Lincoln Navigator Power Lift Gate
Has anyone had problems with the lift gate opening on its own? 3rd time it happened to us today, the glass was smashed out and door was damaged on a parking structure after we drove away with closed door.
Power lift gate option appears to be dangerous on the 2008. Anyone else had this fiasco?
1) It does a lot if you are closing a door while it is going down, it will go back up. I think this is because the air pressure in the truck is pushed out the back and it thinks it hit something, so it tries to return the position. If you just barely tug on it in either direction it will stop and go the other way so it doesn't kill someone or smash things.
2) It did it to me closing it. It would get to the closed position and just opened right back up. I was closing it with the remote. There was nothing in its way. I don't know why it kept doing it. I tried closing it 3 times with the remote. I finally just grabbed the pull handle and shut it the old fashioned way. It seemed to cure it but I do look before I walk too far to be sure it closed :shades:
(I only use the remote to open and close..never manually) when I close it with the remote the liftgate will come down and then go back up..as if something is blocking it (there is nothing there) so I have to close it with the remote and when it gets down to the point where it slows to latch I physically have to push it closed to get it to latch..otherwise I would be in an endless loop of it opening and closing. Sometimes when I get in the car and start it up I will have the "Liftgate ajar" message..so I have to turn off the car, get out open the liftgate and then push it closed at the end of the cycle. There is no rhyme or reason to this happening. There are also times where I will go out to the truch and the lights on the mirrors are on as are the interior lights...so again, open the liftgate and when it gets to the end push it closed.
Randomly there are times that the remote won't work. It won't lock or unlock (Both remotes when this happens) won't open the glass or the liftgate. Then I have to start the car and turn it off. Then the remotes will work. Today the remotes would do everything EXCEPT the liftgate.
Please, for the love of God, help me figure this out. Today my battery died because the lights were on when I went into class and I didn't notice it...needless to say I had to get my battery jumped.
Oh I should mention that we tried the resetting the car battery by disconnecting it.
I have a 2005 Navigator doing the same thing. Anyone know where this reset is? Dealer would not tell. Jerk regularly wants my $75.
I'm doing yet another internet search, and found my old thread. Still nothing around anywhere. I forgot I even posted this.
the lift gate will open completely and then reverse and close...won't stay open.
If I park it in the sun on a cold day, it will usually operate correctly.
Anyone experience this...any fixes?
Parts on order as follows:
ebay item:
StrongArm 6106 L&R (2) Rear Liftgate Gas Lift Supports/ Tailgate, Hatch, Struts
mrlousstuff is who I bought from
good luck
