I lost my keys to my 1998 cadillac deville, I had the dealer make me new keys but the ignition had been changed and key did not work, I found a copy of my original key i lost but does not have a Chip so i had a locksmith make a new key like my old key using the chip the dealer made me. But the car still says starting system disabled after a few seconds, then it says remove key, wait 3 minutes, wait 2 minutes, wait 1 minute, inster key, start car. but only elctrical turns on, i cant hear the starter or anything then it says the same thing remove key, waith 3 minutes..I dont know what to do. I have bought two keys , from dealer and locksmith
carlwintheiser@yahoo.com
I had the dealership replace both crankshaft position sensors and the tech also suggested replacing the fuel filter. I did both.
1100 miles later, the car is running perfectly and hopefully it will continue to do so.
They don't fail much, but the starter might be going bad. You have a 15 year old car. The starter isn't easy to replace, it's inside the intake manifold.
Also, the positive battery cable is long on these cars and is not cheap.
Did you check the battery with a load test? Even if it is only a few months old, it could be failing.
2001 DTS.
had the car stalling on me . Or the idle would run high at stop lights . I first checked all the codes . And one came back as a catalytic converter issue .
Further investigation , realized that the catalytic converter code can also be caused by toour much air getting into the intake / throttle body . Or possibly a air sensor issue .
( rare but possible )
THE FIX , and I'message writing this because it drove me so crazy I want to help others .
it was so simple .
I removed the rubber boot from the air filter to the throttle body . I pulled out the sensor nearest the butterfly valve gave it a cleaning with alcohol prep pad . AND applied a NEW O-RING Before putting it back in . I also cleaned out the butterfly valve assembly back to its former shiny glory . .
I than put it all back together . And here is the part that I believe fixed it . TIGHTEN the clamps! The worm ring clamps . For whatever reason they loosen up over time .extra air was seeping into the intake . And causing the car to run LEAN. Raising the idle . And also at times causing a stall after I start the car or at stop lights . one of these processes , not sure which one solved all my issues . No more check engine lights . No warnings . No codes . Runs like it did from the factory .
Simple fix . It's worth a try . And my car the check engine light turned itself off without me clearing codes or manually turning it off. And with the cleaned up throttle body , I must've gained about ten horsepower on my 15 year old 122,000 mile cadillac dts. It MOVES now .
Also gas mileage has improved .
I'm so confident now in the performance of the car and reliability I even started spending money doing modifications like H.I.D headlights and aftermarket pioneer navigation systems .
Good luck to everyone having this issue . Check o-rings that possibly dried up . make sure all clamps are tight . Make sure that throttle body is clean !
I'm wondering, in this case, if there's another variable you aren't noticing that affects the stall.
