Volkswagen Jetta Brakes and Rotors
12346»
  • amanda22183amanda22183 Member Posts: 1
    I took my 2008 Jetta in for it's 20,000 mile servicing today. I got it back, and didn't read over the paperwork until I got home. They left a check list in my car for me. Everything checked out ok except my rear brakes. They said my front brakes are at 11cm and my rear brakes are at 6 cm. I don't quite have 20,000 miles on it yet. From what I have read so far this seems to be a common problem. I am NOT a mechanic in any way and need some advice on what I should do.
  • jetta7jetta7 Member Posts: 17
    If your rear brakes are wearing faster, have the parking brake lever, which is located between the front seats, checked for slack. If you pull up on the lever and it does not move very far, chances are it is adjusted too tight. As you apply the brakes in normal driving, the automatic adjuster keeps adjusting the rear brakes too tight.
  • iamglenniamglenn Member Posts: 1
    Rear brakes do wear first on all VW models except Touaregs. If you've ever had to make an emergency stop the nose of the car does not dive to the ground. Rear brake calipers compress first and with greater force to prevent nose dive braking.
    53K for rears is amazing! I've seen as low as 15K and as high as 85K for the first set of rears on a Jetta. Almost all brake jobs on German cars require pads and rotors at the same time -- German car makers trade longevity for stopping power.
    Slam on the brakes on a VW and you stop -- quickly. Some squeal or grind on cold or damp days is unfortunately a by product of brake dust and binding to rotors ....... some of my customers get pissed at that answer but ...... like I said -- unfortunately .....
  • bpeeblesbpeebles Member Posts: 4,085
    I "2nd" the above append! This may be the #1 'complaint' I see here on the Edmunds forums regarding VWs. I wish people would just use "search" before asking this same question over and over.
    The rear brakes on most VW models wear faster than the fronts. VW *purposfully* uses softer pads in the rear to get a better bite into the rotors.
    You may chose to install NON OEM pads (ATE, Akebono, Mintex... etc) and the faster wearing will NOT happen. (but your car will not stop the same either)
  • shriftyshrifty Member Posts: 255
    Based on what you've seen with the lifespan of brakepads, I'm probably nearing the end. I currently have about 75K on my original pads on all 4 corners, but they still seem to be about the same as when I bought the car.
    I believe the 09 has brake pad sensors, but I'm curious how this works? I'm guessing once the pads reach a certain thickness (or lack of) you will see some type of indication on the dash? If this happens, about how much life is left in them? I don't want to push it to the max, but at the same time I don't want to panic and call for a tow out in the middle of nowhere when I can safely and easily drive back home and get it done the next day.
  • nflroyaltynflroyalty Member Posts: 10
    Hi to all,
    Took delivery 5 days ago. Has barely 100 miles on it. What bothers most is appearance of rotors. They all look rough and a little rusty. Feel somewhat rough too. Compared to wife's new car(Honda cr-v) not near the same. Her car delivered Saturday past has perfectly smooth rotors and more miles. Does this justify a service call to dealership?
    I think mine have looked rusty since I bought the car, and have almost 77K on them now. So far no issues with them.
    These are rusty and somewhat rough. Should a brand new car have perfectly smooth rotors?
    It seems logical that they would be smooth, but I don't really know. My car sits outside in the elements, so they are almost always rusty. Does the car shake when braking? When I brake it is smooth when stopping.
    No, stopping is not smooth especially at low speeds.
    In that case I would get it checked out.
    edited March 2011
    My rotors occasionally get a little "surface rust" on them. I often get surface-rust after my car sits for a weekend in the rain. (Especailly after driving on salty roads in the winter.) Some (safely executed) panic stops tends to clean them up nicely. It is also good for the brakepads and rotors to be exersized once in a while.
    HOWEVER: On a brand-new car, it takes at LEAST 500 miles of driving to season the rotors. A very thin layer of brake-pad material gets imbedded into the surface of the rotors. (This is called "seasoning" the rotors) After several miles of seasoning, it is best to ""let the smoke out" and perform several back-to-back panic stops to get the pads smoking-hot. (This is called "bedding" the pads) ... then park car overnight and allow COMPLETE cooldown of the brakes. This aligns the molecular grain within the rotor which will help reduce the chance of warping.
    After that exersize, (seasoning and bedding) your brakes should provide many years of trouble-free service.
    Also.... never EVER touch the rotors wth your fingers. The oils from your skin can impede braking-performance.
    edited April 2011
    I just had my brakes checked on my 09 TDI as they are the original pads. The fronts have 80% remaining, and the rears are at 40%. Not bad for just over 78K :)
  • eisenhauereisenhauer Member Posts: 1
    With my 2004 VW Diesel Jetta Wagon my rear brake pads had to be replaced at 170,000 miles. The repair garage said my front pads had about 10,000 miles left on them. Now, at 190,000 miles, the warning light went on in my car indicating the front pads now have to be replaced. Obvously, most of my driving is longer distance, and I live in southern New Jersey where there are virtually no hills, and I'm light on the pedal and stopping and starting (e.g., I'm getting 90,000 to 100,000 miles out of tires, whether they're Michelin or Cooper). I'm not sure what all this means, but thought it of value to share. For me, the brake wear indicator light should probably be attached to the rear brakes but this obviously isn't true for most people's driving habits. I closely monitor tire air pressure, which certainly helps with tire mileage.
    I'm guessing that my driving habits and the flat terrain of South Jersey are mostly to credit for the low wear of my brake pads. My Toyota Corolla, which was totalled in an accident at 160,000 miles, had its original brake pads front and rear. And this Corolla had significant local mileage on it since it was used for half its life by wife for shorter trips.
  • basha_manickbasha_manick Member Posts: 12
    Hello Handiman!,
    This question is not related to brakes , but VW in general. If you have time can you kindly answer?
    I have a 2008 VW JEtta 2.5 S ( When i got it , i t had 27500 miles on it).
    Now, 31k miles.
    1) I got it in summer. Now in the winter i see that it is emiting too much smoke compared to other cars on road. Do you think of anything that could be wrong? Emission, engine tuning etc
    2) Also when i drive like around 40mph, i hear a strange rattling noise, itook it to the VW dealer as is under warranty. He said he checked with mikes and doesnt hear sound, It might be because, the rear tyres are of different brand. And once you drive 5k miles, both become even.
    But i have driven 3k miles since and the sound stll exists.
    It would be great if you could give ur expert comments!.
  • jim532jim532 Member Posts: 1
    I had a similar issue with a 2007 Jetta Wolfsburg 2.5. The rear caliper pistons have to be turned in with a caliper tool. I used a snap on tool that I borrowed from a mechanic. You cannot simply compress the rear caliper pistons in. They must be turned in clockwise. I don't think it's the emergency brake adjustment although you should be sure to see that the pads move freely within the caliper pins. I used VW factory pads with all new hardware after 40,000 miles and had to replace the rear pads a second time at 24,000 miles. The second brake pads were manufactured by TRW. The VW pads are $99 retail and $65 wholesale. The TRW pads were $37 wholesale. Be sure to check the rear brakes regularly so you won't have to replace rotors too. I hope the TRW pads don't leave as much brake dust on the rear alloy wheels. I've heard that some people have experienced similar problems with Audi A-4s.
  • paintchippaintchip Member Posts: 10
    Smoke or steam? My 2.5 emits a lot of steam in the winter and always has. If it's definitely smoke then what color is it? Black or grey? Black is fuel, grey is oil.
    As for the rattle. Does it seem to be coming from the trunk? I had a rattle that was driving me nuts and the dealer also said they couldn't duplicate it (BS...heard it every time I hit the slightest bump). I finally found a VW engineer that told me the rear brake adjusters are tied to the e-brake. He told me to set the e-brake every time I parked the car. I did and about a week later the rattle was gone and has never returned. Might want to give that a try.
  • SnowyRdSnowyRd Member Posts: 1
    I bought my ‘14 Jetta in ‘16 with 13k miles on it. When I brought it in for the 20k service the dealer told me my front rotors were junk because of rust. 20k miles? Really??
    I have owed many cars in my life and have never seen rotors rust out after two years. the dealer blamed VW. Said they were not putting zinc in the rotors anymore so they rust quickly. I had them replace the rotors and then kept an eye on them. They actually glaze over with rust overnight! Every day pulling out of my driveway the first time I hit the brakes....scrape, scrape, scrape until the layer of rust is gone. But each day the pads are grinding that rust into the rotors and soon enough they started pitting again. one year and 10k miles later they look the same as when I was told I needed new ones.
    This is insane. The last 3 Toyota’s I owed needed pads at around 60k but the rotors never rusted. I am going to try some non VW after market higher quality performance rotors and pads and see what happens. The VW brake issue is pitiful. And my local VW dealer is pitiful. Their troubleshooting skills are nil. Thats a whole different story. I dont know what happened to VW. I have owed VW’s in 70’s, 80’s, and 90’s with zero issues.
