Ford Escape Engine and Performance Problems
tiffinymariha
Member Posts: 1
in Ford
I picked-up my car from the shop yesterday (flat tire) it drove fine until I got on the freeway, then started to rev at 2500+. In park and neutral it's over 5500, the mechanic I usually go to is on vacation until the 26th and we're expecting snow. Any chance this is an easy fix I can take care of? Thanks for your help! Tiffiny
I bet you the PCM is doing all the fuss. JMO!
thanks in advance
4 cylinder engines, I4 engines, are notorious for low speed vibration. Many "upscale" manufacturers use something called a "balance shaft" to help smooth out these vibrations. Obviously the lower the idle speed is the worse these vibrations will be felt within the cabin.
Since two separate dealers have said the level you are expereincing is normal I'm afraid what is, is.
Not that I disagree with you, but....
2011 Escape....
Just how slow is too slow...?
We have all adapted over time and experience to an idle speed of ~800RPM.
But in truth what if the engine could be kept running, idling, at as little as 100RPM..in favor of improved FE....??
The new electronic engine controls might well be able to do that.
And what, who's is to suffer...?
Engine lubrication/oil pump...no.
Engine cooling/water pump...no.
Power stearing...(electric..?) .no.
A/C....no.
Battery charge...no.
And coming soon....automatic engine start/stop......or should that be stop/start...??
I believe the 2011 is just the same as the 2010.
Not up to the standards of my 2005 Escape which had rear disc brakes and a full size spare mounted on a rim that matched what was on the other 4 wheels.
If the cat was glowing, the exhaust wsa horribly rich, meaning a serious overload of fuel in the combustion chambers, more than just a 1 plug misfire would cause. So, it has to be fuel related, as in the injector computer is likely opening the injectors all fully, flooding the engine.
Again, very concerned the mechanic can't figure this out. If he has now ruined two cylinder's compression, he has ruined your engine. You may have a cause of action against him if you take him to court. Not knowing who you use - I can't say, but the problem seems clear from here - can't understand how the mechanic can't see that from under your hood.
Best of luck - try someone else! :surprise:
But Ford is too cheap for that.
srs_49, "Caravan/Town & Country Electrical Problems" #656, 22 Aug 2013 4:56 am
Last week my 2005Ford Escape Hybrid engine blew up. Yes two pistons pushed through the engine block. It only had 63,000 miles on it, I only took it to the dealer for repair since buying it new (no one else would touch a hybrid). So I am looking at $8,000 plus to replace the engine. Does anyone know of a way to get Ford to help with some of the costs?
That's going to be tough with a thrown rod but you certainly can try. As it stands the vehicle is just about totaled unfortunately, unless perhaps you found a good used engine. It doesn't seem wise to invest $8000, but of course that is your decision. That's pretty unusual for two pistons to let loose, so maybe Ford needs to examine the interior of this engine before "blaming" you.
