Nissan Xterra Vibration Noise
                    I have a 05 Xterra with 35k and i have for some time now a vibration sound from mostly the rear when at a stop light. It seems to be more extream now with the more mile i put on it.  And the cold weather seems to inhance it..  I have had it in the shop a couple of times and can't find what the problem is!  I hear there are a few others out there that have this problem!  I have 500 miles left on teh warrenty and would like to get it fixed!! Its getting really bad now!  Any one out there have this problem?
Good luck!
I also have the high-pitched squeak coming from the rear end when I go over bumps (no matter the size). It's driving me crazy. I am taking it to the dealership this week to get looked at. Anyone have any luck of finding out what's going on or getting their problem fixed?
What I found to be the problem with mine was the exhaust rattling. There are several points where there is an exhaust shielld above the exhaust pipe and the pipe is attached to the shield with a steel band. The In two of these places the steel bands had rusted away causing the exhaust pipe to rattle against the upper shield.
I just bought a couple of hose clamps from the hardware store and tightened swapped them for the rusted steel bands. I hope this is the same problem some of you are having, because it is a quick fix.
Do you know - do I need to put some damp material between the shield and the pipe before I tighten the pipe with the hose clamp? Anyone else did this? Thanks -
