Cadillac DTS auto lights problem
 louiephipps
                    Member Posts: 9
louiephipps
                    Member Posts: 9
                    I just recently started experiencing a problem with the automatic lights on my '07 DTS.  I park the car in a carport.  When I start it in the mornings (while the sun is up), the headlights come on in the carport.  Normally the lights will go off within one minute.  Now they will stay on until I park the car.  When I return a few minutes later and start the car again, the lights do not turn on.  In addition to the headlights being on all the time, the instrument panel lights are very dim and difficult to read.  I bought the car in May and just started experiencing the problem in the past few weeks.  I can't get my dealer to understand that I have a problem.  Anyone else experiencing a similar problem?
your car has Daytime Running Lights, i.e. the headlights should be on all the time.
Also, your car is equipped with "Automatic Headlights With Automatic On and Dusk Sensor". i.e. the headlights and tail lights come on automatically when it gets dark.
My guess is the instrument panel goes dim when the automatic headlights turn on (Probably adjusts itself for night time driving?). I would re-adjust the instrument panel lights to an acceptible level when the auto headlights are on.
If the "Automatic Headlights" stay on when driving during daylight hours, then I would suspect something is wrong. Maybe explain this to the service writer. The Automatic headlights should turn off during the day. My guess the sensor or timer is bad.
Hope this helps.
-jasper
Also note another problem. When i push the map light on, it will come on for about 10 seconds, then it will go on and off a few times and then will stay out.
Any suggestions would be nice.
RCTrego
On auto off they go on but lights go off , sometimes one headlight goes out. Puzzled???
the dealer stated that must replace the lamp at $288.00 ea
seems pretty high and after looking at these postings looks like there should be a recall or some gm considderation
also amazon has them for a bit more. We have a fleet of cady's and they work
fine. you want d1s bulb. Problem is it takes 3-5 hours labor to change.
if you are doing that, change both sides.
Has anyone had a similar experience and found a fix?
I have not tried the manual setting, but will do so next time the problem occurs.
Besides the headlamp issue I also have a radio issue - reception sucks big time on am & fm but really bad on am stations. I have also had several occasions where the radio didn't work at all and when i shut he car off and restarted it, everything was fine. No idea if all of these issues are connected, but I think its computer related. What school or class do the service writers take so they can act like they have never heard of any of these complaints, WHAT CAN WE DO??
Can you please email me with your VIN and concerns? I would like to look into this further.
Christina
GM Customer Service
Thank you for your post. Can you email me with your VIN, current mileage, and dealer of choice? I look forward to your email.
Christina
GM Customer Service
SocialMedia@GM.com
MILAGE IS 57,000
I HAVE A GM EXTENDED WARRENTY.
HARRYS CADILLAC,ASHEVILLE,NC
I checked your VIN and do not see any open recalls on your DTS at this time; you are still within the following warranties until the date/mileage indicated (whichever comes first):
Corrosion Limited Warranty until 06/24/2012 (Unlimited mileage)
Emission Select Component Ltd Warranty until 06/24/2014 or 80,010 MI
I'm sorry that you weren't able to get this taken care of while under your warranty; we can explore any available options if you were to send the following information to socialmedia@gm.com: your name/Edmunds username, phone number(s) and current address. This would enable us to open a Service Request and look further into the situation.
All the best,
Sarah
GM Customer Service
My coworker Christina (who also posts now and again out on Edmunds) responds to incoming emails from this forum. If you include your Edmunds username, she is able to search the forum to gather more information, but if you were to include a description of the situation in your email that would also be helpful for her.
I hope this helps to clarify a bit how we do things on our end,
Sarah
GM Customer Service
The GM reps' function in these forums is not to diagnose and fix issues. Their purpose is to help compile information on common problems & complaints, and when possible, to help the owners by contacting the dealerships to see if they can assist in resolving problems.
It is probably worthwhile taking the design complaint to a higher level, but perhaps there is a solution out there for the issue that could be implemented.
MODERATOR /ADMINISTRATOR
Review your vehicle
This is a great synopsis! If you wanted to include this in the email to socialmedia@gm.com containing your name/Edmunds username, phone number(s), current address, the last 8 of your VIN and mileage, we would be happy to get started with the Service Request.
All the best,
Sarah
GM Customer Service
Took the car to our dealer ship and they want to replace the headlight for 490.00. but the light is not the problem. it is in the sensor. How do I make these people understand that is not the light.
Any help is greatly appreciated.
Any Clue?
Sarah, GM Customer Service
Sorry that you're experiencing some difficulties with your headlamps. What are you plans on getting this addressed? Let us know if we can look into anything by emailing socialmedia@gm.com (include the last 8 of your VIN).
