Visitor Agreement.
So far no problems, but it has been only 3 months/ 3k miles since I had mine replaced.
Good luck with your replacement !
http://www.autosafety.org/uploads/AcuraTransTSB.pdf
135K miles
Ran like a dream
I was hoping to get 200K out of it...
c'est la vie!
Now, regarding the low mileage 1997 Acura you mentioned, there's no such thing as a 2.5 RL. Acura made a 2.5 five cylinder TL and a 3.2 V6 TL, and a 3.5 RL, but the model designation you mentioned doesn't exist. The good news is that the three models mentioned above are solid cars but, obviously, old.
The 2.5 TL was the successor to the 2.5 Vigor, and, except for the engine, is very similar to the 3.2 TL of that year. The 2.5's suspension was tuned more for sportiness, the 3.2's for luxury. The 3.5 RL is a larger luxury car than the TLs. It's good, but some would say it's somewhat boring.
The mileage, 14,000 miles over 12 years, is good and bad. The good part is obvious. As for the bad, if the car sat for months at a time, say, that's not such a good thing. I'd try to find out about the maintenance, why it was driven so little, and how it was driven.
Good luck, and let us know what happens.
The car was owned by an elderly lady who just passed away and her family traded her car in to purchase an Audi....silly them
Why did you get rid of the Vigor you loved so dearly?
As long as Acuras continue to be good to me, I will be a lifelong customer!
Circling back to the very low mileage RL you're considering, be prepared to change the fluids, belts and hoses if the haven't been replaced according to the schedule in the owner's manual (not the Acura dealer's schedule). Belts and hoses, and some fluids (eg. brake fluid and coolant, but not engine oil) not only wear with mileage, but also deteriorate with age. If the car checks out, it should provide excellent service for you.
If it is included, is there an average mileage when the transmissions failed?
Thank You!
The water pump needs replacement.
I was told the timing belt needs to be removed in order to replace it.
Is that true?
The estimate was around $1K.
The cost was $2000.
Im buying a new Acura TL and i was wondering how many miles an Acura tl has when it comes into the dealers lot. In other words, when its coming from the factory.
If your car is well maintained and runs well, other than for the transmission, it should be worth more than scrap value, regardless of what the used car pricing books may tell you. It would be difficult to replace a good '02 for $4,000 - $4,500.
Transmissions aside, TLs are well designed and well built cars, that can last well over 200,000 miles with proper maintenance and reasonable care.
I'd begin by asking why they (the Honda dealer) charges a lot more than the Acura dealer. I wouldn't disclose what you were quoted by Acura, other than it's considerably lower than what they quoted, and then only if they ask. You don't owe them any information.
Good luck, and let us know how it goes!
How many miles did your '99 TL have when the transmission failed? Are you the original owner?
In fact my other leased car, I can't wait to turn it back in. It's a large crossover & only get's 20 Miles per gallon on open road & doesn't drive as well as my "old" Acura which doesn't burn oil and gets 28-29 miles per gallon--and it's paid for. LOL
By the way, timing belt and water pump are scheduled at 105,000.
So here's the deal... this past weekend I was driving on the highway when the TCS and Check Engine lights both illuminated simultaneously. Last time this happened, it was a bad ignition coil that needed replacing. About 20 min. later, it felt like someone put my car in neutral, I was on the interstate and my car began to slow, but when I hit the gas, the engine revved but I was still slowing down. Finally when it got down to about 20-25 mph the gears caught again and I was able to get off an exit. When I looked at the bottom frame of the car, there was transmission fluid leaked everywhere. When I checked the transmission fluid itself, it was higher than the normal line, and looked diluted as though something was leaking into it, and it was consequently getting displaced somehow. As I opened up the hood, the transmission itself emanated white smoke for about 5 minutes.
I got the car towed home and about 5 hours later started it back up. It drove as though nothing was wrong, took it up to about 70-75 mph and through each gear and nothing slipped or felt off. I took it into a transmission specialist to get it checked out anyways.
The mechanic told me it looked pretty bad, on the report it said Code 740 - 4th Pressure Switch Failure, and Code 1740 - TC Clutch System Failure. They said they can rebuild the transmission and will get back to me tomorrow on the cost.
A few questions for everyone:
1) Is it worth the rebuild or should I just replace the transmission?
2) I have a friend who recently put in a new transmission on a 2000 Accord, is this transmission similar enough to that one?
3) If I need to limp the car along for a few weeks before replacing/rebuilding the transmission, would using something like a Lucas Transmission Fluid Stabilizer allow me to do this?
Thanks in advance for all your help!!
-Jared
