Kia Sedona Squeaks, Rattles and other Noises
in Kia
hi, i have an 07 sedona since we had it its really noisy tappit noise and worse when cold. its like a transit van is this normal?.
also 3 weeks ago we went to over take and loss of power, check engine light came on and it was running a bit rough for a while. we went to our local dealer here in england and he said it was dodgy fuel. 2 weeks ago the same thing so this time we went to another dealer and they couldnt find anything on the machine. got the car back then went to overtake on the motorway and oh my gosh it happend again, loss of power, engine check light on and running really badly. this could have caused a serious accident we were lucky. so back to the garage and the mechinic is using it and as yet not found a fault on driving it or on the machine and it has behaved well for them, any ideas?.
also since the first check light came on 3 weeks ago when starting it up now and going through the gears it jerks its hard to emplain but can anybody help?.
we have told them we dont want the car back until they find the fault.
i have told them if nothing comes up on the mchine to take parts of the engine off and manually check but they have to get permission off kia here in england for that.
oh and any cure yet for the electric doors that play up?.
any help would be great.
jo-anne
jo-anne
Problem: "Intermittent high pitched whine or siren type noise from rear A/C unit"
Fix: "Replace the rear expansion valve...this applies to vehicles produced before 12/20/03."
If you search the "problems" forum you will see more about this noise and fix.
The only problem I have is my left rear tire looses air from new. I have to add air every 3 weeks. I'll bring it to there attention in May when I take it in for inspection and oil change.
Daniel
Daniel
Our locks also went off and on by themselves along with the lights flashing. Let's see what other problems- the horn doesn't work, the window gaskets are broken, the lights on the dash don't work... the car is a peice of crap.
Bottom line, we were told it's a computer problem and no fix available.
Guess where my van is today? In the shop, legally they had one more chance to fix it. Reguardless, we're suing. I'm done with kia and the games.
I'm sorry I have not. I just had business trips come up and this and that, newborn baby and what not and have not had time to leave it over there for them to check it out. It does not seems to affect anything that I can tell. Please let me know what they say and or do.
Daniel
Wastntime
Wastntime
Thanks Joann
Hope that helps.
The van only has 15k on it.
Anyone else had this problem? :mad:
I really like the van otherwise. Great engine, comfortable etc.
I have noticed a big difference in road noise when buying new tires for our 3 different min vans over the years.
My 2004 Kia Sedona has Kumho Tires, and they very low on road noise compared to some other tires I have had.
I replaced 1 along with sub-in of the original equip spare (full Kumho) - to get two new tires on the front of my van (at 60,000km)- They are actually pretty expensive, but I am happy with them.
The rears are still like new and so now I will rotate regularly.
Hope this helps
Chris
GUy
I'll go to the Tire Rack web site and review the Kumo. Hope they have a 235/60/R17
I have not found time to ride in the back while someone drives yet.
It is funny cause I had it in the shop at least 5 times and they kept saying there was no noise and I was imagining it. So We saw that Sorentos had the great rebate so we went to the same dealer to trade in our van, because of the noise, and the same dealer test drove it and told us that my van had a horrible noise and I would have to get it fixed before they would trade it. I took it to service and told them that the salesman could hear the noise and then they told me that there is no noise and no problem with my van. UGH!!! It makes so much noise when I turn it or hit a bump!! HELP
got missus to drive whilst i found the squeak, its coming from the bottom ot the hatch.
after a closer inspection i found that the large plastic cover on the hatch was a bad fit, check round the lock area and the opposite side to the handel.
it rubs at these locations because the hatch plastic is slightly to large.
i removed my hatch and sanded the plastic on the verticals where it goes round the lock and both horizontal sections.
replaced and i now have a very slight,very occasional squeak over rough road. probably needs a bit more sanding, but the hatch is awkward to get off so i can live with it.
its a plastic on metal squeak.
i also had the pulling to the left thing but they fixed that by rotating the strut top.
now have the steering judder, but its electrical somewhere because it happens at speed for 6 seconds then stops for 4 then starts again.
any ideas?
steve
p.s otherwise its a fantastic car
I would take your van back to the dealer to deal with the shudder. If it developed after the fix for the other problem it is probably related in one way or another.
This same lubricant can also be used to lubricate the van's sliding door tracks, all the hinges, and even where the rubber meet the windows for less friction when rolling up and down the windows. Great stuff.
