This might be low water level inside the radiator allowing air to get into the heater core. Then when you start the motor the coolant eventually gets pushed up and through but the air makes a gurgling sound which should leave.
You'll need to check the radiator by removing the cap when COOL after sitting for at least half an hour to cool down. The radiator should be full. ANd the reservoir should be up to the cold mark and higher. If the radiator is low that means the system isn't sucking coolant back from the reservoir like it should.
You'll need to find problem source such as leaking water pump, or plastic coolant elbow on hoses to heater, or radiator hose leaks.
Water from the AC condensing can not drain out of the HVAC box and slosh around when going around corners.
Water can be leaking in through sun roof drains and collect on floor in car, front and then back. Check carpets for squishing. Check under the front seats. Check inside the trunk.
Water can leak in through the doors if plastic inner layer isn't sealed, often after work was done in door and the sealer wasn't replaced and they just stuck the plastic layer back on.
If so it may be the actuator for the passenger broken. It's an electric motor with gears inside that sometimes crack and slip on the axle. Since in a dual control system it relies on indexing to determine how warm it is setting the vane for mixing hot and cold air, slipping means it loses track.
You can take off the plastic hush panel above passenger legs with about 3 screws and a couple taps holding it to the firewall. It helps to take off the glove compartment door with about 6 screws under the hinge.
Then you can see all this. Inside the red circle is a plastic motor housing with a rod that connects to the white plastic arm that moves the temperature mix vane inside the heater box.
With the key ON try changing the passenger temp on the door and see if the upper actuator moves at all. Changing the temp on the main AC unit will move the rod at the bottom that's white plastic (not in picture but would be inside blue square).
I'll bet your upper actuator doesn't move. It has two little screws on top and one small electrical connector that goes to the programmer box to take it out. But it's not easy. Some people take off the connection to the white arm that moves the vane and put a coat hanger through the glovebox to it and use that to move the vane for passenger from heat to cold. That was on a Pontiac which has slightly different geometry of parts from what I can tell.
Apparently the part that was cold was what the air to the passenger side went through.
Or you change the temp settings with the key ON and the actuator moves, but jerks or slips (the wheel inside slipping on the hub since the wheel has cracked), then you are ready to replace.
The two little screws on top are difficult to handle and replace, according to people who have done it. One fellow tied fish line through the socket and the screws in case they dropped, but that's the level of difficulty.
Go to Rockauto.com. Pick Buick. Then 1997. Then go to Heat and air conditioning. Then go to A/C vacuum actuator. Your system is CJ2 so I think you want the 2nd one that says CJ2 near the end. Note it says vacuum actuators for the group, but those are electrical. Because of shipping costs with rockauto, you might check your local dealer or other places on the internet, such as GMpartsdirect.com
I would probably pick the local dealer source because if I got the wrong part, I might be able to return it for the right one. Or take off yours and check the parts number with the one on the rockauto or gmpartsdirect or what you get at the dealer.
To verify the code RPO for your system, look at the spare tire cover under the mat in the trunk. The white tag lists all the options and base components for your car. You should see CJ2 listed instead of C67 (the manual temp control system).
I think I just saw someone's writeup on how to do this replacement...
Let us know what you decide.
This week, the blower has been fading in and out, and I was thinking it was the automatic fan control, though it would do it regardless of fan setting. Then the fan quit altogether. Yesterday it blew faintly for about 2 minutes, then out again.
Wow, bad week for this to happen.
I saw that "sturgis larry" replaced the temperature sensor, and all was good again. My question, was that the external temp sensor, by the grill, or would that have been the rods under the hush panel? Also, do I need a new blower motor, or a sensor?
Could be blower control module going out.
Did you try changing the fan speed setting manually?
Did you try hitting gently the fan housing on the firewall under the hood. A sticking, bad bearing will let go and the fan will often start running--a temporary fix until it can be replaced.
The temperature sensor in front of the radiator support can be disconnected and reconnected to see if corrosion on the contacts are causing the problem in the reading. It's a fairly cheap fix.
The blower control modules can be had for 90$ on ebay. First directly connect blower motor to battery with a fuse to be sure the blower motor works right before replacing the module.
Or get a module, temp sensor from a recycling yard.
It has temp cold warm-cold slider. It has PB's for functions (yellow lights in buttons). So I'm saying it is manual; ie no digital readout of setpoint or actual temperture.
It does allot of stuff and it has been doing it for over a year.
1. most of the time system works fine. yellow pb lights respond to pushing them.
2. sometimes all yellow lites go out and system dead.
3.sometimes you can hear relay(s) chatter over on the passeners side
4.somtimes the AC compressor will start on it's own.
5. Fuse looks fine.
Flappers seem fine.
thanks for any help
Does the car have anything else that gives symptoms when the heater control acts up? You might try just hitting on the floor in that area to see if you can affect a corroded contact.
I have a 93 with the heater occasionally losing control--the unit defaulted to AC compressor engaged and cooling fans running for it but the controls didn't change anything. The electric door locks also wouldn't work while this was happening, so my conclusion was that the ground buss was common to both problems. I didn't get to find out because my wife made me trade it for a new bright red one before the problem started happening more often.
http://i86.photobucket.com/albums/k110/imidazol97/DSC00977.jpg
The black plastic line connects next to the big rubber tube from the brake booster.
Another check is run motor. Turn off but leave key at ON then switch different buttons on the heater control unit. If there is vacuum, you should hear the diaphragms moving vanes between different settings. You should have enough vacuum stored for about 10-15-20 seconds of changing.
Then if you're getting vacuum inside,
http://www.imcool.com/articles/aircondition/fix_vacuum_line.php
I replaced the plastic multiconnector with 1.25 inch pieces of 1/8 inch internal diameter gas line, free from friendly scrap box at NAPA.
Others have used aquarium tubing.
The black nipple layers inside the connector pull closed and block vacuum to the AC diaphragm first, with age and heat.
Take off the under dash thin plastic panel. Take off the glovebox door at its hinge with about 7 screws. Then you have good access for arms and light to the programmer box sitting anagled on the corner of the HVAC box. The programmer is held on with 2 screws, a multiwire connector and on top a little connector that goes to the electric actuator on top.
There is a plastic link at the bottom that comes from the electric actuator inside the programmer and snaps onto a wire rod with grooves on it that sets the throw of the lower vane for the passenger side IIRC. Top electric is for the driver vane temperature blend.
The blue plastic vacuum line goes to the actuator for the AC vane that closes and forces air that would go to defrost to come out the dash vents.
You can check for movement of the 4 diaphragms by taking off the plastic underdash on the driver side--all 4 are on that side. The back of the diaphragm is open and you can feel the diaphragm pull if you have motor running and switch the dash settings to different modes.
Whats up imidazol97? I have a problem with my 98 Buick Lesabre. Last Friday my blower just stop working with no warnings all. It was working fine 2hrs prior. I put a brand new blower on it and the new one wouldn't come on. Since my old one was already off, i got it tested Autozone. It spent like a champ. I checked all fuses and all of them lit up. I even check the ones on the passenger side and under the hood, they all tested positive. Later, I got a resistor off a used Buick and hooked it up and the blower still wouldnt work. Next, I got an a/c switch off a used Buick and still nothing. The blower still wouldn't blow. I've taken it 2 several mechanics and they're dumbfounded, they can't find out whats the problem. Im just tired of spending money and my problem isnt being fix. I'm in desperate need of help. Can you help me?
You need to check with a meter to see if you are getting power to the resistor pack with the key ON and the blower motor switch ON. If you had the relay center loose and put in a new resistor, you sound like you are capable.
Since you say it had a resistor instead of a blower control module in the hole, I assume it's the standard AC without the digital readout and without dual controls.
Those have a relay in the relay center that turns on and off the blower circuit.
I believe it's the relay at the left side of the relay center-the passenger side. It's the third from the left (compressor, horn, blower relay).
Most of those relays are the same part number, so the second one which may be cooling fan can be switched to the passenger side to see if the blower motor runs.
Use a knife blade underneath to lift the flat spring catch the snaps over a prong to hold the relay in to pull the relay out. You might try checking for power on the brown wire which should be hot with ON. --from fuse 5D in IP fuse block, 25 A.
the output wire is light blue and goes to the resistor pack.
That relay should be the same part number as the horn and compressor and is a single pole relay.
Another relay is involved and has a Dark blue wire and a Red wire to the two power connections and the out connection is purple and goes the the blower motor.
This should be the relay in #5, the fourth from the passenger side. It is a single pole double throw. It connects either to the output from the resistor pack OR to a 30 amp red lead direct from power for HIGH speed. It's called the high blower relay.
On these relays check the colors I gave you because the book has the circuit diagram mislabled as to which is the blower relay and which is the high/normal speeds relay.
That fuse for the REd wire is in the underhood fuses--the big ones and is 30 amp. It's #3 fuse. I think there's a label on the inside of the relay cover?
There's a third fuse involved and thats' in the IP fuse block, #5A called the Auto AC cruise. It appears to provide power to the heater and AC control on the dash.
The high speed blower relay might not be making contact on their of the two contacts. Normally people have either the low speeds or the high speed working.
But you can use a fused jumper on either of those relays for the input/output power leads and see if the blower starts to run. But best to use backprobing the contacts with a meter grounded to battery negative, to see if you got power where it should be with key ON and blower set for one of the lower speeds.
You might use meter to check that ground on the blower motor is actually grounded to the negative.
This info came from a 98 Factory Service Manual.
Measuring resistance won't check what needs to be done.
You are looking for where the postive battery current is delivered along the steps in the line to the starter motor. When the key is ON and blower switch is ON, does power get to the purple line on the blower motor?
When you checked for power on certain wires, what did you connect the meter to for a ground?
Your checks need to be methodical along the power route one direction of the other.
The first place is to check for power at the BRN wire on the relay which is the blower relay. Then check for power on the Lt Blu output wire--all this with the on and the relay in the circuit. You'll have to backprobe the connectors or use a pin to piece the insulation. Also with someone turning the AC control Off and On you should feel the relay move as it makes contact.
If you have power there then check power at the resistor leads. Terminal D is the LT BLU from the relay. It should have power all the time if the AC Is on.
Then the Dark Blue from the resistors goes to the blower High speed switch relay.
If you want a schematic for the circuits, I can photograph and send you a schematic. I still think work backwards from the high speed relay. Try bypassing to put the RED power wire directly to the purple wire at the relay --using a fused wire--to see if the blower runs. That will run with the key OFF and a back AC head unit. It's a direct connection. To find my email, click on my user name in this post and it's in the profile.
Softened plastic in connector blocking vacuum
My 1998 had the exact same symptoms
The guy has beautiful pics, good description, and he's right on.
I ended up just cutting the lines on each side of the connector, and using 3/16 vacuum hose to connect the hoses - bypassing the failed connector.
Although the connector didnt look bad, I tried sucking on the blue one (to vents) and it was plugged up tight! Nice post! THANKS!!!
Your system came with R12. That's hard to find these days. Do you know the history of your car? Have you owned it? Just bought it? Has it been converted to R134a?
Did you use a vacuum pump? Did you replace the expansion valve?
Sorry to ask questions. I know only a little about the AC charging.
That said, everything went along great until the same thing happened to me; heat for maybe 15 to 30 seconds. I was concerned but didn't know what to do. It stopped on its own and all is well. I am not a GM mechanic, but I wondered if one or more of the "doors" directing the air-flow hadn't stuck or the vacuum level dropped for some reason. I was ready to look at my by-pass surgery and see if something had slipped.
I'm glad it's back to full performance.
Spend some tiime with the underdash cover and the glovebox off. When you start the car watch the lower rod for the driver blend door. It will move to the right for full heat until it senses a change in temp in the air streams. Then it will go to the normal calculated position for the requested air temp vs. the actual air temps. Then later start the car and watch the upper arm for the passenger side blend door control. It probably won't move properly because the electric actuator has plastic gears inside that have cracked and are slipping on the axle. This may be what causes the error flashing temp light: the programmer isn't able to sense the left and right end points of the movement for the upper door.
Also you might have low freon charge.
Replacing the upper actuator is the solution. If you can move the arm with a light force, that probably is verification the gears have split with age.
The relays are in the relay center above the blower motor.
Are you having a blower motor issue? Or is air coming out the wrong vents due to vacuum problems?
However, you can open the hood, open the two little clips on the plastic opening under the passenger side windshield wiper, and inside you'll find either a filter for the incoming air that goes into the cabin or you'll find nothing. If the filter is there, it fits into a plastic skeleton frame. Pull it out. Look down inside and you'll see the blower motor's squirrel cage--the fan part. See if you can rotate it with your fingers. Then turn on the blower motor and see if it rotates?
There also are problems with the electrical connector for the blower motors--it's right next to them under the dash inside.
The water is supposed to drain out the rubber tube that's under the passenger side of the firewall behind the motor. Hard to get to, but if someone supports the car safely and can crawl under, they can use a piece of thin wood or something to poke into the tube. It may have a flattened end that water pressure is suppose to push open or some other way to keep air or water from coming up in from the road. When you push something gently up into it, water will probably start rushing out. Goop of some kind probably has clogged it. Prepare for a bath if you are under the car.
I guess I will have to get under the dash to see whats going on there, and clear out the water tube under the passengers side. Thanks for your advice.
Can you pull it out from the cowl opening?
>fan doesn't move
Connector not making contact? Some have contacts that burn.
Or the blower motor brushes have stuck in their channel where they slide. As they wear they don't move forward and lose contact.
Try tapping up on the blower motor with a vibration from your shoe or fist while the key and controls are both turned ON. See if it makes contact and catches. That would tell you everything else is working right.
I have a water leak in my 2005 Buick Lesabre. It happens when using the air conditioning. The leak appears to be clear clean water. It's coming from under the dash on the passenger side. The dripping is approximately three inches from the floor board hump. The amount of water is enough to saturate the carpet on the passenger side. I suspect it is a problem with the drain from the condensation removal of the cars air conditioning.
Any help with thoughts about this problem would be greatly appreciated.
Is the drain for the condensation under the dash on this vehicle?
Thanks, Deamer1
I apologize that your vehicle has a concern. Have you had anyone look at the vehicle to diagnose the concern? Thank you,
Mariah GM Customer Service
If you mean have I taken it to a dealership for them to diagnose the problem...no.
I know how the basics work. It is most likely a broken piece of plastic, a misplaced, worn, split, etc drain hose. Most likely it will be something similar.
I just don't know the specifics of what I will find when I remove the uderpanel of the dash and get started on the repairs.
What I did do was pull the car into the gagage, disconnected the battery, mopped up most of the water, opened all the car doors, put a large fan blowing air into the car at the wet spot. I left it there all night...it is now dry and no spots in the carpet.
So, that is where I'm at on this problem. I was hoping someone had words of wisdom for me on this site with this situation.
Thank you for your concerns,
Deamer1
Dirt, pollen, mold, mildew, leaf particles, etc., can get into that area and form a muck that blocks the drain.
If you can park your car in some way to leave room underneath to crawl under from the side, you should see the rubber drain. I cannot see mine from the top of the engine compartment. Do not lift the car with the scissors jack for changing cars and get under. It is dangerous to do so. Jackstands are a must for solid support.
Thanks for responding. Great minds think alike!
What I have done so far...removed the dust shield from under the passenger side of the dash. Laid on the floor board until I slightly cracked several ribs
The plastic parts under the dash are many and packed in a close space.
My time was limited so, I had to quit for a time....which was a good thing. I finally came up with the same idea which you provided for me.
Again my time was limited. I have not jacked up the car and put it on stands yet. That is what I intend to do and then see if the drain is blocked. It may well be that is the problem.
I'll keep you informed if you would like, as I progress.
Deamer1
From inside the car, under the passenger side of the dash...a drain line runs down and goes under the carpet and is angled as if it stays under the carpet and going toward the rear of the floor panel on the passenger side.
I haven't figured out how to loosen the trim so I can raise the carpet up to trace it better, but I took out the back seat and lifted the carpet up on the passenger side of the back seat floorboard...It's wet...real wet. Could the drain hose possibly run to the rear seating area and come out there?
Any words of advise are always welcomed.
Must go crawl under the car and see if I can figure this out.
Deamer1
Behind the right front wheel look across and up under the car. There's a large cross beam. There is a 1.25 inch round bar about 2 inches behind it. I think that's the sway bar. The drip comes down just behind the big square crossbeam at about the point where the sway bar comes downward and bends to go horizontally across. I didn't try, but I suspect a long arm can reach upward to the area where the tube should be hanging. It will have some kind of system designed so it's not open except when water's weight is forcing water out.
I really appreciate you and your input to my problem. It may sound like nothing to others, but your input helped me solve my problem and I want to share it with others. This is a situation which I'm sure will be experienced by others. It's easy to fix once you have good information about the problem. You have helped me and I'd like to provide some input for others.
I jacked the car up using a floor jack. I blocked the rear wheels, and put jack stands under the frame in the front end. Your input helped me locate the A.C. drain, but it took several attempts for me to find the drain hose.
The A.C. drain is located almost in the center of the car, high in the dash. I'll describe the location from the underneath of the car as that is where you'll have to unplug the drain hose.
The A. C. drain hose on my 2005 Buick LeSabre is located high above the point where the manifold meets the catalitic converter. These cars are so low to the ground that I wouldn't have found it without jacking the car up and putting it on Jack Stands and crawling under it.
Above the catalitic converter is a small drain hose coming out of the dash. It's approximately a 1/2 inch line. It extends out of the dash approximately two inches, then bends down in a 90 degree bend for approximately three inches. the end of my drain hose is like the neck of a balloon. Coming out of the dash it is a round hose, but at the end where the water comes out...it has flat sides that go together. I found some sort of gunky matter in the outlet end of the hose. The water coming out was only a drop once in a while, nothing like it should have been. The blockage caused the water to back up inside the car and spill into the passenger side of the floor board.
I took a 5/32 inch copper rod approximately 25 inches long and used it to open the drain hose. A couple of flicks of the rod and splash! I got wet. The drain was open, then I had to address the moisture inside under the floor carpet.
Wishing everyone well and hoping your problems are small.
Deamer1
Be aware there's a rubber like pad under the carpet that holds the moisture underneath. You might want to try lifting it at edges to blow air under if you park car in a garage in some way to dry it. Or lift it at edges with wood pieces and park in the hot sun with windows cracked enough to give airflow on breezy days.
Is there water pooling in the area under the front seats especially on the driver side? If so, there's a connector of 4 tan wires that corrodes and you lose communication between the driver door module and the three other door modules.
Bonneville owners have had lots more problems with leaks and water from sunroofs and door liner leaks along with an occasional windshield leak. Add in wheel hump leaks in the trunk along with some others. Some of them take the seats and everything out to hang the carpet and mats up to dry.
The amount of moisture in my car was more than I thought. Originally I thought there was a little moisture under the passenger side carpet near the top where the carpet goes up into the dash area. The water had actually saturated the entire carpet padded area under the passenger side and went completely to the rear floor board section on the passenger side.
I took out the back seat, disconnected the battery, pulled the rear passenger carpet up as much as I could (wasn't enough) When I put my hand under the carpet it was saturated with a lot more to spare.
I took five shop towels and packed them under the carpet. When they were saturated I pulled them out, rung them out and put them back under the carpet. I did this maybe ten times. I still had the car up on jack stands so water was running slowly from the front passenger side under the carpet to the rear. There was a lot of water in there and still some in the carpet padding, but not as bad as it was.
I need to remove the plastic trim holding the edges of the carpet along the door frames bottom, but don't know how these come loose. Do they pop out?
The weather here was in the 100+ heat index so I parked the car outside, disconnected the battery and opened all the doors. I wedged some small 2x4 pieces under the front carpet near the dash and the rear carpet just at the back seat. I left the car like this all day. I has dried some more, but I really need to remove some of the trim to raise the carpet better to dry it out. Would you know how to remove the plastic trim along the bottom of the doors which hold the carpet in place?
That's pretty much it in a nutshell. Still working on drying it out.
Deamer1
The factory manual says you can use a fan pointed at the wet area. They don't mention the under layment. Maybe that's only behind the rear seat or under the front floorboard.
I lifted the carpets in the front and rear floor board area as much as I could...blocked them up with a short piece of 2 x 4, placed the car outside as we had two days of 100+ degree days. I disconnected the battery, opened all doors, placed a box fan on a stand for each area and let it blow air under the carpet area for two days. It is drying, but isn't completely dry as of today. I will do this until it is dry.
Another thing I tried is to blow my shop vac into the areas using the exhaust heat from the electric motor. It works, but is best with a smaller amount of moisture, not like what I experienced. The most difficult to dry is the rubber padding attached to the carpet back which is located under the front seat without removing the seat. Wicking this area and using a fan is working, so I will continue.
Deamer1
Does the car have drain down protection on the battery? I believe LeSabres do--maybe a Custom might not. But if you leave the headlights turned on or the doors open, the power is turned off after about 10 minutes. Same for trunk and overhead lights.
You might not have to disconnect the battery is my point.
If you are in an area of the country where you get dry humidity days, I always used those where the hot sun was shining into the car and I leave the windows down an inch on one side of the car to suck air through the AC unit to dry out the accumulated moisture that stays in the drain. You might get even more drying on those days than on high humidity days.
Tony
