Saturn Outlook Transmission Problems
1568101118
  • integrityplzintegrityplz Member Posts: 12
    just a little info i found.
    TECHNICAL
    Bulletin No.: 09-07-30-012A
    Date: January 12, 2010
    Subject: No Reverse, 3rd or 5th, Check Engine Light Illuminated, DTC P0776 (Replace 3-5 Reverse Clutch Plate (Waved)
    Models:
    2008-2009 Buick Enclave
    2008-2009 Chevrolet Equinox, Malibu
    2009 Chevrolet Traverse
    2007-2009 GMC Acadia
    2007-2009 Pontiac G6
    2008-2009 Pontiac Torrent
    2007-2009 Saturn AURA, OUTLOOK
    2008-2009 Saturn VUE
    All Equipped with 6T70/75 6-Speed Automatic Transmission (RPOs MH2, MH4, MH6 or MY9)
    Read more: 60 mph, engine reved momentarily then dropped..slowed..20 mph - JustAnswer http://www.justanswer.com/saturn/4d6be-60-mph-engine-reved-momentarily-dropped-s- lowed-20-mph.html#ixzz211hSkNta
    Below is the definition of a tsb.
    A notice given from manufacturers to dealers to inform them of repairs suggested to solve common complaints Technical Service Bulletins, or TSBs, are recommended procedures for repairing vehicles. Not to be confused with recalls, a TSB is issued by a vehicle manufacturer when there are several occurrences of an unanticipated problem. ...
    en.wikipedia.org/wiki/Technical_Service_Bulletin
    This is the technical service bulletin i found
    Maybe it will become a recall. In the meantime i must wait to see if i have to pay for a known common problem with this car.
    all you have to do is search broken wave plate and you will find forums for the acadia, enclave, and outlook.
  • ellimacellimac Member Posts: 6
    Are these cars set to implode when the warranty runs out or what!?!?? As I have posted, I have the roof leak, the transmission issue and now the STEERING won't work!!!! I had the power steering pump replaced and that didn't fix it. It's fine when it's first started but after a few minutes the steering wheel is so hard to turn it practically is locked up. Mechanic said it was the pump, but after he replaced it, it just got worse. AND IT IS NOT SAFE TO DRIVE. He is stumped and is contacting GM to see if there are any service bulletins. I HAVE NO CAR AND NO MONEY!! I loved my Outlook, but after all this and reading all the issues that other people are having (which are the same as I am having) I am not very happy with it anymore. Leak is potentially dangerous, transmission problem is dangerous, but the steering issue is a HUGE SAFTEY issue. lWhy are there no recalls on these issues when clearly so many owners are having the same problem? How do we bring this to the attention of the public at large??? In am so frustrated and upset. I have no vehicle, no way to get to work (live in the country, no public transportation).
    My suggestion is for everyone to report their issues to thw national highway safety. Maybe the more reports they will have to investigate and we can get these issues fixed or at leaast the money we put into these back
    hmmmm?TSB's
    Repairing a broken clutch wave plate
    Posted on May 9, 2012 by Information provided by Identifix Inc.
    Post a comment
    Comments (0)
    Facebook
    Twitter
    Email
    Print
    A harsh shifting condition on select GM vehicles may be due to a broken 35R clutch wave plate. Applicable vehicles include 2007-2009 Saturn Aura and Outlook, 2008-2009 Saturn Vue, 2007-2009 GMC Acadia, 2007-2009 Pontiac G5, 2008-2009 Pontiac Torrent, 2008-2009 Buick Enclave, 2008-2009 Chevrolet Equinox and Malibu, and 2009 Chevrolet Traverse (all equipped with the 6T70/75 6-speed automatic transmission.
    The condition may include the Ses light and/or no reverse, and a slip/flare or harsh shifts in drive range 3rd and/or 5th gear. Codes P0776 Clutch Pressure Control (PC) Solenoid 2-Stuck Off and P0842 Transmission Fluid pressure (TFP) Switch 1 Circuit Low Voltage may be set.
    A broken 35R clutch wave plate allows the piston to overstroke, causing the piston to leak and causing loss of apply on vehicles with more than 25,000 miles.
    During the repair process, it is important to install the wave plate in proper orientation to prevent the possibility for the failure to reoccur. Install the rounded edge of the wave plate internal splines facing the 35R piston. :confuse:
  • chefiguanachefiguana Member Posts: 3
    So, I have put up with odd noises out of the steering column (replaced, no help), the failure of the power lift gate (replaced twice) and the "quirky" transmission shifts over the years. Today however, the engine light popped on and the transmission failed to up shift entering the interstate. At first, it wouldn't even go into neutral, finally go it out of traffic onto the feeder at about 5K rpm. I went and checked the fluid level (fine) only to find SMOKE coming out of the dipstick. I have read all your posts, and we all seem to be having the same problems, something related to a wave plate. I'm afraid the tranny is shot (overheated). I have MajorGuard extended warranty from GM and assume Covert Buick/GMC in Austin will do the right thing. I will keep y'all informed when I hear something.
    ...forgot about the replaced headlight and the passenger airbag sensor. No leaks in the sunroof, so I got that goin' for me...which is nice.
  • kyfdxkyfdx Moderator Posts: 273,835
    Bill Murray reference.... nice! ;)
    oki just found out from my mechanic that GM knows there is an issue with steering lockup and they aren't doing anything about it!! This is a major safety issue!! It may not even be repairable. Not to mention I now have no vehicle, live no where near public transportation, have already missed 2days of work, my daughter lost her waitressing job because I couldnt get her there and I have no recourse! Its out of warranty, however this goes beyond a warranty issue. It's an inherent defect of the vehicle. I grew up in a Chevy family, thats all we ever had, but this has truly soured me on GM. These vehicles should have been recalled by now. Are they waiting for someone to get killed before they recall it? i brought it to dealer because of transmission several times, and all they did was clear the codes, not fix it (stabilitrak, abs, check engine). The check engine light came on within a mile of the dealership. What is the point of codes and warning lights if they just ignore them and "clear" them?
  • gmcustsvcsarahgmcustsvcsarah Member Posts: 1,964
    We hope that everything went well during your visit and look forward to an update!
    Sarah, GM Customer Service
  • pnhdadpnhdad Member Posts: 1
    I have a 2008 Outlook XR FWD and was talked into the transmission program change (#08-07-30-022A). I wish I was not convinced to do it. The GM dealer states they cannot change it back because there is not a program available. Is there one available? This new program causes the RPMs to always run over 2000 even when it downshifts. On the highway, I was getting 24/25 with the old transmission and now only 20. I would not recommend it.
    Yes, the sun roof has leaked twice, the steering was replaced, the water pump has been replaced, the passenger air bag sensor sometimes works, the air temp monitor is always 10 to 15 degrees too low, the heated windshield washer was recalled, hoses needed to be rerouted (dealer recommened) and also the rubber strips on the roof are creeping forward and pushing on the windshield gasket.
    We're happy to look into these concerns further, pnhdad. Please send the following information to us at socialmedia@gm.com so that we may open a case and contact your dealership: your name and Edmunds username, phone and address, the last 8 of your VIN and current mileage, and the name of your involved dealership.
  • outlookowneroutlookowner Member Posts: 1
    I have a 2008 Saturn Outlook with only 45,000 miles on it. While driving 65 mph on the highway, my car completely shut down. Thank God I was able to pull over safely to the shoulder of the road. I was able to get the car started right away but for a while the steering wheel was making sounds and the air conditioner was not working properly. This was an extremely scary experience. I'm taking my car to the dealer today. Hopefully, he can figure out what went wrong. Please post if your Outlook has had a similiar problem.
    In the past, I have had the headlight and leaky roof problem.
    Good morning,
    We're very sorry to hear about the situation on the highway and are glad to know that you're okay. Please keep us posted on your progress at the dealership!
  • beachmom2beachmom2 Member Posts: 1
    I feel so much relief... I HAD a 2007 Saturn Outlook that was a great car for all the reasons except what a car should be- safe, reliable transportation. The whole family loved the space, comfort and appearance, even the football kids we'd bring to practices with us. BUT at 73K miles the transmission started to slip and rev high, took it to the dealer for service still under warranty at the end of June 2012..... stupidly believed it to be fixed and took the car on a road trip to DC when it really started to act up in DC stop and go traffic.... then transmission just died about 2 hours from home, on the interstate where average speed is 70 MPH!! talk about dangerous! Had it towed to the Chevy Dealer at home & they were awesome and fixed it at no charge but "warned me" that they were doing me a favor as it had passed warranty life, not true. Whatever. I took it straight to the Honda dealer and traded it for a Pilot the next day. I'm done with GM. Comfort is one thing, QUALITY is another.
  • daplapdaplap Member Posts: 2
    Count us in on the loss of power/chugging problems with our 2009 Saturn Outlook. The dealership mechaincs are saying it's the "coils". So far we've had two coils replaced, plus a new catalytic converter, plus multiple "fuel & induction system cleaning". And once again the car is with GM today for the same problem - 3rd time and we're only at 76000 miles. Sure sounds like a systemic (i.e. WARRANTY!) problem to me. My wife loves the car but mechanic friends tell us to cut losses and sell it asap.
    Have you spoken with customer assistance in regards to the repeat concerns you've had with your coils on the Outlook? If you would like for us to get a case set up for you, please send the following information to socialmedia@gm.com: Your name and Edmunds username, phone and address, the last 8 digits of your VIN and current mileage, and the name of your involved dealership.
  • outlooknogoodoutlooknogood Member Posts: 1
    I just wanted to add us to the long list of individuals who have experienced a broken wave plate right around warranty expiration time. In our case, the warranty expired due to time, not mileage, a little more than two months ago. Our car broke down as we were exiting the interstate after a road trip on Sunday. I contacted customer service earlier in the week...and haven't heard a thing back directly from them. They have been in contact with the dealership, who called me today with the "good news" that GM will be paying over half of the repair costs, so we'll "only" have to pay $1400 out of pocket. That's of course, in addition to the $400 out of pocket we've already paid for a rental car.
    Based on the posts I've seen here, as well as posts on other forums, the wave plate issue in the 2007 Outlooks is a known issue for GM. They should be covering the entire cost, not leaving loyal customers holding the bill for their faulty engineering decisions. We have been loyal GM owners for years, but we'll be taking our business elsewhere now.
  • valeriep1valeriep1 Member Posts: 1
    GM is not going to do a damn thing. My outlook has had its transmission replaced at 50,000, since then it has been in the shop 7 times for transmission related problems. each time I get a crappy loaner, while my SUV sits in a shop for a week. Then GM offers me 1000 dollars off a BRAND NEW GM vehicle, like if I could afford a new SUV I would be driving one! So my next offer was to pay for my onstar for 2 years. What I want is my down payment money back so I can get rid of this heap and not break down on the side of the road with my baby AGAIN! and now its stuck in gear again. This is time number 8. as usual on a saturday. Do yourself a favor and dont count on GM doing anything at all for you. Its terrible. I have owned nothing but GM vehicles, one right after the other, and now I get a piece o f crap that I will never be able to get rid of.
  • johnnyboy17johnnyboy17 Member Posts: 2
    Decided to make this easy. We checked and the problem still existed. So, to make everything easier, we just got rid of the Saturn and bought a Ford. Hopefully, we will be trouble free from now on.
  • pebs4pebs4 Member Posts: 3
    our saturn outlook is a 2008 with 36,500 miles only. car started to rev up at 25-30mph and come down and again at 45mp. then completely stalled.....got it towed, mechanic says 3500 at the least for a new one. mechanic stated he never saw anything like this for an suv with these low miles. something needs to be done especially when other vehicles are doing this. please help, cant afford and shouldnt have to!
  • fkarasfkaras Member Posts: 14
    I had this with my 2009 20K miles solved it by trading to a toyota FOUR RUNNER,,, i can go on a trip to Florida any day and know this car is coming home , back to NY . i smile when i visit toyota dealership. when you must cry to beg GM for help
    Good morning pebs4,
    We're sorry to hear about your Outlook. While we cannot guarantee what the end resolution will be up front, if you would like for us to look into this further please send the following information to socialmedia@gm.com so we can get a Service Request going: your name and Edmunds username, phone and address, the last 8 of your VIN and current mileage, and the name of your involved dealership.
    Kindest regards,
    Sarah
    GM Customer Service
  • montereymamamontereymama Member Posts: 1
    Imagine my disappointment as I search and read all the transmission trouble with a vehicle we WERE happy with....
    On the way to school this morning in heavy rain, I realize that the engine is squealing as I accelerate. RPMs over 5, mph not past 40 and I don't appear to be shifting out of 1st. Check engine light comes on. I stop and turn off the engine. Sit a minute and restart. Same trouble. I am forced to turn around, poke back home and change vehicles.
    This 2007 Saturn Outlook was purchased 9 months ago and currently has 59,000 miles.
    I feel foolish bc we tried to really do our homework before purchasing a used vehicle for our 7 member family. It was thoroughly inspected by a trusted and outstanding GM mechanic.
    I'm hoping the Powertrain warranty will handle all necessary repairs. I'm taking a list of these documented problems to my mechanic. Just don't want to risk a quick fix with continued problems as everyone else is reporting. Very disappointed. Should have purchased another used Chevy Tahoe. Our 2001 has nearly 300,000 miles!
  • frs929frs929 Member Posts: 51
    Good luck with getting anything out of Gm. We bought a New 2007 Outlook and the transmission went bad at 87000 miles. It was 2 months past the 5 yr requirement too . I recently submitted a claim and GM turned me down. They dont stand behind their product. I will never buy another GM car and will tell everyone I know too. Got my bailout money but can't help anyone else.
  • customsyscustomsys Member Posts: 1
    We have only owned our 2007 Saturn Outlook since Jan 2012. After reading all this I am thinking maybe we chose wrong vehicle. We love the size and feel of the Outlook, replaced our 1996 Suburban with 285,000 miles. Yesterday we had transmission trouble for the first time, reverse is studderly and strange rpm race from 1st to 2nd. Called the only Saturn approved dealership in 100 miles and they said 1-2 weeks before it can even be looked at, most likely 2. What are we supposed to do for a car? They said loaner only applied once they have confirmed powertrain failure- 1-2 weeks. That is crazy. Only other real issue is that the power liftgate wont stay up after opened, but only sometimes. Other times it works perfect.
    Hello montereymama,
    We're sorry to see that you've had some transmission difficulties with your Outlook. If you have any questions about warranty coverage or would like for us to look into this further, please email us at socialmedia@gm.com with your name, contact information, and the last 8 digits of your VIN.
    Hello customsys,
    We're sorry that there is such a delay to get your Outlook in to the dealership to have it looked at for the transmission concern you're experiencing. If you would like for us to check into this situation further, please send the following information to us at socialmedia@gm.com:your name and Edmunds username, phone and address, the last 8 of your VIN and current mileage, and the name of your dealership.
  • br4509br4509 Member Posts: 4
    over all i would never buy a Saturn....The liftgate problem is from your liftgate arms...replace them. I had same problem. go online and order a generic one dont order GM part....
    Transmission --- broken wave plate....my is in shop now...prob about 1400.00
    sorry
    Sounds exactly like what happened to me. GM is QUITE familiar with this issue. Others have had a broken "wave plate", but In mine, they replaced the Transmission TCM (transmission control module). Basically, it is both the electronic and hydraulic part of your automatic transmission that controls all shifting. ie, the computer tells the TCM to shift, and it actuates a valve that changes the gears. Anyway, they knew immediatley what was wrong. I had the extended GMAC warranty so it was covered. Good luck with yours....
  • bgin2love1bgin2love1 Member Posts: 1
    I have a outlook 2007 and all it has given me are issues. I am a value customer for New Rochelle Chevy in NY. I brought a new 2009 Malibu with 4 miles on it. no issues. Then my family size changed so I went to that very same dealer I just paid over 26,000 in car for the malibu to trade and get my outlook. Not only did i not get Half the money down in my trade, but they gave me a lemon. THIS outlook has leaked from day one. They fixed it once and now want to charge me $250 just to tell me where the pour, YES pour of water from my roof is coming from. I replaced the front head lights seven times and received three tickets because when it was replaced, it blew right out again. To NOW get a recall about the wiring!!!! then the Transmission went in the car this year, They replaced it, but NOW not even 7 mons later, it's going again!!!!!! of course I'm out a warranty because I take my Handicap child to therapy four times a week 30 mills away from my house and I put too many miles on the car. The Dvd's they installed in the vehicles broke a week from getting the vehicle. I pushed the button to turn it off and the button went straight threw and fell in the Unit. All the buttons are broke. If it wasn't made to push, why install them? I have always gotten all my work done at the dealer. All oil changes, tire rotations, tune ups, etc... I hate my vehicle. At this point I PLEA PLEASE don't get a Saturn, or GM vehicle. They don't work with you. They take your money!!!!! I'm stuck with this vehicle that they can't fix or will charge you every time they fix the same item.. LIKE MY LEAKY, NO POURING inside till I have a puddle in my car and they act like they don't know where leak is coming from. a customer that will NEVER get another car from GM again!
    Get rid of it ASAP! Outlook is junk! Ours stays in the shop! I will never buy another GM product!
    Hello bgin2love1,
    We're sorry that you have had such a negative experience with your Outlook. If we can look into this further for you, please email us the following information at socialmediagm.com: your name and Edmunds username, your phone and address, the last 8 digits of your VIN and current mileage, and the name of your involved dealership.
    Amen we have a 2007 and the transmission recently broke. Got it fixed by AAMCO. Now GM turned down my claim because I didnt go to the dealer. It had 87000 miles so within the mileage requirement. It was two months beyond the 5 yrs. I agree with you and say dont buy GM they dont stand behind their products.
    Our 2007 Outlook transmisson broke this last July. It had 87000 miles on it and it was two months beyond the 5 yr requirement too. I didnt take it to the dealer because it was out of warranty. As an afterthought I filed a claim with GM for the cost. The turned it down because I didnt go to a dealer. I even offered to have them only pay half. They couldnt even do that. They sure dont stand behind their products. We bought a new car recently and you can bet it wasnt a GM. They said that they are not aware that the transmisson is a problem with this model. I said how could they not know. They just dont have to do anything since they got out money already. I am out of luck on the cost. I will be sure to tell everyone I know about the bad customer service GM provides.
  • aj2009paj2009p Member Posts: 1
    I purchased my 07 outlook pre owned in nov of 2010 with 75250 miles on it loved the room loved the smooth ride but had a clunking noise when i got home i brought it back they say the steering gear is bad and needs to be replaced since i had just purchased it i said well who is paying for that service manager says you need to talk to your salemanan which turned into me getting the run around. After finally getting the gear replaced under warranty the noise is still there so me being a car guy and being the field for 10 yrs now i kept saying to the service manager sure sounds like a banging strut top or a sway bar link he kept saying tech said they were fine get in the shop i work for had a bad sway bar link i fixed that replaced them with some moog sway bar links as the ones from factory are not greasable than evrything seemed fine than the check engine light came on po446 replaced gas cap reset code came right back a week later accompanied with reduced engine power service traction control service stabilitrac take it back i have a broken wire to the throttle body they replaced the harness and the throttle body assembly than it seemed fine but light came back p0446 again so i called them they said bring it back but i just was sick and tired of spending my days off at the dealer so i just drove with the light about a yr later i was on my way to work when the check engine light start flashing and the engine made this horrible noise got it to a gm dealer by my house this time since the dealer i purchased it from was an hr away and i obviously couldnt drive it and didnt wanna pay for the huge tow bill so i take it to COLEMAN BUICK CADILLAC GMC LAWRENCEVILLE NJ they had it for an hr i get a call and the dealer is asking me when i replaced the motor and im like i never replaced it so the servce writer says my warranty is void the engine was replaced and id have to consult my dealer PINEBELT CHEVY EATONTOWN NJ so I called them explaining my dilemma first the service manager didnt wanna talk to me than the sales manager didnt wanna talk to me so finally i called gm customer care they were helpfull with in a couple of hrs they sent a tow truck up and towed my truck to there dealer found out that it jumped time on cylinder 3 and bent a valve they said they were gonna replace it with a remanufactured gm 3.6 ly7 so id get some warranty again i got back like 6 months ago now the trans has a shutter on the highway at 65 plus and sometimes at lower speeds i take it to PINEBELT CHEVY EATONTOWN he tells me to have a seat and that they will road test it within minutes he comes back and says that i have a trans problem but he didnt have time to diagnose it that day cause it was the friday before labor day so i brought it back that wednesday and he says that the dealership is closing and that he will do all he can do with the diagnosis but if the transmission has to come out i will have to take it to another dealership so he road tested it dropped the pan inspected the fluid found no issues he wrote as follows road test vehicle on light accel can feel issue check fluid no metal no codes in system vibrates all gears call tac (whatever that is) check ratios shift point match spec check slip speed less then rpm call tac nack calibrations all correct. perform dissasemble check 3-5 wave plate and valve body if ok replace tcm case# 71-1104585338 due to shop closing not able to remove and disassemble . advised customer to take to another dealer. so i take it to COLEMAN BUICK CADILLAC GMC and they have it for a week but nothing is wrong with it since they road tested it and found no shutter but never disassembled like the first dealer said so the internals could be inspected while picking up my keys notice the service advisor filling out the vehicle mutil point inspection sheet i thought techs do that maybe my service advisor does evrything but upon entering the on ramp to the highway its starts shuttering away and is adamn dog i have to like floor it evrywhere just funny and now im stuck with this pos DONT BUY GM i cant even trade this damn vehicle in cause i owe to much so im stuck
    I located your Customer Assistance Case, aj2009p, and have notified your agent of your post.
    Kind regards,
    Sarah
    GM Customer Service
  • eeej123eeej123 Member Posts: 1
    I also have a 2007 Saturn Outlook. Last week the RPM's started reving up at different speeds and then a few days ago it started slipping real bad but then would drive fine. Took it to the dealer and they said they put all updates in it and its still not working. Now I have to take it 2 hours away to a Certified Saturn dealer so they can look at it. Also, the 5 year powertrain warranty ran out in june, perfect timing. Not happy at all.
    Good morning eeej123,
    We're sorry that the updates done by the first dealer did not resolve the transmission concerns you're having with your Outlook. If you would like for us to look into this further with you and your dealership(s), please send us an email with more information at socialmedia@gm.co (include your name and Edmunds username, phone and address, the last 8 of your VIN and current mileage, and the name of your involved dealerships).
  • chico53969chico53969 Member Posts: 1
    Hello-
    I am having transmission issues as well. I took my car back to the dealer I bought it from which is now owned by Acura cause I trust them more than the GM dealer next door. I took my car in for transmission to GM in July and they supposedly did a diagnostic and only found a gasket leak...of course out of warranty by 4 mo. Then Monday I start feeling the transmission slip so I take it back to where I bought it and they can't get any codes off it so they refer me back to GM dealer I don't trust in case its a software issue. So then I leave and plan to return the next day to get robbed of another diagnostic fee from the GM dealer and the I break down in the middle of an intersection! So I have it towed back to where I bought it cause the transmission won't move or go into gear. Of course its out of warranty now as of March and has only 83,000 miles.....I can't believe these cars transmissions don't last for what you pay for them I have a year left to pay on this thing and now I'm dumping money into before it's even paid off. I am so disappointed in this product and the fact that obviously GM knows they have these issues with these transmissions yet they let the consumer pay out their pockets for a faulty transmission. I won't be buying GM again and that's all I've ever owned. They should back their products!!! It's out of warranty so what is the point taking it to a GM dealer especially if they are just gonna charge you for something that wasn't gonna last to begin with!
    Good morning chico53969,
    We're sorry that you've encountered these transmission concerns with your Outlook this year; did you have the gasket work performed in July? Are you planning on working with your dealership or are you seeking alternative solutions at this time for your current transmission concerns? If you want for us to look into this further, please email us more details at socialmedia@gm.com, including your name and Edmunds username, phone and address, the last 8 digits of your VIN and current mileage, and the name of your involved dealership.
    Good luck with your problem Chico 53969.GM doesnt back anything out of warranty. I had a Saturn Outlook 07 that had the transmission replaced at 87000 miles and two months out of the 5 yr warranty. They were not interested in doing anything for me Eventhough it's a known problem
  • timkandytimkandy Member Posts: 3
    Sarah I am having the same problem with my 09 Outlook, I have had it in for service 4 times now and it still is having this problem. Last year when we had the issue and the dealership didn't seem to be able to fix it GM stepped in and it finally was taken care of but here we are one year later and we are experiencing the same problem. The dealership found a service bulletin and fixed that issue but within 1 week the issue was back. I took the car in they hooked up the computer but it would not throw a code but you could feel the chugging/slipping/hesitation.
    Can GM step in again and set up a case so that this issue can be resolved? I am on the edge of just getting rid of this vehicle since this issue cannot be resolved once and for all.
    Thank you. :(
    Good morning timkandy,
    We'd be happy to set up a Service Request for you to check into what's been going on with your Outlook; please email us more details at socialmedia@gm.com (include your name and Edmunds username, phone and address, the last 8 of your VIN and approximate mileage, and the name of your dealership).
    Thanks Sarah. The Dealer called yesterday they had a round table discussion with their mechanics and finally called in one of their diesel mechanics and now believes it to be the "intake coil" . They will be replacing it to the tune of over $400.00. On 3/23/2011 they believed it to be the "ignition coil" and replaced that to the tune of $357.00. I am worried about what it will be next. After reading other complaints of this same problem I have to agree with the other folks on this site that this is a systematic problem and should be covered by GM. :cry:
    Thank you for the update, timkandy. We appreciate your patience in giving us a chance to continue looking into this for you and look forward to hearing from you via email (again, that's socialmedia@gm.com).
    All the best,
    Sarah
    GM Customer Service
    Hi Sarah, I sent am email to you on the morning of the 22nd. I will send further updates there.
  • gmcustplatt73gmcustplatt73 Member Posts: 1
    I Just had my transmission rebuilt on9/21-24, I picked it up on the 24th. they said a clip in the transmission had broke. I have the half of the clip that broke. I have a Saturn Outlook 07 with 61000 miles. I paid $3000.00 to have it rebuilt. Now i don't know if I should keep it or
    get rid of it. I'm going to call GM & complain.
    300
    Gmcustplatt73
    We have a 07 Saturn Outlook that had the transmission replaced in July 2012, it had 87000 and was two months past warranty . We complained to GM about it and of course they did nothing. I wish you the best of luck with your case .
    Good morning gmcustplatt73,
    I hope you were able to get a Service Request started up when you contact us! If you haven't done so and would prefer to get one started electronically so we can contact your dealership, please send and email to us at socialmedia@gm.com with more details (including your name and Edmunds username, phone and address, the last 8 of your VIN and current mileage, and the name of your involved dealership).
  • dompdomp Member Posts: 24
    Might want to compile a list of the problems the '07ish outlook/traverse/enclave/acadias have (headlight wiring harness, water pump, transmission, sunroof leaks, etc). If you haven't already had the issue, are that you will. I'm at 90k miles and have had just about every issue I've read about on this forum, other message boards, and the nhtsa except the transmisssion rebuild/waveplate issue and power steering failure issue.
    If you have a sunroof, and haven't had the clogged drain tube water leak onto your fuse box or power steering failure issue, might want to consider getting rid of it before those happen - those are pretty expensive and I'm pretty sure neither of those are covered by recalls.
