Buick Rendezvous Temperature Problems
I recently bought an 02' Buick Rendezvous and immediately had to get the Manifold gaskets changed. A couple days after I picked up the car, I noticed the Temperature gauge fluctuating. On The freeway, the temp gauge would stay around the 1/4 mark, but when stopped on city roads or at lights, the gauge will constantly creep up until it reaches the 3/4 mark, and then slowly go back down to the 1/2 mark. Can anyone tell me any ideas of whats going on??? Also, last night the Service Engine Soon light came on while driving on the freeway.
Thanks In Advance
Thanks In Advance
They have replaced the AC control module and checked the actuators and they are opening the doors properly. The tech said there is a problem but they can't seem to fix it. Thanks for any help Dale
Thanks for you help!
Rick
Hope this helps anyone!
Are all the problems I am reading about typical? First thing I did was to check the fluids in the car and the coolant tank was empty. Can't wait to see how long it holds anti-freeze!
Tom
Thanks for any feedback and solutions
In the 2002 and later Buick CXL Rendezvous..
The overheating problem will never go away! I realized there was a problem when I raised the hood and tremendous gust of heat hit my face!
The engine is in a restricted compartment area under the hood with very little exit to remove heat buildup!
The heat just keeps building up! So badly, it blisters the paint at the only escape rout that it has near the rear center of the hood ,
With an inspection, you can see the rubber guard on the hood seals off the windshield and the heat crawls to the two ends of that rubber seal then back to the highest point at the center of the hood..
The compartment is not big enough to keep the engine from it’s own heat!
The cause is a bad design of the engine vent system!
I cut the top half of the rubber seal (2 foot x 1”) That way there is still enough left for water run off from windshield area .. Be careful not to cut away in front of air screened air vents My CXL is now a cool tool...
Bud Crawford Coopersburg PA 18036
The engine is in a restricted compartment area under the hood with very little venting to remove heat buildup!
With an inspection, you can see the rubber guard that seals off the windshield, the heat crawls to the two ends of that rubber seal then back to the highest point at the center of the hood exit.
I cut away 12" to the right and left from center of the rubber seal (total 2 foot x 1”) That way there is still enough left on the bottom for water run off from windshield area .. Be careful not to cut away in front of air screened vents Check to be sure water cannot hit your engine!
This cure seems like a drastic move, but beats a blown engine! ...My CXL is now a cool tool...
Bud Crawford, Coopersburg PA 18036
The engine is in a restricted compartment area under the hood with very little venting to remove heat buildup! ( LAW! Heat rises )
The heat just keeps building up! So badly, it blisters the paint at the only escape rout that it has near the rear center of the hood.
The cause is a bad design with no engine venting system.
With an inspection, you can see the rubber guard that seals off the windshield, the heat slowly crawls to the two ends of that rubber seal then back to the highest point at the center of the hood and exits blistering the hood there.
I cut away 12" to the right and left from center of the rubber seal (total 2 foot x 1”deep) That way there is nearly 1" left on the bottom for windshield water run off .. Be careful not to cut away in front of air screened vents
When finished, ("with cold engine") check and spray a lot of water on the window and watch the run off to be sure it cannot hit your engine!
I like your idea of "letting the engine compartment vent". From a science perspective, it makes sense. Well ventilated items do keep cooler. However, I'm not too sure if cutting out rain cutter plating is the most optiminal modification. Especially if someone lives in harsh winter / snow with massive April showers climate - like in my region.
I'm wondering if a rear position hood vent might be a better "let if vent" mod. Instead of installing a forward facing hood vent, I wonder if a backwards installed "air flow" vent would be better. For example:
http://ecx.images-amazon.com/images/I/51BCH7H2HYL.jpg -> as a nice "low profile" hood vent to use.
http://www.caranddriver.com/var/ezflow_site/storage/images/news/car/09q4/lingenf- - elter_455_t_a_concept-auto_shows/gallery/lingenfelter_455_t_2fa_concept_shaker_h- - ood_scoop_photo_4/2963458-1-eng-US/lingenfelter_455_t_a_concept_12_cd_gallery.jp- - g -> example of rear facing vent.
If I lived in hotter region (like lower USA regions), I would install a hood vent and install it backwards. Thus, air flows into the front grill area and that hot air flow out the top of the rear hood. Using this idea, no rain gutter platting would be cut instead.
As implied, I love your "let if vent" idea. However, I'd use an backwards facing low profile hood vent (on the rear hood area) instead.
Also have had all window clips replaced numerous times. Now need to replace driver door window motor mechanism lord knows what that will cost.
All the best,
Sarah
GM Customer Service
When vehicle overheats typically we pull over to side of road and shut engine off. Wait 30 seconds to 1 minute and restart engine and temp gauge drops back to normal operating level. It does rise to over the "12 o'clock" position and close to 3/4 way to hot setting on gauge but the aux cooling fans kick in and drop temp the normal reading on gauge. Completely at a loss as to what to do now. Thinking of a complete radiator purge and flush and possibly replacing the water pump to see if this corrects the problem. Any other ideas out here as to what the problem is? Thanks.
I am the original owner of a 2003 rendezvous with 61,000 miles and latley hav e noticed that the engine coolant is running low and signs of coolant are in the oil.
I have heard that the intake gasket problem is a known issue on these vehicles and was wondering if it would be coverd/
