Performance Modules and Chips
So I've got a '07 Subaru Outback XT that I would like to spend a little money on. The thing is pretty quick off the lot with 245hp from a turbocharged 2.5L boxter engine. I was clicking around on Ebay and saw a great deal of posts for "Performanc Modules" and "Chips" that people are selling for around $10.
Now I'm not technical genius, but I know that it took a lot more than $10 to squeeze horsepower out of my '67 Mustang Fastback.
Has anyone ever tried any of these products? I'm curious on how well they work, or if they work at all.
Thoughts? Comments? Jokes?
I have an 05 Legacy GT which essentially is the same car as you have.
Before I did/do any power upgrades, you will want to address upgrading your brakes, and suspension. These aren't $10 mods either.
-mike
From there we can really hone in on what items would be most beneficial.
What kind of tires do you have? Stock? All Season? etc.
That's a great place to start, cause tires will effect your handling and speed in a huge way.
-mike
I hate to put out that kind of cash and find out that it did not do anything for my investment????? I already had the air in my tires replaced with Nitrogen and it seems like it helped a little but it is to soon to tell just had it done the other day???
AzLee1
You could switch to synthetic oil,which might get you 1-3% better mileage---not much but could possibly boost you to 13 mpg in the city. Driving habits can help a lot,which would include, for city driving, "keeping the truck moving", that is, coasting to stop lights rather than rushing up to them and then braking and then restarting. Every time you can keep those tires rolling, you are saving gas. You could pump up the tires another 5 lbs or so.
It's a heavy vehicle, and it needs to get moving from standstill, and the laws of physics are not easily defeated.
But try the synthetic. Your truck will like it.
What is the synthetic that you would recommend??? Also I am a little leary about running my tires up over 35 pounds, I live in Az. and it gets pretty hot and I would not care to have a blowout due to too much air after I have been driving on the hwy. ????
What are your thoughts on a K/N Low Restriction air cleaner system over the factory installed system????
Also I failed to mention that I have a 4x2.
Another possibility may be the exhaust system ????
K&N filters will give you lots of noise but that's about all. You have to look at your car's engine as one long tube---if you open one end but don't do anything to the middle or the other end, you aren't really doing anything of significance. Not just the intake, but the fuel system, the engine itself, the computer mapping, the turbo if equipped, and the exhaust needs modification to make any kind of payback worth the effort.
Modern engines are pretty much locked into their gas mileage. The automakers do make some compromises for comfort and safety and reliability, of course, but they have these engines pretty well dialed in by 2008. They do not leave much on the table for tinkerers unless you want to add serious horsepower for serious dollars and a loss of fuel economy and reliability for that 'fun factor".
There is no "bolt-on device" for $29, no magic fluid, oil and gas additive, turbonator, hydrogen generator, chemical, acetone, or whatever that's going to give you better fuel mileage.
5 quarts of Mobil One synthetic oil would do more good than a whole boatload of them IMO and even that's going to be minimal.
Good tire pressure, driving habits, synthetic oil, alignment, brake check, good tune-up, new air filter, good gasoline---that's about all you can do on a modern car.
Well possibly you could add overdrive gears, change differential gearing, etc, but that ain't cheap.
Visiting Host
I could see how this device might make your truck/car more responsive but beyond that, the website's "evidence" is pretty slim pickins IMO.
-mike
