Kia Sedona Doors and Exterior
in Kia
Also, same body shop replaced front bummber skin. After about a year, one of my fog lights fell out of the opening. After crawling under to inspect, the light attaches with 3 scres to tappings molded into the bumber skin. All 3 of the tappings have broken off. Probably by over tightening by the body shop. Is there another way to attach this without replacing the bumber skin AGAIN??
On the fog light proplem... If the broken screw posts are still attached to the screws carefully remove them. Buy J B WELD epoxy glue (4 hour set only) reset the broken posts and carefully tape them in place. 24hours later you should be able to re-attach
the fog light ....(..Walmart sells this glue)
Checked another and they do stay open and require you to pull the handle to release them. So is there a common issue and an easy fix ?
Did I tell you that my wife still hates this van.
Glad it wasn't just our family that had trouble getting our Sedona doors open during the deep freeze. Will ask the dealer for help.
