Toyota Yaris Tire and Wheel Questions
Hi, somebody can tell me the specifications of the offset distance and bolt pattern of the 2006 yaris hatchback?, this its because i want to buy a set of 4 rims (16") with the following specifications:
Bolt Pattern: 4:100/114.3
Offset: 42
Will this set of rims fit on my car?
Thanks..
Offset: 42
Thanks..
Came on about a week ago, I verified the pressure in all the tires and they were right at recommended levels with one tire being about a lb lower than the other three. Just to be safe I aired everything to the exact same value, and verified all the lug nuts were torqued properly as well.
I finally disconnected the battery and reconnected and no joy. The light still popped on as soon as I started the car up. Is there a) a different reset method - I know some modern cars aren't fooled by the battery disconnect anymore? or b) another idea in general?
From poking around a bit it seems like at least some Toyota models have a button in the glove box or on the steering column that you hold down to reset.
Your owners manual should have that information. Or a call to a dealer or competent garage should get you an answer as well.
Yarisworld.com forum
I took my car to the dealership and watched them reset it.
1. With the odometer on trip A and the ignition off, press and hold the reset button.
2. Turn the ignition on (no need to start the car) and wait for it to start blinking. It will count down and when it's done, it'll be reset.
Also, finally found on page 243 of the 2008 owners manual.
Toyotaownersonline.com Registration
You can also order it through your dealer with the following publication numbers (but it's not free)
Publication
Description
Pub #
Price
Repair Manual
VOL. 1
RM07Q0U1
$121.38
Repair Manual
VOL. 2
RM07Q0U2
$128.97
Repair Manual
VOL. 3
RM07Q0U3
$144.14
Owners Manual Mexico Sdn
NCP93
OM52788S
$15.95
Owners Manual Mexico H/B
NCP91
OM52838S
$15.95
Owners Manual Sdn
NCP93
OM52787U
$15.95
Owners Manual H/B
NCP91
OM52730U
$15.95
Electrical Wiring Diagram
"NCP91,93 "
EM07Q0U
$66.21
Collision Repair Manual
"NCP91,93 "
BM00R2U
$16.45
MPG is really dependent on distance divided by fuel use. If you have a greater tire height, it may appear when you divide the mileage by the fuel use that you are actually getting worse gas mileage. In reality the mileage is about the same, but your odometer will actually just be inaccurate (as it was based on a lower height tire). You will have actually traveled farther than the odometer will read.
It is actually tire width that has the greatest effect on mileage. A wider tire has greater friction and thus has lower fuel efficiency in general.
Would tires size 190/70/14 fit on a 2008 yaris hatchback basic model.. stock everything?
Plus Zero
175/70-14
185/65-14
195/65-14
Plus One
185/60-15
195/60-15
205/55-15
Plus Two
195/55-16
205/50-16
Plus Three
205/45-17
215/40-17
Plus Four
215/35-18
225/35-18
P.S. I don't know anything about tires and wheels, i just know that the tire size is like 15".
We bought a '09 3 door white manual Yaris. I was not happy with Toyota for putting on the 15 inch rims/tires. Bigger tires cost more and more to turn! More rubber contact to the road means more friction.The 14 inch with smaller tires will give you a better mileage. It has taken a lot of care and time to relearn matching this cars clutch and gear match ups since the engine revs are a lot quicker than other standards in the fleet. We keep our speed no more than 60 mph and use the highest gear possible to cruise in. In other words, drive it like a diesel. RPMs under 2000. That got us to 40 mpg.
At 5000 miles, we caught a nail in the side wall of the rear tire. Rather than replace it with another 15 inch. We located two 14 inch rims and carefully selected another 14 inch tire with the same height as the 15 inch ones. 175/70 R 14. That one has the same width as the recommended 175/65 R 14 and the height of the 185/60 R 15, but more narrow. Best of both worlds. That bumped up another 2 mpg's. I am waiting for the next few tanks to come in to decide if that reading is in error or correct. So at this point it is looking like 42 mpg's. City. Oh, I do a bit of coasting in Neutral as well and use the cruise control.
I copied my post from another forum and brought it here. Rule of thumb, the fatter the tread gets and/or the shorter the tire, lower gas mileage. So best tire/rim size should be a 175/70 R 14. If you go up another size in the 14", the tread gets wider which will defeat your purpose. I wish 13" rims would fit in the front like the older Tercel and Mazda 323's.
also, will this work on a 2007 Yaris?
Thanks for the information.
Tom MY 2007 YARIS HATCHBACK
do I just put 15x5 by 100 thread? 4 holes? 5 holes?
Can I just put em on or do I need to alter the vehicle in other ways? Or does that matter by what size I buy. I think the same size with some style would be fine. Any advice would be great. Thanks
So be careful. If you want to get the same exact wheel that came on the car, you're best bet is a dealer. If you are willing to have something "about the same", then try Tire Rack, Discount Tire, or a local tire dealer.
