200 rpm with a weird NOISE.
And most importantly, why this is not happening on all 2007 Sienna LE's - just very few.
Sounds like something is out of spec with yours. See if you can get a tech to ride with you to demonstrate the noise under those conditions.
Mine is quiet, so I haven't experienced what you describe. Knock on wood, it's been completely trouble free, though the dealer did forget to screw in my antennae at delivery.
I know it's not easy to isolate delicate issues like this. I need someone who understands the vehicle and how it's put together. I don't think a simple part change is going to fix it.
Weight? Tires? Not sure why, but that what I (and others) have observed.
This is my first and last Toyota.
Jacek.
So, about 4 months ago, while breaking, hitting 20-25mph, a dinging noise starts...and as I continue to break, it gets faster as I break until I stop. It has been in the shop 2 times to figure it out. 1st time, they resurfaced the breaks...then they took the breaks apart. They said nothing is wrong and the noise isnt causing any problems with the car....Obviously, Im quite upset since then noise is there and why it cant be fixed, I dont know! Can anyone help me with this?
That said, how long is it taking for these rattles to become apparent? While I would expect body creaks and rattles to increase with age, intake and engine noise should be evident early, barring a mechanical failure.
For many ppl this will be something that they are willing to accept but not for me. I drive fast, often on the h-way in the range of 140 km and this is about the 2500. There is no way that anyone will keep it at that rpm because it is just too noisy. I have 2 choices go slower or faster. I usually choose the second option. In the city, with normal driving the van changes gears just before it hits 2500 or right after hitting it. But since it is so short time, some ppl wont even know... but if you know about it, you will hear every time it happens. Not sure if ALL Sienna's have it or just some but give it a try, maybe yours doesn't do it. Then you have a good van and maybe a good dealer that will stand behind the product that they sell.
Was that ever even a requirement? I don't think so...
It's been few months and I didn't hear from them
The loud hum noice while accelerating still exists, and it is still a BIG PROBLEM
What about others?
I test drove a 2005 Toyota Sienna XLE Limited last week and was surprised at the road noise. The noise became louder and louder and higher speeds, especially on the parkway traveling at 50-60 mph. Is this normal?? I also heard a slight rattle on the passenger side that concerned me. I drove 2 additional siennas one limited, one xle and the limited was noticeably quieter however the xle seemed to be just as loud. Is this some type of design flaw. I would really appreciate any feedback I can get on this matter because I plan to buy a used sienna and I want to make sure that I'm making the right decision.
The road noise could possibly come from the brand of tires that are on the vehicle. I have read that some people have changed out the tires that are original to the vehicle for others. Is the rattling sound coming from the sliding door or the passenger front door? My '07 developed a rattling in the sliding door. It is now fixed. It could be the age of the car and how the previous owner took care of it. I'm surprised that you had a lot of road noise, because normally Siennas are pretty quiet.
Best wishes on your search. I think you'll enjoy the Sienna once you find the right one for you!
Thanks so much for responding. The vehicle was a 2005 sienna limited fwd. Initially it sounded as if the rattling was coming from the passenger side rear, and I immediately thought that it may be the jack in the rear compartment, but I also heard it up front on the passenger side. I believe your right about the care of the previous owner because when I test drove 2005 same model it was DRAMATICALLY DIFFERENT. The noise was there but it certainly wasn't as pronounced. I plan to continue my search which can be very frustrating at times. I just want to be comfortable with the purchase. Thanks again.
I too have 2000 sienna and it also started making the same " leaking compressed air sound " few days ago. I haven't taken it in yet, but am wondering how you made out ? Any help would be greatly appreciated !
Thank You,
Jay
He charged me $20 bucks and I haven't heard the noise since.
Good luck with yours. Keep me updated.
this is driving me crazy...
Searching "2007 Sienna Sliding Door Tick" at FixYa.com also gives some potential solutions for this problem.
I would like to hear if you've fixed that already and if yes, how you fixed it. Thanks.
