I have been very happy with the Bridgestones Dueler Alenzas. I bought them mainly because the Michelin Energy MXV4-S8's that came with the RX were pretty bad on wet roads. Not only are the Bridgestone's great in the wet, they really changed the dry-road handling for the better too. They have much stiffer sidewalls so cornering is stronger and steering feel improved as well. The trade off is a firmer ride, maybe a bit noisier too, but worth it, imo. Let's face it, the RX is no sports car, but these tires actually provide some fun on curves and on/off-ramps. The tread looks more aggressive than the Michelins and that may make them appear a bit wider, but they are the same 235/55x18 size. My Alenzas currently have about 30k miles and look good for at least another 20k. The tirerack currently lists the Alenzas for $159 each and you also get a $100 visa card if you buy 4 (no, I don't work for tirerack.com, but I've been a happy customer for more than 20 years).
You are welcome.
MD
The wind noise so bad at highway speed. Does anybody have this problem?
You just purchased this 4 days back, and wind noise problem? Didn't you notice on the first day?
I use reg unleaded (87 octane) gas for my 2001 RX.
What octane gas are you using for the 2010?
What are mpg in city?
I have tried all three grades of fuel, measuring mileage at fill-ups each time (I don't use the on-board computer). For the first year or two I was really obsessive-compulsive about it. Overall there was no discernible difference in mileage or performance. I even compared different brands and saw no difference. Maybe it's my routine driving that is always about 2/3 highway and 1/3 local. Only real difference was 1 mpg lower with winter gas.
MD
Me ES runs great on regular although a higher octane is indicated in the owner's guide. I hear no pinging and the car has great pick up and great mpg.
No modern day engine is designed to use premium exclusively.
It's likely the best FE might be obtained with Premium but regular can be used and just might be more economical overall.
Especially to the "boy-racer", 0-60MPH mentality "set".
As a general rule the advertised HP rating is only with the recommended premium fuel.
"...waste of money.."
Depends on the price spread and mpg attainable between the two octane levels.
Did you ask your mechanic his thoughts on 87 octane-does he think mpg would not be as good which is what I was told by a mile or so per gallon?
When I inquired of the details I was told that the engine used the more sensitive new non-resonant knock sensors and if even any small level of knock/ping was detected for which timing adjustment could not be done EFI would be used to enrich the mixture.
Apparently with EFI and the new knock sensors a high compression engine that would normally require premium only can run safely on regular provided the mixture is enriched beyond the point of dieseling due to compression.
So if you're driving in hot weather (when higher octane is most usable), climbing steep grades, full load, etc. you may want to use premium to avoid the resulting retarded engine timing, which ultimately will affect performance and fuel economy to some (possibly not noticeable) degree.
It shouldn't hurt the RX to run on 87 octane, though. Just performance. Especially if you drive moderately on flat terrain in cool weather.
P.S. Lowering the tire pressure will make the ride softer and more dampened, definately at the expense of handling sharpness (on pavement) and fuel economy. I run at or near the max suggested on tire sidewall to maximize handling, fuel economy and tire life. But the ride does get "stiffer" which I don't mind.
Probably not....
In modern day vehicles, at least for the last 5-8 years, spark knock is often NOT the problem, so retarding the ignition is rarely the solution. The engine/transaxle ECU is capable, using the crank position sensor, to tell if the detected knock/ping ocurring prior to ignition is due to low octane fuel. For low octane fuel the solution is slight enrichment of the mixture under knock/ping conditions, high throttle openings.
For knock/ping due to engine lugging a simple downshift is used. If there is no downshift available then DBW will be used to dethrottle the engine and prevent damage.
I would presume eventually you would get what you want but it might take a while. I had 2 dealers tell me Lexus tells them what they are shipping.
I "ordered" the new hybrid and there are certain options I do not want (heads up, rear seat entertainment, park assist, accident avoidance) and certain I do, (sport package, levenson and the full lux and comfort pkg)
We will see--but I have time other than just wanting the car.
I have not found a dealer able to order me a hybrid yet. They are telling me I might not be able to order until July and may not receive the car until 2-3 months later. What were you told by your dealer?
The environment is an add on--so its hard to justify hte 5k more unless you are a believer in the above
anybody have an idea of when the hybrid is going to land here in the states?
What kind of gas do you use-have you tried regular?
Also, what was MSRP and price you actually paid before taxes, etc?. When did you purchase? Maybe comment under pricing forum.
