2004 Dodge Stratus Camshaft Position
I have a 2004 Dodge Stratus with a 2.4 DOHC motor and the check engine is on and when I read it It says Camshaft Position sensor A bank 1 CKT Intermittent I have replaced the Camshaft Sensor and Now the light wont go off If u push donw on the gas the car acts like its not getting any gas and jerks and then goes and does that every so often and once u get over 65 mph it wont go at all and I cant reset the computer at all now can u help
identify part please
gear that holds the timing belt, while replacing timing belt my son broke some teeth off this gear. I assume it's the upper cam gear, is this correct? need to identify to purchase replacement.
please advise
