GMC Envoy Losing Coolant
Envoy Losing Coolant very slowly
I have a 2003 Xl. It has been losing about 1/2 gallon of coolant every month. I have looked every where for leaks with no luck. Any suggestions???
Reg
The slows loosing coolant are eat in engine combustion chamber and this are the reason because over time the gasket often havin partial such problems in this car model and need replacement!
I know.. it's very expensive to open the engine head but, this are the necessary job to fix..
Othervise wait for suprprice when on trip and the engine will stop workin for good now flooded with collant including full engine Oil Case and more..
Now the engine will need a heluva job to clean the whole Oil lines and cooling system in entire engine where oil + coolant remains almost everywhere..
Inregrads the labor and used times as well as new Gaskets totally the price will heat the Heaven high!
@just.. 1 cent
(35 yrs Technician Mech)
I have the same problem and I'm getting really annoyed !
What is it, did you find out?
that is where I could trace the leaks to.
replaces it and no leaks at all.
I had to take off the windshield washer tank, lair filter, air conditioner condenser, very easily move this out of the way,, the overflow tank for the radiator and then finally take off the three the lines and remover the heater control vaule .
Make the line because you'll be taking apart a lot of lines and number them so you know where things go back.
$40-$50 and your done.
