Hyundai Entourage Tires and Wheels
The factory tires on my 2007 GLS seem OK for normal use, but the tread design doesn't appear to be very good for snow.
I would like to get 2 more wheels and permanently mount snow tires on them for short term use in slick conditions. I am fortunate to have a garage and tools (jack, air wrench, etc.) for quick change over.
Anyone know of an aftermarket or used source?
Also, I am in need of a wheel cover for a 2007 GLS. Anyone know of a source? Would like to find used or aftermarket. I'm sure it can be obtained from Hyundai, but likely is pretty expensive.
I expect Kia Sedona wheels will fit. Not sure about wheel covers. Mine are a 7 spoke design
I tried some of the sites like Tire Rack, but no luck yet. The wheel must be fairly new type. Used ones seem to be rare. Dealer can supply for about $120. If by next fall I cannot find used or aftermarket, I may break down and buy from the dealer.
Suggestions welcomed
So long story short here's what I did. I mounted studded snows on my factory steel wheels and then bought a set of 2007 18" Escalade wheels off e-bay for the amazing price of $100 for the set of 4 with center caps. Normally these are pretty common for $199 with $100 shipping. Then the center bore has to be enlarged by a machine shop which actually cost me $120 more ($30 each) for a quality job in a small town. I went with 235/55/18 Michelin tires on this setup which I also found lightly used (20%) on e-bay as they are stock on some Magnums, Chargers, 300c's, and Lexus SUVs. I also bought new lug nuts to fit the wheels better and with shipping, mounting, balancing, machining, etc the total was $600.50. I didn't put the pressure monitoring valves in the 18's but they are in the snow tires. I'm not sure how much more that would add to the cost or if the ones in the GM rims would be able to be reprogrammed but my wheels didn't have them anyway.
They set out a little more then the factory 16" wheels and 225 tires but they don't rub in the turns on the front or against the sliding doors when opened. I'd say they are out 1/2-1" more then the stock tires or about even with the lip of the fender at the top of the arc.
A rude dealer would probably say this is going to void the warranty but laws are clear the burden of proof is on the manufacturer that the modification caused the failure. I bought this van used so I only have 3 1/2 years left on the warranty anyway and I'd probably swap to the stock tires if I thought I was having a serious warranty issue I wanted checked out.
I'll try and put a picture up but we are leaving for a spring break. I looks really nice IMO. Next I'll maybe put on some chrome door handle and maybe mirror covers and then leave well enough alone. I think it's one of the best looking vans from he factory I just didn't like the 16" steel wheels with hubcaps!
http://www.wheelsandcaps.com/catalog.asp?Make=HYUNDAI&Model=ENTOURAGE
so a set of factory alloy wheels with shipping would be about $800, snow tires mounting and balancing another $550-600 and then still you would have to buy a set of tire pressure monitoring sending units to go into the new wheels to make everything factory.
