Hyundai Sonata Subframe Rust
                    Hello, I just registered to tell my own story. I own a 2001 Sonata GLS with 148,000 miles. I hope my story will help others.
While I had my Sonata at my mechanic for a ball joint and a new tire, he called me to tell me my subframe was completely rusted out and it is a safety issue and I should take it up with Hyundai. So I did, I called Hyundai consumer affairs and made my case very strongly that this is a clear safety issue and a subframe on a car should NOT be rusting out and if Hyundai does not fix this on their dime that I would make a huge stink about this. They admitted to me on the phone that this is not "normal" and to take it to a dealer for them to confirm the issue. I did that and they did confirm the problem. The service manager said to me he would talk to his rep and call me on Monday(today), but stated that because of high mileage and the fact that I havent been doing regular servicing and been a "loyal" Hyundai customer they might noy pay for the repair. Watch out for them playing the" loyalty " card. It's [non-permissible content removed]. Force the issue with them, this is not a mechanical thing, it is a safety thing and this should NOT happen! Be forceful in your comments, but remain respectful so they will owrk with you.
I just now got a call and they are ordering the part and repairing it at NO COST TO ME! I will have my car back bby Thursday or Friday with a new subframe.
So I hope this info helps someone out there. If you own a Sonata have the subframe checked before it breaks while youre driving. Luckily mine was found out before any more damamge was done to me or my car.
You can refer to my case number : 3254818
email me if I can be of help or support, Hyundai will pay for this to keep it from becoming more publicized and becaome a recall.
[Email removed]
[Email removed]
When I called the dealer on Tuesday (8/5), they wanted to see it ASAP... Just picked it up after they looked at it--they need to order the part. Already been told it will be a no-cost repair (even got them to give me a loaner for the two days they'll have it).
BTW--looks like it is for 1999-2001 and maybe even 2002 model years and mainly in areas with heavy road salting:
Hyundai Sonata frames rust, U.S. NHTSA investigates
Have your regular mechanic check it next time they have it up on a lift--if they see anything, take it back to your dealer...
Corrosion can cause suspension to fail, wheels to fall off
http://www.lemonauto.com/complaints/1_hyundai_recalls.htm
bryceturnerwv@yahoo.com
I called the Hyundai corp 800 # and was assigned a case number and told to take the vehicle to a dealer to verify the frame rust was the cause. I told them it had to be towed and i would need a rental car. I called the dealer to inform them i was having it towed to them and would need a rental. I asked if Hyundai corp had called and authorized the rental and was told, "dont worry we'll take care of you.".
Two days later i got a call from the dealer saying that Hyundai would replace the frame at no cost but will not pay for any of the other damages caused by the accident and they would also not pay for the tow or car rental.
I have filed a complaint with the Attorney general's office and registered on the NHTSA.gov site.
My Hyundai case manager will not take my calls and no one will tell me why.
I was told the regional district office made the decision but will not give a name or phone number to call. I was told "they call you, you dont call them".
Does anyone have any suggestions?
I have found the dealers have been more cooperative with thier LOYAL customers.
Tom Baker Kansas City Mo
tntnknb@juno.com
After setting up an appointment with a local garage, I got online and found this site. I then went out and looked under the hood. Sure enough, there was a bunch of rust and a hole in what I think is the subframe.
I contacted Hyundai at the national number and the guy was very professional and said that he would assist me. When I told him what the problem was, he responded by saying that he hadn't heard of this problem before. I assured him that I had found posts by others that had the same issue.
He said that he would send out a tow truck through the Hyundai roadside assistance program and tow my car to the nearest Hyundai service center for no charge. Within 45 minutes the tow truck was here to take my car away.
In the morning, I will call the service center and find out more.
Here is an image that I snapped right before the tow truck arrived:
Have any of you ever heard of this same sub-frame rust problem happening with an Elantra? I have a 2000 Elantra and just spent a mint to get it fixed...
Nancy
*******************tntnknb@juno.com**************************
Tom Baker
There are 110,000 miles on the Sonata.
David
Tom Baker Kansas City MO
tntnknb@juno.com
All Hyundais, purchased new, come with a 7year/unlimited miles anti-perforation warranty.
The following is from HyundaiUSA.com:
Covers 7 years unlimited miles starting with 2005 Model Year (previously 5 year/100,00 Miles for 2004 and prior model years).
Covers perforation (rust hole through the body panel from inside to outside) corrosion of original Hyundai body sheet metal due to defects in material or factory workmanship, under normal use and maintenance.
Excludes surface corrosion
It doesn't specifically mention the subframe, but perhaps this would be a good way to start talking to Hyundai about a warranty issue.
Here is their contact information (also pulled from HyundaiUSA.com):
You can reach us at:
Hyundai Motor America
P.O. Box 20850
Fountain Valley, CA 92728-0850
Phone : (800) 633-5151
Email : consumeraffairs@hmausa.com
My suggestion would be to call their customer service line, and see what they can tell you. Let us know how it works out.
The NHTSA recall ID is 09V124000. You can either find details at the NHTSA site or at sites like Edmunds.com (look up the 2000 Sonata in the Used Cars section, and there's a link to recalls).
The only thing the said was that we could file a Good Will Reimbursement Form after the car was fixed and we paid for it. But we really cannot afford an $800+ bill right now, especially since it was no fault of ours for the frame breaking. Any help would be awesome!!!
Also I found there is a recall for - 2000 Hyundai sonata suspension recall- ( sonta suspension recall - ID# 70094 ) In that article they mentioned that this issue is due to the subframe rust. Hyundai recall date is APR 16, 2009.
Hope hyundai will take care of the issue.
Tom Baker Kansas CIty MO
For me, dealer service guy told that better not to drive the car. because the subframe rust is too bad. So I just left the car at the dealer service center. they ordered the subframe and waiting. hopefully it come will come by today or tomorrow. After that I will come to know. My car also there is no issues as of now. other than the subframe rust issue.
As per the re-call they did it free of cost. But the alignment was not done perfectly. Because they are saying that they were not able to do the alignment due to the rust on the other bolts.
They are not able to open/close those, so they said that they have done at their max. Now the car steering is little bit away from the normal.
Don’t know what will happen due to this. Any idea or suggestion.
I went to Bank Street Hyundai Dealer in Ottawa, Ontario (it is the worst dealer in Ottawa) for that subframe recall. They charged me 90 CAD for front wheel allignment. I said, they should cover it, because I didnt need any allignment, but because of the recall they remove the subframe and becasue of that I need the allignment. Anyway, I talked with the service manager and he said they cover only the recalled part, not the other adjustments made due to the recall. I later send an e-mail to Hyundai-Canada and they aslo said they won't cover the wheel allignment.
It is stupid. Becasue of their fault I took my car with perfectly balanced wheels to the dealer and they charged me to re-balance them. :mad:
