Pilot Fuse Problem with Cell Phone Chargers
For my new 2007 Pilot, I am on my 4th or 5th set of radio or ACC/Cigarette lighter fuses because my Verizon car phone charger shorts out those fuses as soon as I plug it in. (Sometimes the radio fuse blows, other times it is the ACC/Cigarette Lighter Fuse) This same charger is not a problem in my 03 Odessey or in my 96 Accord. When I call my local dealership they say that other people have had similar complaints but they say it is a Verizon issue.
Is anyone else having this problem? Does anyone have any suggesstions? Thanks
The dealer tested the car and could not find anything.
Any ideas what may be going on ????
btw, the Dash , around the Radio, has always had vibration sound, as if something is not quite fastened in there !
2006 Honda Pilot: - Radio and power outlets failed.
The passenger side fuse box should be under the dash on the passenger side just to the right of the passengers feet. I suspect the fuse in the passenger side underdash fuse box is the one you are looking for.
Fuses associated with the front power outlets are Fuse #9 in the passenger side underdash fuse box and Fuse #54 in the main underhood fuse box.
Both of those fuses also affect the radio.
For the rear power outlet it is fuse #6 in the auxiliary underhood fusebox.
The main underhood fusebox is probably the one you already checked on the passenger side under the hood.
The auxiliary fusebox is on the drivers side under the hood next to the battery.
